- RoadXY
- Domoticz version: 2.2331
Re: Domoticz app 2.0
I've created a little "Troubleshooting geofences" guide:
https://github.com/domoticz/domoticz-an ... -geofences
Jango
Please please, don't need qr or nfc. What I really want are better graphs and camera stream.
Verstuurd vanaf mijn E6853 met Tapatalk
- RoadXY
Both working on.Jango wrote:Please please, don't need qr or nfc. What I really want are better graphs and camera stream.
It's just hard
Jango
Good luck!
After updating to new Android client the description of the dimmers are not on the right position.
- RoadXY
Thanks.Jango wrote:Good luck!
Will add that to the to-do list.
piokuc
In new version on screen switches color button and color font on button ON for switches wake on lan is wrong. Button is brightnes and font is white. On screen plans is ok.
pj-r
- Domoticz version: V3.8650
Its setpoint of my air to water heat pump request temp. Its making hot water for underfloor heating. The request temp is not room temp its the water temp request of the heating system. I have separate room thermostats for room temp adjusting.RoadXY wrote:But when do you set your thermostat to below 10*C or above 30*C?pj-r wrote:And for my MySensors HVAC device set point from 4*C to 55*Cpiokuc wrote: For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
Currently I get 10 to 30*C
Its for optimizing the heat pump load. Less the pump have to make temp difference less it consumes energy. I have script adjusting this temp based on outdoor temp and couple other variables. Sometimes it would be nice to adjust it manually.
In my case this setpoint is between 25(out temp >=16) and 37(out temp -30).
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
Jango
Just discovered that things have changed for the graphs, it is getting better.
jkimmel
- Domoticz version: 2021.1
could you please publish your script?pj-r wrote: Its setpoint of my air to water heat pump request temp. Its making hot water for underfloor heating. The request temp is not room temp its the water temp request of the heating system. I have separate room thermostats for room temp adjusting.
Rfxcom
Raspi 4
Raspi 4
pj-r
I'll adjust the arduino code and this script to work well and then I'll make a project topic and publish everything there.jkimmel wrote:could you please publish your script?
maluko
hi people
i use domoticz app with same server, only with default server i have same widget but when we change server and forget to change back on close app, the widget will not work because the definition are for other server, so i wonder if it is possible to on every time that we goes out of App this will put the server on default.
videobelu
Hi i am new on Domoticz.....my question is how can i have a bigger slide on screen of Android App????
jbreed
Is there the ability to switch the thermostat reading and SetPoint to Fahrenheit?
Justin
Justin
- galadril
- Domoticz version: latest
Thanks for the screenshot, fixed in next releaseJango wrote:After updating to new Android client the description of the dimmers are not on the right position.
Please make a screenshot, i think this is fixed in next release....piokuc wrote:In new version on screen switches color button and color font on button ON for switches wake on lan is wrong.
Please stay on topicjkimmel wrote:could you please publish your script?
I'll look into this, maybe save the server connection per widget.. so you could add a widget from server a AND server bmaluko wrote:i use domoticz app with same server, only with default server i have same widget but when we change server and forget to change back on close app
You can change this on the Domoticz system, on the settings pagejbreed wrote:Is there the ability to switch the thermostat reading and SetPoint to Fahrenheit?
Work in progress, better dashboard:
Skippiemanz
- Domoticz version: 4.10233
Great project and progress so far galadril and others!
Have you been able to fix the roller/shutter problem in this release?
EdwinDaems wrote:Any progress in working on the blinds / rolling shutter fix?
http://www.domoticz.com/forum/viewtopic ... nds#p76800
Or is it fixed in the upcoming release?
- galadril
I actually can't find the problem with blindsSkippiemanz wrote:Have you been able to fix the roller/shutter problem in this release?
EdwinDaems
Problem with Blinds is that only stop command is sent.
If you want I can give you remote access.
Cannot PM myself, but you can send me a PM and I'll leave my mailadres or phonenumber to grant you access.
Skippiemanz
I can give you access also. Let me know I've desired. Indeed only stop command is send.
Verstuurd vanaf mijn SM-G925F met Tapatalk
I like this app because the widgets actually work. The dashboard unfortunately doesn't look nice on a 7 inch screen. I got an Amazon fire and made the home screen look like the attached. There's a virtual button on the bottom that will activate away mode for the alarm when you're about to leave the house, and the 3 sensors above it just give you the status of the house. There's the security panel URL link in case the alarm needs to be deactivated and your phone for some reason can't connect to the network or is dead.
Although the switches could look nicer with transparent backgrounds, its probably not worth your time since its just superficial.
It would be nice if we can modify the font colors and text sizes based on the device. I like the current values for my phone but on the tablet I'd prefer something bigger so it can be read from a distance and buttons can be hit easily.
- houseTablet.jpg (119.38 KiB) Viewed 3163 times
Skippiemanz
Just updated to version 0.1.250 and can confirm the blind are working perfect!
