Page 41 of 94
Posted: Saturday 16 April 2016 15:38
by Eternity
Will try this weekend. Thank you !
Posted: Sunday 17 April 2016 10:25
by iAmRenzo
I added the regular beta repo, and updated to 3.0.5070-7.
Then I saw the DSM6 beta repo, added that one but no updated is pushed. Nor can I force a reinstallation.
So I still cannot start the service, it will be stopped automatically. What to do?
Posted: Sunday 17 April 2016 11:47
by franzelare
since the last domoticz update domoticz is crashing all the time on my NAS, pushing to many switches in a short period makes it crash...
my mochad driver is now crashing once every other day or so...
all in all I decided to go back to raspberry pi since that has been running stable for a long time without any issues and the synology version gives me nothing but work to keep it up and running...
Posted: Sunday 17 April 2016 12:21
by Egregius
franzelare wrote:pushing to many switches in a short period makes it crash...
I noticed that also.
In my script I use a 0,8sec delay between switches. If not I receive errors concerning not able to write to serial port or something.
Posted: Sunday 24 April 2016 16:50
by jberinga
When deleting or editing\saving LUA scripts I get an error that the permission is denied.
Is this because of the latest Domoticz package or since the Synology update to DSM 6.0?
Posted: Friday 03 June 2016 15:33
by mavl
I'm using the Domoticz-package on my Synology DS409 (DSM 6.0-7321 Update 6) and it's running very stable (version 2.0.2112-5). Last week I added Philips Hue to my hardware in Domoticz but it stops the Domoticz-package from running. As soon as I shutdown the Hue bridge, Domoticz is able to run again.
Anyone knows how to solve this?
Posted: Monday 06 June 2016 13:53
by mikl10
Hello community,
I have installed this package on my synology, but I have a problem of security with json request.
For connecting to domoticz' s dashboard, I have to connect with my user name and password but If I send commande json via http, I don't need to fill my user name and password.
Anybody know why?
Thank you
Posted: Monday 06 June 2016 17:16
by jumbotroll
Update.
Domoticz-6.0_3.0.5228-7
OpenZwave version 1.4.260
Tested on DSM Version: 6.0.1-7393.
http://www.jadahl.com/domoticz_beta_6/
Posted: Wednesday 08 June 2016 21:27
by gevegest
Hi Jumbotroll,
With the latest Domoticz beta for DSM 6.0 on my DS214+ (v3.0.5228-7), Domoticz slowly crashes over time. To have a more stable setup i would like to go back to the latest stable build v3.0.4834-7. However, this stable build is for DSM 5.2, is it possible to install this on DSM 6.0?
Thanks in advance.
Posted: Wednesday 08 June 2016 21:41
by jumbotroll
gevegest wrote:Hi Jumbotroll,
Thanks in advance.
I don't think DSM 5.2 stable will work on DSM 6.0.
I can compile v3.0.4834-7 for DSM 6.0 DS214+ (arch-armadaxp) if you want to test that?
Remember! you can NOT downgrade domoticz, you have to take backup of domoticz.db and reinstall the domoticz.spk.
Do you want to test this, then I can compile a package for you.
Posted: Monday 13 June 2016 16:54
by jumbotroll
Posted: Monday 13 June 2016 18:49
by Egregius
You must have lots of time to spent
Maybe consider some kind of donation possibillity? I would donate for your work just as I do for Domoticz
Posted: Monday 13 June 2016 19:04
by jumbotroll
Egregius wrote:You must have lots of time to spent
Yes, spent some time on this project, so I hope someone uses these packages too
BTW..Donation button is on my web page
Posted: Tuesday 14 June 2016 18:29
by jnoel68
Hi Jumbo,
any idea how to deploy the needed package for bluetooth / beacon solution described in this post ?
viewtopic.php?f=28&t=10640&p=88667&hili ... ogy#p88667
Thx
Jerome
Posted: Tuesday 14 June 2016 18:41
by Egregius
That's exactly what I mean. If you didn't say I probably never would get to your site. I would add that info to the Syno package.
Anyway, made a small donation, enjoy the beer you buy with it
Also donated again for the Domoticz team, more peable should do that. Many people don't understand what time you need to develop stuff like this.
Posted: Friday 17 June 2016 19:06
by deennoo
Facing a probleme using Domoticz on my Syno
DSM 6
Domoticz : 3.5242
Pushbullet Notification don't work anymore, message is : problem sending notification please check api key, i didn't remove the first one i get, i try creating a new one and proble is still here.
Does some one use pushbullet with is syno ? does it works ?
Édit : solve with last beta for ds216play
Posted: Tuesday 21 June 2016 21:37
by RogerSch
Great to see that for DSM 6.0 there is also a stable release. Currently my Synology is still 5.2 due to the stable release of Domoticz. Now I would like to know what is the easiest approach to upgrade DSM to 6.0 without complete re-install of Domoticz?
Posted: Tuesday 28 June 2016 10:08
by rgouyet
It looks that recently, the RFXCOM is no more working with the latests beta of Domoticz.
Version: 3.5271
Build Hash: 5b20c5b-modified
Compile Date: 2016-06-24 08:30:55
I get this error :
2016-06-28 10:00:13.352 Error: Serial Port closed!... Error: End of file
2016-06-28 10:00:14.901 RFXCOM: retrying in 30 seconds...
2016-06-28 10:00:18.728 Hardware Monitor: Fetching data (System sensors)
2016-06-28 10:00:33.932 Ending automatic database backup procedure...
2016-06-28 10:00:33.933 Error: RFXCOM hardware (13) nothing received for more then 10 Minutes!....
2016-06-28 10:00:34.934 Error: Restarting: RFXCOM
2016-06-28 10:00:35.903 RFXCOM: Serial Worker stopped...
2016-06-28 10:00:36.925 RFXCOM: Using serial port: /dev/ttyUSB1
2016-06-28 10:00:36.925 Error: Serial Port closed!... Error: End of file
2016-06-28 10:00:38.475 RFXCOM: retrying in 30 seconds...
2016-06-28 10:00:48.874 Hardware Monitor: Fetching data (System sensors)
2016-06-28 10:01:07.490 RFXCOM: Using serial port: /dev/ttyUSB1
2016-06-28 10:01:07.490 Error: Serial Port closed!... Error: End of file
2016-06-28 10:01:09.040 RFXCOM: retrying in 30 seconds...
2016-06-28 10:01:18.885 Hardware Monitor: Fetching data (System sensors)
2016-06-28 10:01:38.055 RFXCOM: Using serial port: /dev/ttyUSB1
2016-06-28 10:01:38.055 Error: Serial Port closed!... Error: End of file
RFXcom has 1005 firmware.
The rfxcom is working well on my windows PC.
Any idea ?
Posted: Tuesday 28 June 2016 10:26
by jumbotroll
rgouyet wrote:It looks that recently, the RFXCOM is no more working with the latests beta of Domoticz.
Version: 3.5271
I get this error :
Any idea ?
Reboot NAS with RFXcom plugged in.
Posted: Tuesday 28 June 2016 11:19
by rgouyet
Thanks.
I downgrade the firmware to 250 and reboot the synology.
Now, it looks OK... Will try to update the RFXCOM firmware again later.
