Page 46 of 94
Posted: Wednesday 14 December 2016 16:49
by Gravityz
upgraded to 6072
upgrade went smooth.
so far looking good.
Posted: Wednesday 14 December 2016 17:09
by jumbotroll
Gravityz wrote:upgraded to 6072
Have you installed DSM 6.1 Beta? and what type NAS do you have?
by Egregius
6072? I just received 3.6147 on Syno DS1513+
edit: simultanous post
@Jumbotroll: thanks again for the great work you do for Syno
Posted: Wednesday 14 December 2016 18:08
by Gravityz
My nas is a DS112+
DSM 6.0.2-8451 Update 5
no 6.1 beta.
why is that a good thing
Posted: Wednesday 14 December 2016 18:31
by jumbotroll
Gravityz wrote:My nas is a DS112+
no 6.1 beta.
Ok I miss understood, because the latest beta for DSM 6.0.2 is Domoticz v3.0.6147-7
http://www.jadahl.com/domoticz_beta_6/?arch=88f6281
I miss understood, because the latest domoticz beta for DSM 6.1 Beta is Domoticz v3.0.6072-7
http://www.jadahl.com/domoticz_beta_6.1/?arch=88f6281
I have not tested DSM 6.1 Beta, will wait for the release
Posted: Wednesday 14 December 2016 18:36
by Gravityz
yes,
i just downloaded 6072 2 days ago(so i missed the latest version)
i noticed a new zwave module was not supported on 5019 but was supported on 6072
It turned out the module is recognised in 6072 but far from supported because a config file is missing.
i will buy the new module tomorrow and will test it out with a config file i made myself
Posted: Monday 19 December 2016 10:31
by Isane
Hardware:
Synology DS215J DSM 6.0.2-8451 Update 6
P1 USB cable
Package installed
Domoticz (version 3.0.5877-7)
UsbSerialDrivers DSM 6.0 beta (version 3-0)
I have the P1 cable in the USB3 port but Domoticz does not recognize the P1 cable.
How can I fix this issue? Is it a driver problem or something else?
Posted: Monday 19 December 2016 11:18
by sincze
did you try 'dmesg' to see if synology recognized the cable as USB device?
Posted: Monday 19 December 2016 15:56
by Isane
sincze wrote:did you try 'dmesg' to see if synology recognized the cable as USB device?
Thanks. I see indeed some errors (I did 2 outputs, 1 with the p1 kabel and 1 without a p1 kabel).
I see the following error with a p1 cable
Posted: Monday 19 December 2016 16:50
by sincze
Isane wrote:sincze wrote:did you try 'dmesg' to see if synology recognized the cable as USB device?
A yes, that is why it does not show up in Domoticz, not recognized as ttyUSBx device.
Sure you have the correct drivers??
Posted: Monday 19 December 2016 16:52
by Isane
sincze wrote:Isane wrote:sincze wrote:did you try 'dmesg' to see if synology recognized the cable as USB device?
How can I pick the correct driver? The P1 cable works fine at the USB2 port. (but on that port i have the Aeotec USB Z-Stick - Z-Wave Plus)
I've installed the following packages:
EDIT: 20-12-2016: I removed UsbSerialDrivers DSM 6.0 beta (version 3-0) and Domoticz. I installed Domoticz again. (from
http://www.jadahl.com/domoticz_stable_6/) . But thats also not the solution.
Posted: Tuesday 20 December 2016 19:45
by Gravityz
zwave control panel is only displaying correctly on an iphone or ipad.
Windows10 pc with edge, internet explorer or firefox does not work anymore.
is there a way to extract files from older spk packages.
i have problems with zwave control panel and need some files from an old package.
Posted: Saturday 24 December 2016 14:15
by jumbotroll
Domoticz with Python PluginManager for Synology test packages.
Download here:
http://www.jadahl.com/domoticz_beta_6_python/
Before installing this package, you have to install Python 3.5.1-0104 from Synology package center!
Python package can also be downloaded manually here:
http://download.synology.com/download/P ... .5.1-0104/
Plugin folder is located in folder /usr/local/domoticz/var/plugins/ on Synology!
After you have added *py files in the plugin folder, you have to stop and start domoticz from package center for modules to load.
BTW! Take backup of domoticz.db and all you script before you test as always
Merry christmas and happy new year!
Posted: Saturday 24 December 2016 14:23
by Egregius
What can you do with this?
Posted: Saturday 24 December 2016 14:32
by jumbotroll
Egregius wrote:What can you do with this?
Add python plugins
https://www.domoticz.com/wiki/Developin ... n#Overview
Posted: Sunday 25 December 2016 14:03
by kaivalagi
That's great, hmmmm, lots of python libraries to utilise....I assume if a library works natively it will work via plugins? I.e. full library support?
Sent from my ASUS_T00P using Tapatalk
Posted: Wednesday 28 December 2016 18:38
by Soulplayer
My domoticz keeps crashing? Does anybody has an idea what is going wrong?
Posted: Saturday 14 January 2017 17:43
by matsumoto
I have troubles with the lastest Domoticz version installed on my DS413j (events not working well, notifications not sent, no log on some devices ...).
It was working better with the previous version.
I'm still on DSM 5.2 and when i check for the lastest version available, it is Domoticz v3.0.5864-7 and i have ... v3.0.5877-7 ... which is supposed to be for DSM 6.0
Is it the source of my problems ?
Will it be an update for DSM 5.2 ?
Do i go back to 3.0.5864 and everything will be better ?
Thank you.
Posted: Saturday 14 January 2017 17:51
by jumbotroll
matsumoto wrote:Hi,
Thank you.
I do not update the DSM 5.2 domoticz packages so often anymore, but I can compile a new version for you if you want to test?
Edit: Here you go
Domoticz v3.0.6343-7 for DS413j for DSM 5.2
http://www.jadahl.com/domoticz_beta/?arch=88f6282
Posted: Saturday 14 January 2017 18:15
by matsumoto
jumbotroll wrote:matsumoto wrote:Hi,
Thank you.
I do not update the DSM 5.2 domoticz packages so often any more, but I can compile a new version for you if you want to test?
Edit: Here you go
OMG !
You're so reactive and helpful !
Thank you !
... i should learn how to compile myself some day ...
