Page 44 of 94
Posted: Sunday 30 October 2016 23:32
by jumbotroll
@Jelmer
cp210x.ko is used by Aeon Labs Z-Stick Series II and I don't think this is the source to your problem.
I do not have neo coolcam PIR for testing, so I can't debug this problem.
I am also using Neo Power Plug and z-stick gen 5, this working perfect.
So I don't have any idea
Posted: Monday 31 October 2016 1:29
by Jelmer
Thanks for your quick answer...
It's not only about the coolcam node, it's just on the z-stick gen 5 too. When i first installed domoticz, I only had the z-stick with the same issue.
Every action I make on the controller, it's crashing after the error report, for example "
5. Enable Controller Blinking" settings altered, click apply and immediate crash. (I think that's where the error report is the result from)
So, where can I troubleshoot why domoticz is crashing? Mayby it's a permission issue? Some output, don't know if it's relevant.
I really hope there's a solution to this, I cannot even set the log debug enable parameter on the stick, it crashes the package. (What I really want to do is some modification on the PIR, like sensitivity, also... not possible)
It's like.... any
write/send action to the stick is causing this.
[ 348.130000] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
[ 471.280000] usb 1-1.3: new full speed USB device using orion-ehci and address 4
[ 471.390000] Got empty serial number. Generate serial number from product.
[ 471.390000] usb 1-1.3: configuration #1 chosen from 1 choice
[ 471.400000] cdc_acm 1-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 471.410000] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
T: Bus=01 Lev=02 Prnt=02 Port=99 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=02(comm.) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0658 ProdID=0200 Rev= 0.00
S: Product=USBDevice
S: SerialNumber=d1b2abadc88cbe9dc8
C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=02 Prot=01 Driver=cdc_acm
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
E: Ad=82(I) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 32 Ivl=0ms
usbserial 23980 5 ftdi_sio,cp210x,pl2303,ch341,ti_usb_3410_5052
usbcore 136506 15 ehci_hcd,ohci_hcd,xhci_hcd,etxhci_hcd,usb_storage,usblp,usbhid,usbserial,ftdi_sio,cp210x,pl2303,ch341,ti_usb_3410_5052,cdc_acm
Posted: Monday 31 October 2016 9:32
by jumbotroll
I think maybe this is a cdc_acm driver problem, DS212 with DSM6.x use a older Linux Kernel v2.6.32.12.
I don't have any quick fix for this.
Posted: Monday 31 October 2016 9:41
by GJKNL
Since the latest stable update yesterday on my Synology, the log is running full with:
2016-10-31 09:40:23.322 Error: Webserver: File '/icons/min.png': No such file or directory (2)
2016-10-31 09:40:23.322 Error: Webserver: File '/icons/plus.png': No such file or directory (2)
2016-10-31 09:40:31.434 Error: Webserver: File '/icons/min.png': No such file or directory (2)
2016-10-31 09:40:31.444 Error: Webserver: File '/icons/plus.png': No such file or directory (2)
2016-10-31 09:40:39.518 Error: Webserver: File '/icons/min.png': No such file or directory (2)
2016-10-31 09:40:39.519 Error: Webserver: File '/icons/plus.png': No such file or directory (2)
Any idea how to solve this?
Posted: Monday 31 October 2016 11:29
by RedEarth
jumbotroll wrote:Domoticz on synology use SSL port:8443
I upgraded to V3.5837 yesterday and I can no longer connect on port 8443, but I get an error message in the log saying that it's trying to use 443 and can't do so because it's already in use. Also, the standard http port seems to have changed from 8084 to 8080 but that doesn't seem to be causing issues for me because 8080 was available, I just need to update my browser favourites
Thanks for the great work!
Posted: Monday 31 October 2016 11:37
by jberinga
Just updated to the latest version (3.0.5.837-7), but now Domoticz won't start on my DS214se. I also installed it manually, but after the install it stops where it normally automaticlly starts. When starting it manually it stops as well.
What can I do to fix this? Is there a rollback option?
Posted: Monday 31 October 2016 12:20
by Egregius
jberinga wrote:Is there a rollback option?
Off course, rollback your versioned backup.
Besides that, my Syno updated perfectly to this stable version, even from a previous beta channel.
Posted: Monday 31 October 2016 14:09
by jberinga
Thanks for the quick reply, the bad new is that I don't have\make a back-up of the previous version...
But the good news is that Domoticz works again after restarting the NAS
Is it a good idea to update Domoticz everytime there is a new version available? Or is there a change log that I can check and decide if it is worth to update or not?
Posted: Monday 31 October 2016 14:26
by Egregius
One could think of this: if it ain't broken, don't fix it.
If the commits on Github don't include stuff you like or need and you don't have issues with the current version and you didn't add new hardware... Why upgrade?
But, backup, backup, backup!!!
Posted: Wednesday 02 November 2016 11:23
by RedEarth
RedEarth wrote:jumbotroll wrote:Domoticz on synology use SSL port:8443
Solved...sort of. I backed up the database, uninstalled and then reinstalled Domoticz from within DSM, which triggered the wizard that prompts for the port numbers and they were defaulting to 8084 and 8443 as expected. I guess the upgrade must've somehow wiped out this configuration and not triggered the wizard to reapply it.
Posted: Thursday 10 November 2016 19:01
by jumbotroll
Domoticz Version #3.5877 Release stable for Synology DSM 6.x
http://www.jadahl.com/domoticz_stable_6/
Domoticz Version #3.5877 Release stable for Synology DSM 5.2
http://www.jadahl.com/domoticz_stable/
Posted: Saturday 12 November 2016 21:38
by mschut
Just trying to use my HGI-80 (for Evohome) again on Domoticz with the Synology package. However, I cannot see it (no serial port, no driver?). A few months ago it did work thanks to you, did something change or might I be missing something again? I just freshly installed the beta package for DSM 6, connected the HGI-80, rebooted the NAS, but I cannot set the hardware of the HGI-80 in Domoticz. (DS216+). Is the driver still on board?
Posted: Saturday 12 November 2016 21:55
by jumbotroll
Yes the driver is still on board, nothing has change in the cross compiling on this side..
Type dmesg and check if driver is loaded.
Posted: Saturday 12 November 2016 22:06
by mschut
jumbotroll wrote:Yes the driver is still on board, nothing has change in the cross compiling on this side..
Thanks for the quick response. I will have a look. Can take a while, I always have issues logging on through SSH with root, somehow the password is never correct (and yes, I do use the same as admin).
Posted: Saturday 12 November 2016 22:29
by mschut
Reading now. Stumbled across:
[ 122.782594] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 122.791183] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[ 122.799838] ti_usb_3410_5052 1-4:1.0: TI USB 3410 1 port adapter converter detected
[ 124.429583] init: pkg-LogCenter-syslog main process (13864) killed by HUP signal
[ 124.438832] init: pkg-LogCenter-syslog main process ended, respawning
[ 124.543490] usb 1-4: ti_download_firmware - error downloading firmware, -110
[ 124.551446] ti_usb_3410_5052: probe of 1-4:1.0 failed with error -5
Posted: Saturday 12 November 2016 22:38
by jumbotroll
Ok, I can't test this.
Check if you have the firmware files in /lib/firmware folder.
Posted: Saturday 12 November 2016 22:43
by mschut
These you mean?
-rwxrwxrwx 1 root root 13765 Nov 10 18:41 ti_3410.fw
-rwxrwxrwx 1 root root 13764 Nov 10 18:41 ti_5052.fw
Looks like I do
Posted: Monday 28 November 2016 23:07
by jumbotroll
Created a few Domoticz packages for DSM6.1 Beta, if someone wants to test this.
I'll build more gradually.
ONLY USE THIS WITH DSM 6.1 BETA !!!
http://www.jadahl.com/domoticz_beta_6.1/
Posted: Tuesday 29 November 2016 17:30
by mcwieger
jberinga wrote:Just updated to the latest version (3.0.5.837-7), but now Domoticz won't start on my DS214se. I also installed it manually, but after the install it stops where it normally automaticlly starts. When starting it manually it stops as well.
Same or similar issue here: updated to 3.0.5877-7 via update in Package Center. When I click Run, it is starting up, but always returns to Stopped status.
Tried to restart DSM, no result.
Any ideas?
Posted: Wednesday 30 November 2016 11:28
by jumbotroll
Any ideas?
I don't know why you have this problem, but try the latest beta.
Do you installed the right version?
Domoticz for DSM 5.2 do not work on DMS 6.x.
Domoticz v3.0.5989-7 for DSM 6.x
http://www.jadahl.com/domoticz_beta_6/?arch=armadaxp
