Page 47 of 94
Posted: Wednesday 15 February 2017 15:11
by tjofras
This looks great and I want to try it, but I can't find my ds416j under any of the versions?
I'm guessing I won't be able to use any of the other 416-packages?
Posted: Wednesday 15 February 2017 15:52
by jumbotroll
tjofras wrote:This looks great and I want to try it, but I can't find my ds416j under any of the versions?
DS416j added
http://www.jadahl.com/domoticz_beta_6/?arch=armada38x
Posted: Wednesday 15 February 2017 16:10
by dannyf
Just new here so I don't know this is the right topic.
I've installed a Jadahl package on my Synology DS213, but I can't find the installation files for adding some scripts. It should be at volume1\homes\danny. But I can't enter that folder with SSH. Other folders no problem.
Any ideas?
thx, Danny
Posted: Wednesday 15 February 2017 16:17
by jumbotroll
dannyf wrote:Hello,
Any ideas?
thx, Danny
domoticz folder is located in
/usr/local/domoticz on synology
Posted: Wednesday 15 February 2017 16:30
by tjofras
Haha wow I'm impressed!! Thanks a lot!
Posted: Friday 17 February 2017 15:29
by dobber
I'm looking for a version of domoticz from mid or late jan 2017. There is a bug in the February updates that makes my Zipato keypad not work as intended.
I tried outsmarting your website by just changing the version:
http://www.jadahl.com/domoticz_beta_6/p ... 6500-7.spk
But the site is smarter than I am, obviously.
I'm on a DS916+ (Braswell)
Posted: Friday 17 February 2017 15:44
by jumbotroll
@dobber
Older beta versions is deleted from my server, only latest beta version is available.
If this is a bug in newer versions of domoticz, is it not better to report this as a bug and get it corrected?
Posted: Friday 17 February 2017 15:47
by dobber
jumbotroll wrote:@dobber
Agreed, but meanwhile my alarmsystem remains offline
The problem has already been reported here:
viewtopic.php?f=6&t=16164&p=120154#p120154
Posted: Friday 17 February 2017 15:51
by jumbotroll
@dobber
I can always build an older version for you until the bug is fixed
What version do you want v.3.6500? with or without python plugin?
DSM6.0 or DSM6.1?
Posted: Friday 17 February 2017 15:57
by dobber
DSM6.0 or DSM6.1?
Omg, you are awesome!
6500 without python plugin plz.
DSM 6.0.2-8451 Update 9
In the future I'll make sure to make a backup of the install file once a month or so
Posted: Friday 17 February 2017 16:05
by jumbotroll
@dobber
Ok
give me 10 min and I will give you a link for domoticz v.3.6500 arch-braswell for DSM 6.0.2.
Remember you can not downgrade domoticz, so you have to take backup of domoticz.db and uninstall the domoticz package from package center.
Posted: Friday 17 February 2017 16:11
by dobber
Ok
Noticed that when I was switching from 6730 with python to 6708 without python
Thanks for the support. That's what makes this community so great!
Posted: Friday 17 February 2017 16:22
by jumbotroll
@dobber
Here you go
domoticz_braswell-6.0_3.0.6500-7.spk
http://www.jadahl.com/synospk/
Posted: Friday 17 February 2017 16:49
by dobber
@jumbotroll
The alarm system works again. Thank you!
Posted: Friday 17 February 2017 16:53
by jumbotroll
dobber wrote:@jumbotroll
Great!
Let us hope the developers fix this bug and you can update to the latest version
Posted: Friday 17 February 2017 22:41
by bertbigb
I do not know if this is the right spot to ask this question, if not please let me know.
I have a Synology DS1515, running Domoticz (latest beta) V3.6708. To the domoticz I have a few Yeelights connected and to controle these lights I have to send a command like echo -ne '{"id":1, "method":"set_hsv", "params":[273, 65, "smooth", 2000]}\r\n' | nc -w1 192.168.2.81 55443
when I do this from the command prompt (ssh to the DS1515) then it works.
But when I send the command from a lua script like:
runcommandYeelight ="echo -ne '{"id":1, "method":"set_hsv", "params":[273, 65, "smooth", 2000]}\r\n' | nc -w1 192.168.2.81 55443"
os.execute(runcommandYeelight)
Then nothing happens, however if i send the same command from a raspberry PPi the bulb reacts as expected
Can anyone help me to point out what I could do to make this work for Domoticz on my Synology?
Many thanks
Posted: Thursday 23 February 2017 7:56
by Egregius
Synology released DSM 6.1 build 15047
One of the release notes is:
Due to infrastructure update, packages will need re-initialization after upgrading to DSM 6.1. The process will occupy a higher CPU usage and can take up to an hour depending on the number of packages installed.
Is it safe to update?
Posted: Thursday 23 February 2017 9:11
by jumbotroll
Egregius wrote:Synology released DSM 6.1 build 15047
I have not tested (still on 6.02 here) 2 antother users tested with success.
But I have build domoticz for DSM 6.1 because some models got new kernel and need updated usb drivers.
http://www.jadahl.com/domoticz_beta_6.1/
Posted: Thursday 23 February 2017 9:41
by Egregius
OK, will update today and report back if it still works with stable 5877 version
Thank you.
Posted: Thursday 23 February 2017 11:05
by Egregius
No problem here, stable 5877 direct online on my Syno 1513+
