Page 48 of 123
Posted: Thursday 16 March 2017 19:40
by bing69
OK, I installed the gateway and no error messages. (See logfile) Have installed a door sensor. In the app, no problem. However in Domoticz I see no device from Xiaomi.
What am I doing wrong?
2017-03-16 19:32:24.257 XiaomiGateway: will listen on 9898 for hardware id 18
2017-03-16 19:32:24.257 XiaomiGateway: Worker started...
2017-03-16 19:32:24.257 EventSystem: reset all events...
2017-03-16 19:32:24.257 XiaomiGateway: Using 192.168.1.49 for local IP address.
2017-03-16 19:32:24.258 EventSystem: reset all device statuses...
2017-03-16 19:32:24.262 EventSystem: Started
2017-03-16 19:32:25.257 RFXCOM: Using serial port: /dev/ttyUSB0
2017-03-16 19:32:25.660 AppLamp: Bridge found!...
2017-03-16 19:32:35.032 Incoming connection from: 127.0.0.1
Posted: Thursday 16 March 2017 19:45
by jjnj
I need to put the gateway onto a different Wi-Fi network. Do you guys know how to do this without resetting everything?
Posted: Thursday 16 March 2017 19:51
by jjnj
corbin wrote:dcliff1 wrote:
Nice work mate! Its now reporting all the devices. Thanks heaps for that.. really appreciate the good work. Now to go play!
That is a lot of devices, you should have some fun with that!. Are you getting any more? I think I read the limit is around 30 per gateway and would be good to know for sure.
I have just hit 30 devices. Untill now everything is working correctly. Hopefully i can add device number 31 within this week
Posted: Thursday 16 March 2017 21:42
by Derik
jjnj wrote:I need to put the gateway onto a different Wi-Fi network. Do you guys know how to do this without resetting everything?
Perhaps in Domoticz just change the ip adres.. [ same idx ]
Mihome:-(
And in your app is a help function..
There you can ask the helpdesk some help..
And they help me.......... [ with other problems ]
Posted: Friday 17 March 2017 7:48
by corbin
Please be aware that the next Xiaomi Gateway beta update will duplicate all your switches - you will then need to delete the originals and rename the new switches.
With this change, it should fix the double update messages (I hope!)
Please don't update to beta 3.7016, the problem isn't fixed and will duplicate your switches for no benefit.
Posted: Friday 17 March 2017 7:55
by bing69
corbin wrote:Please be aware that the next Xiaomi Gateway beta update will duplicate all your switches - you will then need to delete the originals and rename the new switches.
Currently I do not see at all switches.
How do I get to see the switches ??
Posted: Friday 17 March 2017 9:44
by bbqkees
I now have a black version of the door sensor (because my window frames are black, not white.)
You can't buy them in store unfortunately, I used a spray can from the Praxis (Sensys zwart zijdeglans).
Posted: Friday 17 March 2017 9:47
by lamouette
I did the same with a classic black spay
Posted: Friday 17 March 2017 11:07
by kiquof
corbin wrote:Have you tried deleting hardware id 11? If that doesn't work, look in the Hardware table in the Domoticz.db database and try deleting from there.
Thank you for your reply. I do a software reboot (sudo reboot) without it working,. After a hardware reboot everything is returned in order.
thank you
Posted: Friday 17 March 2017 23:04
by corbin
Please don't update to beta 3.7016, the problem isn't fixed (there is no double up, but you lose control of switches) and will duplicate your switches for no benefit.
Posted: Saturday 18 March 2017 8:27
by Derik
corbin wrote:Please don't update to beta 3.7016, the problem isn't fixed (there is no double up, but you lose control of switches) and will duplicate your switches for no benefit.
mmmm
To late....
Did the upgrade.. [ before reading this
And now?
edit..
Cannot See not my motionsensors and my doorsensor and the light is not working in domoticz.
The cube and the wireless switch are working fine
Posted: Saturday 18 March 2017 9:31
by corbin
Hope to have it fixed soon
Posted: Saturday 18 March 2017 10:30
by murtadin
Derik wrote:corbin wrote:Please don't update to beta 3.7016, the problem isn't fixed (there is no double up, but you lose control of switches) and will duplicate your switches for no benefit.
And now?
Just restore frome backup. Of course you have made one before upgrade.
Posted: Saturday 18 March 2017 12:21
by Derik
corbin wrote:Hope to have it fixed soon
Wait for that...
It's beta... and open source so no problem for me..
I always wait to the stable before use the sensors for real...
Never downgrade...
when you need a tester... i will help
Posted: Saturday 18 March 2017 22:00
by corbin
Please test from
https://github.com/corbinmunce/domoticz
Posted: Saturday 18 March 2017 22:13
by Derik
Sorry do not now how ho to use the github clone..
Or do you have a how to..
Posted: Sunday 19 March 2017 12:51
by thps
my gateway freezes about 4-5 times a day so i had to plug it out and in again.
Does anybody has the same issues with it?
Posted: Sunday 19 March 2017 17:39
by Mat2Vence
Off state are no longer seen on the last beta built.
Door sensor are detecting when open, but do not detect the closed (when the status is correct according to Xiaomi apps).
Same for motion sensor that are kept in detection for ever.
Version: 3.7040
Build Hash: fcc83f4a
Compile Date: 2017-03-19 09:34:59
Posted: Sunday 19 March 2017 19:05
by corbin
Mat2Vence wrote:Off state are no longer seen on the last beta built.
Do you have any devices with duplicate IDs on the Devices page?
Posted: Sunday 19 March 2017 19:13
by corbin
thps wrote:my gateway freezes about 4-5 times a day so i had to plug it out and in again.
No issues here, its been 100% stable so far.
What firmware version? Tried moving it to a different power point?
