galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
martk wrote:Blinds not working anymore in latest stable version.
In previous version you could set a slider to open or close, now it gives you 2 buttons, On and Off, both don't do anything.
Can you give me viewer rights?
jannl
Domoticz version: 2025.5.x
Post by jannl »
Propably depends on the blinds/remote. Mine are working since the last stable, they didn't work before
woody4165
Post by woody4165 »
woody4165 wrote:Hi
I'm on the latest beta and I cannot see/add Local Wifi SSID in the Advanced Server Setting.
I have wifi on a it's connected, but the Local Wifi SSID is greyed out.
I'm on a LG G4 with Android 6.0 V20-d, NO root.
Have tried on a Nexus 5 with 6.0.1 rooted and it's working.
Any suggestion ?
Anyone with the same issue?
Seem strange that I can't see my wifi networks from the app...
galadril
Post by galadril »
woody4165 wrote: Anyone with the same issue?
Really Strange, we have no issues with gettings SSIDs from the phone..
woody4165
Post by woody4165 »
I can imagine, and the LG G4 is not even rooted or so. It's pure stock!
Is there any log that can help?
martk
Post by martk »
I want to but I'm not able to send you a PM since I just registered here.
Send me an email and i'll send you the login.
galadril
Post by galadril »
martk wrote: I want to but I'm not able to send you a PM since I just registered here.
I*ll add an option to manually add ssids in the settings screen in the next release
jisse44
Domoticz version: 4.10915
Post by jisse44 »
RoadXY wrote:
Could you create a video and PM that to me please?
I have now the 0.1.253 version, and still not working.
I can not find a recording application that works, only crapwares...
I work around the problem by using antennas as geofences and URL intent with Llama app
burton666
Post by burton666 »
I would love the ability to rotate the camera images in 90 degrees steps in both the app and in the domoticz controller.
woody4165
Post by woody4165 »
codesnipper
Post by codesnipper »
When turning on/off for events will be implemented?
Wysłane z mojego LG-V500 przy użyciu Tapatalka
marktn
Post by marktn »
The nfc tags are working now! Only when the tag is scanned it asked what app to use. After selecting the app domoticz it works.
Is it possible to use always domoticz with nfc.
Under nfc it is not possible to select scene, only switches. A bug?
Verstuurd vanaf mijn SM-T800 met Tapatalk
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
galadril
Post by galadril »
marktn wrote:Is it possible to use always domoticz with nfc.
You can choose 'aways' on the nfc popup right?
In the next version, you can write a url: http://www.domoticz.com/app
to the nfc tag.. and it wil automaticly be filtered by the app!
marktn wrote:Under nfc it is not possible to select scene, only switches. A bug?
At this moment you can only select switches, like for Geofences and QR Codes
rubberduck84
Post by rubberduck84 »
After lastest update blinds dont work anymore.
Can you fix it?
Thanks anyway
EdwinDaems
Post by EdwinDaems »
Same problem here..
Blinds were working after the fix from Galadril in previous release.
Now running 0.1.253 and they stopped working.
galadril
Post by galadril »
EdwinDaems wrote:Same problem here..
please pm me a test viewer account for your system to test
EdwinDaems
Hi Mark, check email for user and pass.
Jango
Post by Jango »
Is it possible to save preferences in the graphs setting? Many times i am only interested in the temperature, it should be nice if the settings could be saved.
Verstuurd vanaf mijn E5823 met Tapatalk
EdwinDaems
Upgrading Domoticz to V3.4834 solved the problem!
Thx Mark :D
galadril
Post by galadril »
EdwinDaems wrote:Upgrading Domoticz to V3.4834 solved the problem!
The json api for blinds was changed lately in the Domoticz builds.. :-)
