domoticz in synology as package! Available now.
Eternity
Re: domoticz in synology as package! Available now.
Post by Eternity »
Will try this weekend. Thank you !
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
iAmRenzo
Post by iAmRenzo »
I added the regular beta repo, and updated to 3.0.5070-7.
Then I saw the DSM6 beta repo, added that one but no updated is pushed. Nor can I force a reinstallation.
So I still cannot start the service, it will be stopped automatically. What to do?
franzelare
Post by franzelare »
since the last domoticz update domoticz is crashing all the time on my NAS, pushing to many switches in a short period makes it crash...
my mochad driver is now crashing once every other day or so...
all in all I decided to go back to raspberry pi since that has been running stable for a long time without any issues and the synology version gives me nothing but work to keep it up and running...
Egregius
Domoticz version: v2024.7
Post by Egregius »
franzelare wrote:pushing to many switches in a short period makes it crash...
I noticed that also.
In my script I use a 0,8sec delay between switches. If not I receive errors concerning not able to write to serial port or something.
jberinga
Domoticz version: 2024.7
Post by jberinga »
When deleting or editing\saving LUA scripts I get an error that the permission is denied.
Is this because of the latest Domoticz package or since the Synology update to DSM 6.0?
mavl
Post by mavl »
I'm using the Domoticz-package on my Synology DS409 (DSM 6.0-7321 Update 6) and it's running very stable (version 2.0.2112-5). Last week I added Philips Hue to my hardware in Domoticz but it stops the Domoticz-package from running. As soon as I shutdown the Hue bridge, Domoticz is able to run again.
Anyone knows how to solve this?
mikl10
Post by mikl10 »
Hello community,
I have installed this package on my synology, but I have a problem of security with json request.
For connecting to domoticz' s dashboard, I have to connect with my user name and password but If I send commande json via http, I don't need to fill my user name and password.
Anybody know why?
Thank you
jumbotroll
Post by jumbotroll »
Update.
Domoticz-6.0_3.0.5228-7
OpenZwave version 1.4.260
Tested on DSM Version: 6.0.1-7393.
http://www.jadahl.com/domoticz_beta_6/
https://paypal.me/Jumbotroll
Jumbotroll
gevegest
Post by gevegest »
Hi Jumbotroll,
With the latest Domoticz beta for DSM 6.0 on my DS214+ (v3.0.5228-7), Domoticz slowly crashes over time. To have a more stable setup i would like to go back to the latest stable build v3.0.4834-7. However, this stable build is for DSM 5.2, is it possible to install this on DSM 6.0?
Thanks in advance.
jumbotroll
gevegest wrote:Hi Jumbotroll,
Thanks in advance.
I don't think DSM 5.2 stable will work on DSM 6.0.
I can compile v3.0.4834-7 for DSM 6.0 DS214+ (arch-armadaxp) if you want to test that?
Remember! you can NOT downgrade domoticz, you have to take backup of domoticz.db and reinstall the domoticz.spk.
Do you want to test this, then I can compile a package for you.
Jumbotroll
jumbotroll
Jumbotroll
Egregius
Post by Egregius »
You must have lots of time to spent :P
Maybe consider some kind of donation possibillity? I would donate for your work just as I do for Domoticz ;)
jumbotroll
Egregius wrote:You must have lots of time to spent :P
Yes, spent some time on this project, so I hope someone uses these packages too :?:
BTW..Donation button is on my web page :D
Jumbotroll
jnoel68
Post by jnoel68 »
Hi Jumbo,
any idea how to deploy the needed package for bluetooth / beacon solution described in this post ? viewtopic.php?f=28&t=10640&p=88667&hili ... ogy#p88667
Thx
Jerome
Egregius
Post by Egregius »
jumbotroll wrote: Yes, spent some time on this project, so I hope someone uses these packages too :?:
That's exactly what I mean. If you didn't say I probably never would get to your site. I would add that info to the Syno package.
Anyway, made a small donation, enjoy the beer you buy with it ;)
Also donated again for the Domoticz team, more peable should do that. Many people don't understand what time you need to develop stuff like this.
deennoo
Post by deennoo »
Facing a probleme using Domoticz on my Syno
DSM 6
Domoticz : 3.5242
Pushbullet Notification don't work anymore, message is : problem sending notification please check api key, i didn't remove the first one i get, i try creating a new one and proble is still here.
Does some one use pushbullet with is syno ? does it works ?
Édit : solve with last beta for ds216play
http://domo-attitude.fr
RogerSch
Post by RogerSch »
Great to see that for DSM 6.0 there is also a stable release. Currently my Synology is still 5.2 due to the stable release of Domoticz. Now I would like to know what is the easiest approach to upgrade DSM to 6.0 without complete re-install of Domoticz?
rgouyet
Post by rgouyet »
It looks that recently, the RFXCOM is no more working with the latests beta of Domoticz.
Version: 3.5271
Build Hash: 5b20c5b-modified
Compile Date: 2016-06-24 08:30:55
I get this error :
2016-06-28 10:00:13.352 Error: Serial Port closed!... Error: End of file
2016-06-28 10:00:14.901 RFXCOM: retrying in 30 seconds...
2016-06-28 10:00:18.728 Hardware Monitor: Fetching data (System sensors)
2016-06-28 10:00:33.932 Ending automatic database backup procedure...
2016-06-28 10:00:33.933 Error: RFXCOM hardware (13) nothing received for more then 10 Minutes!....
2016-06-28 10:00:34.934 Error: Restarting: RFXCOM
2016-06-28 10:00:35.903 RFXCOM: Serial Worker stopped...
2016-06-28 10:00:36.925 RFXCOM: Using serial port: /dev/ttyUSB1
2016-06-28 10:00:36.925 Error: Serial Port closed!... Error: End of file
2016-06-28 10:00:38.475 RFXCOM: retrying in 30 seconds...
2016-06-28 10:00:48.874 Hardware Monitor: Fetching data (System sensors)
2016-06-28 10:01:07.490 RFXCOM: Using serial port: /dev/ttyUSB1
2016-06-28 10:01:07.490 Error: Serial Port closed!... Error: End of file
2016-06-28 10:01:09.040 RFXCOM: retrying in 30 seconds...
2016-06-28 10:01:18.885 Hardware Monitor: Fetching data (System sensors)
2016-06-28 10:01:38.055 RFXCOM: Using serial port: /dev/ttyUSB1
2016-06-28 10:01:38.055 Error: Serial Port closed!... Error: End of file
RFXcom has 1005 firmware.
The rfxcom is working well on my windows PC.
Any idea ?
jumbotroll
rgouyet wrote:It looks that recently, the RFXCOM is no more working with the latests beta of Domoticz.
Version: 3.5271
I get this error :
Any idea ?
Reboot NAS with RFXcom plugged in.
Jumbotroll
rgouyet
Post by rgouyet »
Thanks.
I downgrade the firmware to 250 and reboot the synology.
Now, it looks OK... Will try to update the RFXCOM firmware again later.
