[MyDomoAtHome] Support thread
epierre
Re: [MyDomoAtHome] Support thread
Post by epierre »
Hmmm do you are running 0.2.29?
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
febalci
Post by febalci »
@epierre, Yes i am using 0.2.29. In the beginning I was running 0.2.26 on Synology using jadahl package, everything was working fine. Then i updated to 0.2.27 jadahl package; "tempmode not defined" error showed up. Updated to jadahl 0.2.29, same error again. Uninstalled jadahl 0.2.29 and reinstalled 0.2.29; same error again. Then i created a config.json file under /etc/mydomoathome as per your suggestion; this solved everything.
epierre
Post by epierre »
ok thanks for the clarification, I've had many support request on the french forum, I'll investigate how to get this info from domoticz directly to avoid further issues like this...
reza
Domoticz version: 2024.4
Post by reza »
hi guys
i have problem...
pi@raspberrypi:~ $ wget -q http://www.e-nef.com/domoticz/mdah/nodejs_4.4.2_armhf.deb
pi@raspberrypi:~ $ sudo dpkg -i nodejs_4.4.2_armhf.deb
(Reading database ... 139411 files and directories currently installed.)
Preparing to unpack nodejs_4.4.2_armhf.deb ...
Unpacking nodejs (4.2.2) over (0.10.29~dfsg-2) ...
dpkg: error processing archive nodejs_4.4.2_armhf.deb (--install):
 trying to overwrite '/usr/bin/node', which is also in package nodejs-legacy 0.10.29~dfsg-2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
epierre
Post by epierre »
Hello, you must remove the previous node package which conflicts
epierre
Post by epierre »
You must remove the previous node package whixh conflicts
reza
Post by reza »
epierre wrote: Saturday 21 October 2017 19:10 You must remove the previous node package whixh conflicts
thank you . resolve problem. but a question. i have a private ip (static) from my ISP.and a ip from modem for raspberry pi and a local ip for imperihome. i am confuse :(
i want when i am in home , so i can connect to domoticz locally(with raspberrypi ip) and when i am out of home can connect with private ip from isp.
now i can connect just locally. this is my setting:
http://127.0.0.1:8080/json.htm
http://192.168.1.201:3002
and i have a private ip from isp:
X.X.X.82
can you help me ?how do this setting for auto connect locally and remote (both) ?
epierre
Post by epierre »
Looks like a nat or firewall rule to add to your isp box
Eternity
Post by Eternity »
Installed the latest version on my Synology DS214+
The package starts, but stops after a couple of seconds:
This started after I installed the suggested update....
How can I solve this?
Thank you!
PS
Previously posted in wrong forum ... sorry
Last edited by Eternity on Tuesday 24 October 2017 14:15, edited 2 times in total.
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
epierre
Post by epierre »
@eternity as we said previously, you need to do:
ssh admin@nas
sudo mkdir /etc/mydomoathome
sudo nano /etc/mydomoathome/config.json
in the file do add:
"app_name": "MyDomoAtHome",
"auth": null,
"tempmode": "C",
"domoticz": {
"ssl": false,
"host": "127.0.0.1",
"port": "8084",
"path": "/",
"auth": null
"port": "3002",
"passcode": ""
Eternity
Post by Eternity »
@epierre
Sorry about that!
I managed to create the dir and file and all is working nicely again!
Thanks for the help!
Synology DS218+
Homey controller
HUE lights
IP camera's
epierre
Post by epierre »
great ! I've not had time to overturn this issue htat does not occur on every syno ... will do that mater !
bmath
Post by bmath »
Hi ,
like many users, i've an issue with the last update.
i tried to apply what said before but nothing works.
in /etc/mydomoathome/config.json
  "auth": null,
  "tempmode": "C",
   "domoticz": {
    "ssl": false,
    "port": "7777",
    "path": "/",
    "auth": { "username": "login", "password": "passord" },
  "port": "3002",
  "passcode": ""
mydomoathome is installed with domoticz (port 7777) on the same raspberry.
when i tried to start MyDomoAtHome :
error: Global conf parsing issue !
error:  Error: Error parsing your configuration file: [/etc/mydomoathome/config.json]: Unexpected token }
    at File.loadSync (/usr/share/mydomoathome/app/node_modules/nconf/lib/nconf/stores/file.js:160:11)
    at Provider.add (/usr/share/mydomoathome/app/node_modules/nconf/lib/nconf/provider.js:137:23)
    at Provider.use (/usr/share/mydomoathome/app/node_modules/nconf/lib/nconf/provider.js:110:10)
    at loadGlobalConf (/usr/share/mydomoathome/app/mdah.js:94:9)
    at Object.<anonymous> (/usr/share/mydomoathome/app/mdah.js:2701:1)
    at Module._compile (module.js:435:26)
    at Object.Module._extensions..js (module.js:442:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:311:12)
    at Function.Module.runMain (module.js:467:10)
error: Global conf load issue !
    at loadStore (/usr/share/mydomoathome/app/node_modules/nconf/lib/nconf/provider.js:396:26)
    at /usr/share/mydomoathome/app/node_modules/nconf/node_modules/async/lib/async.js:356:13
    at async.forEachOf.async.eachOf (/usr/share/mydomoathome/app/node_modules/nconf/node_modules/async/lib/async.js:233:13)
    at _asyncMap (/usr/share/mydomoathome/app/node_modules/nconf/node_modules/async/lib/async.js:355:9)
    at Object.map (/usr/share/mydomoathome/app/node_modules/nconf/node_modules/async/lib/async.js:337:20)
    at loadBatch (/usr/share/mydomoathome/app/node_modules/nconf/lib/nconf/provider.js:405:11)
    at Provider.load (/usr/share/mydomoathome/app/node_modules/nconf/lib/nconf/provider.js:449:7)
    at loadConf (/usr/share/mydomoathome/app/mdah.js:105:15)
    at Object.<anonymous> (/usr/share/mydomoathome/app/mdah.js:2702:1)
warn: basic configuration not found in /etc/mydomoathome/config.json, defaulting
warn: domoticz access configuration not found in /etc/mydomoathome/config.json, defaulting
info: Domoticz server: http://127.0.0.1:8080/json.htm
info: Node version: 4.2.2
info: MDAH version: MyDomoAtHome 0.2.29
info: OS version: Linux linux 4.9.41-v7+
info: Hostname: raspberrypi 192.168.1.17 in /var/www /
there is someting that i don't understand :?
thanks per advance for ur help
epierre
Post by epierre »
no coma before }
bmath
Post by bmath »
that works! thanks =)
gdusordet
Post by gdusordet »
still experiencing the same issue, I have added the file
vi /etc/mydomoathome/config.json
"auth": null,
"tempmode": "C",
"domoticz": {
"ssl": false,
"port": "8084",
"path": "/",
"auth": null
"port": 3002,
"passcode": ""
grant the right
chmod a+rx /etc/mydomoathome
chmod a+rx /etc/mydomoathome/config.json
unfortunatly each time I start ImperiHome, mydomoathome is crashing
info: Domoticz server: http://127.0.0.1:8084/json.htm
info: Node version: 4.8.4
info: OS version: Linux linux 3.10.102
info: Hostname: BG-Station 169.254.171.110 in /root /root
info: Refreshing version cache: v0.2.30
291 Open 1 100
809 Closed 0 0
712 Closed 0 0
528 Open 1 100
564 Closed 0 0
713 Closed 0 0
/volume1/@appstore/MyDomoAtHome/app/mdah.js:421
params.push({"key": "Value", "value": ret[lvl].toString()});
TypeError: Cannot read property 'toString' of undefined
at DevMultiSwitch (/volume1/@appstore/MyDomoAtHome/app/mdah.js:421:51)
at Request._callback (/volume1/@appstore/MyDomoAtHome/app/mdah.js:2437:45)
at Request.self.callback (/volume1/@appstore/MyDomoAtHome/app/node_modules/request/request.js:200:22)
at emitTwo (events.js:87:13)
at Request.emit (events.js:172:7)
at Request.<anonymous> (/volume1/@appstore/MyDomoAtHome/app/node_modules/request/request.js:1067:10)
at emitOne (events.js:82:20)
at Request.emit (events.js:169:7)
at IncomingMessage.<anonymous> (/volume1/@appstore/MyDomoAtHome/app/node_modules/request/request.js:988:12)
at emitNone (events.js:72:20)
epierre
Post by epierre »
@gdusordet your issue is different, can you send me the domoticz definition of your multiswitch ?
http://169.254.171.110:8080/json.htm?ty ... order=Name
gdusordet
Post by gdusordet »
Hi epierre, how do I get the definition of the multiswitch?
Thanks for your help
epierre
Post by epierre »
From the link above as it seems it was your ip
Stockfisch
Post by Stockfisch »
on my system, ImperiHome stops displaying the instant energy reporting a few hours after restarting domoticz for most of my devices.
This is happening for all my wall plugs (FGWPF-102) plugs and my dimmer (EFGD-212). For my in wall switches (FGS-213) the instant energy is displayed without any problems.
Is anyone having the the same issue?
Thanks Dirk
NUC5CPYH - Proxmox VE - Ubuntu 18.4
