RoadXY
Domoticz version: 2.2331
Re: Domoticz app 2.0
Post by RoadXY »
I've created a little "Troubleshooting geofences" guide:
https://github.com/domoticz/domoticz-an ... -geofences
Jango
Post by Jango »
Please please, don't need qr or nfc. What I really want are better graphs and camera stream.
Verstuurd vanaf mijn E6853 met Tapatalk
RoadXY
Post by RoadXY »
Jango wrote:Please please, don't need qr or nfc. What I really want are better graphs and camera stream.
Both working on.
It's just hard
Jango
Post by Jango »
Good luck!
After updating to new Android client the description of the dimmers are not on the right position.
RoadXY
Post by RoadXY »
Jango wrote:Good luck!
Thanks.
Will add that to the to-do list.
piokuc
Post by piokuc »
In new version on screen switches color button and color font on button ON for switches wake on lan is wrong. Button is brightnes and font is white. On screen plans is ok.
pj-r
Domoticz version: V3.8650
Post by pj-r »
RoadXY wrote:
pj-r wrote:
piokuc wrote: For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
And for my MySensors HVAC device set point from 4*C to 55*C ;)
Currently I get 10 to 30*C
But when do you set your thermostat to below 10*C or above 30*C?
Its setpoint of my air to water heat pump request temp. Its making hot water for underfloor heating. The request temp is not room temp its the water temp request of the heating system. I have separate room thermostats for room temp adjusting.
Its for optimizing the heat pump load. Less the pump have to make temp difference less it consumes energy. I have script adjusting this temp based on outdoor temp and couple other variables. Sometimes it would be nice to adjust it manually.
In my case this setpoint is between 25(out temp >=16) and 37(out temp -30).
Jango
Post by Jango »
Just discovered that things have changed for the graphs, it is getting better.
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
pj-r wrote: Its setpoint of my air to water heat pump request temp. Its making hot water for underfloor heating. The request temp is not room temp its the water temp request of the heating system. I have separate room thermostats for room temp adjusting.
could you please publish your script?
Rfxcom
Raspi 4
pj-r
Post by pj-r »
jkimmel wrote:could you please publish your script?
I'll adjust the arduino code and this script to work well and then I'll make a project topic and publish everything there.
maluko
Post by maluko »
hi people
i use domoticz app with same server, only with default server i have same widget but when we change server and forget to change back on close app, the widget will not work because the definition are for other server, so i wonder if it is possible to on every time that we goes out of App this will put the server on default.
videobelu
Post by videobelu »
Hi i am new on Domoticz.....my question is how can i have a bigger slide on screen of Android App????
jbreed
Post by jbreed »
Is there the ability to switch the thermostat reading and SetPoint to Fahrenheit?
Justin
galadril
Domoticz version: latest
Post by galadril »
Jango wrote:After updating to new Android client the description of the dimmers are not on the right position.
Thanks for the screenshot, fixed in next release
piokuc wrote:In new version on screen switches color button and color font on button ON for switches wake on lan is wrong.
Please make a screenshot, i think this is fixed in next release....
Please stay on topic :)
maluko wrote:i use domoticz app with same server, only with default server i have same widget but when we change server and forget to change back on close app
I'll look into this, maybe save the server connection per widget.. so you could add a widget from server a AND server b ;) TODO!
jbreed wrote:Is there the ability to switch the thermostat reading and SetPoint to Fahrenheit?
You can change this on the Domoticz system, on the settings page
:P
Work in progress, better dashboard:
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Great project and progress so far galadril and others!
Have you been able to fix the roller/shutter problem in this release? :oops:
EdwinDaems wrote:Any progress in working on the blinds / rolling shutter fix?
http://www.domoticz.com/forum/viewtopic ... nds#p76800
Or is it fixed in the upcoming release?
galadril
Post by galadril »
Skippiemanz wrote:Have you been able to fix the roller/shutter problem in this release?
I actually can't find the problem with blinds :) ( i don't have any to test with also..)
EdwinDaems
Post by EdwinDaems »
Problem with Blinds is that only stop command is sent.
If you want I can give you remote access.
Cannot PM myself, but you can send me a PM and I'll leave my mailadres or phonenumber to grant you access.
Skippiemanz
I can give you access also. Let me know I've desired. Indeed only stop command is send.
Verstuurd vanaf mijn SM-G925F met Tapatalk
abductor
Post by abductor »
I like this app because the widgets actually work. The dashboard unfortunately doesn't look nice on a 7 inch screen. I got an Amazon fire and made the home screen look like the attached. There's a virtual button on the bottom that will activate away mode for the alarm when you're about to leave the house, and the 3 sensors above it just give you the status of the house. There's the security panel URL link in case the alarm needs to be deactivated and your phone for some reason can't connect to the network or is dead.
Although the switches could look nicer with transparent backgrounds, its probably not worth your time since its just superficial.
It would be nice if we can modify the font colors and text sizes based on the device. I like the current values for my phone but on the tablet I'd prefer something bigger so it can be read from a distance and buttons can be hit easily.
Skippiemanz
Just updated to version 0.1.250 and can confirm the blind are working perfect!
