Can you give me viewer rights?martk wrote:Blinds not working anymore in latest stable version.
In previous version you could set a slider to open or close, now it gives you 2 buttons, On and Off, both don't do anything.
- galadril
- Domoticz version: latest
Re: Domoticz app 2.0
- Domoticz version: 2022.2
Propably depends on the blinds/remote. Mine are working since the last stable, they didn't work before
Anyone with the same issue?woody4165 wrote:Hi
I'm on the latest beta and I cannot see/add Local Wifi SSID in the Advanced Server Setting.
I have wifi on a it's connected, but the Local Wifi SSID is greyed out.
I'm on a LG G4 with Android 6.0 V20-d, NO root.
Have tried on a Nexus 5 with 6.0.1 rooted and it's working.
Any suggestion ?
Seem strange that I can't see my wifi networks from the app...
- galadril
Really Strange, we have no issues with gettings SSIDs from the phone..woody4165 wrote: Anyone with the same issue?
I can imagine, and the LG G4 is not even rooted or so. It's pure stock!galadril wrote:Really Strange, we have no issues with gettings SSIDs from the phone..woody4165 wrote: Anyone with the same issue?
Is there any log that can help?
I want to but I'm not able to send you a PM since I just registered here.galadril wrote:Can you give me viewer rights?martk wrote:Blinds not working anymore in latest stable version.
Send me an email and i'll send you the login.
- galadril
I*ll add an option to manually add ssids in the settings screen in the next releasemartk wrote: I want to but I'm not able to send you a PM since I just registered here.
- jisse44
- Domoticz version: 4.10915
Hi,RoadXY wrote:
Could you create a video and PM that to me please?
I have now the 0.1.253 version, and still not working.
I can not find a recording application that works, only crapwares...
I work around the problem by using antennas as geofences and URL intent with Llama app
I would love the ability to rotate the camera images in 90 degrees steps in both the app and in the domoticz controller.
Thanks!galadril wrote:I*ll add an option to manually add ssids in the settings screen in the next releasemartk wrote: I want to but I'm not able to send you a PM since I just registered here.
When turning on/off for events will be implemented?
Wysłane z mojego LG-V500 przy użyciu Tapatalka
The nfc tags are working now! Only when the tag is scanned it asked what app to use. After selecting the app domoticz it works.
Is it possible to use always domoticz with nfc.
Under nfc it is not possible to select scene, only switches. A bug?
Verstuurd vanaf mijn SM-T800 met Tapatalk
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
- galadril
You can choose 'aways' on the nfc popup right?marktn wrote:Is it possible to use always domoticz with nfc.
In the next version, you can write a url: http://www.domoticz.com/app
to the nfc tag.. and it wil automaticly be filtered by the app!
At this moment you can only select switches, like for Geofences and QR Codesmarktn wrote:Under nfc it is not possible to select scene, only switches. A bug?
After lastest update blinds dont work anymore.
Can you fix it?
Thanks anyway
Can you fix it?
Thanks anyway
Same problem here..
Blinds were working after the fix from Galadril in previous release.
Now running 0.1.253 and they stopped working.
- galadril
please pm me a test viewer account for your system to testEdwinDaems wrote:Same problem here..
Hi Mark, check email for user and pass.
Is it possible to save preferences in the graphs setting? Many times i am only interested in the temperature, it should be nice if the settings could be saved.
Verstuurd vanaf mijn E5823 met Tapatalk
Upgrading Domoticz to V3.4834 solved the problem!EdwinDaems wrote:Same problem here..
Thx Mark
- galadril
The json api for blinds was changed lately in the Domoticz builds..EdwinDaems wrote:Upgrading Domoticz to V3.4834 solved the problem!
