Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
peteralm
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by peteralm »
So, I have just taken the plunge to properly understand this and get it working and unlinked the LightwaveRF app from Google Assistant...
I am trying to understand;
Lights with dimmers = Lightbulb
Lights without dimmers = Generic
Other devices (like a TV connected to a plugin socket switch) = TV or other image
So, when I say "Brighten the lights" the dimmers will increase but the lights plugged into plugin socket switch will not
When I say "Switch of all the lights" the dimmers and the generic plugin sockets will switch off but NOT the TV plugin socket
When I say "switch off everything" everything gets switched off...
Is there no chance that you could read the switch type field in domoticz rather that reply upon the image - I have the floor plan and would rather all the lights were lights and not switches (which I suppose they actually are).
Am I on the right tracks?
Also - whilst I am thinking about things - now that GH recognises different voices, the ability to link more than 1 google account to the same settings would be great. This way I dont have to go through the same set-up with the wife!
heggink
Domoticz version: 12451
Post by heggink »
Madgeni wrote:Hi heggink -
i find unlinking, then relinking works :)
Ok.. How do I do that? Image
DASHTICZ 🙃
P1 meter & solar panel
Madgeni
Post by Madgeni »
peteralm wrote: Monday 22 January 2018 22:17 So, I have just taken the plunge to properly understand this and get it working and unlinked the LightwaveRF app from Google Assistant...
Hi -
What i've tried to do, is to take the very disparate set of hardware challenges that Domoticz handles, and filter that down to basically the two options Google (or Alexa) give me - Lights, or switches. Lots of switches, and hardware types use the device.type = 'light'.
Now, a wall socket, is a switch, not a light - it may drive a light, it may drive a TV etc etc. So if you want it to be treated as a light, change the image to a bulb, if you want it to be a switch, then the 'generic' image is the right choice.
Google adds some natural language processing, so if it recognises something as a light, and you put a bunch of them in a room, with some switches, you can say "turn off the lights in the room" and it will turn off lights, but not switches.
Madgeni
Post by Madgeni »
heggink wrote: Monday 22 January 2018 22:43
um, settings - Home Control - accounts, unlink Home Controlicz, then you can relink it (off the top of my head)
jeeps13
Post by jeeps13 »
I'm unable to control Set Poit Thermostat. It was working fine till last week. Now I just get an error, all lights and Temperature work.
Fred78
Post by Fred78 »
Madgeni wrote: Monday 22 January 2018 21:29 Can you try typing it? I wonder if it's not liking the , - I know it should, as that's the european decimal, but can you try 19.5 instead?
Also, humidity now works :) "What is the humidity of <device>"
Whether I say comma or point, Google translates as a comma. And he triggers a search.
But you're right, if I type the request with a point, then it works... So... Google bug...
Do you know if there is a place to report such bugs to Google?
Madgeni
Post by Madgeni »
Fred78 wrote: Tuesday 23 January 2018 9:16
raised here:
https://github.com/actions-on-google/ac ... /issues/88
Madgeni
Post by Madgeni »
jeeps13 wrote: Tuesday 23 January 2018 3:57 I'm unable to control Set Poit Thermostat. It was working fine till last week. Now I just get an error, all lights and Temperature work.
will fix this today - can you give me your email address in PM?
Fred78
Post by Fred78 »
Madgeni wrote: Tuesday 23 January 2018 9:53
raised here:
Great! Thanks!
Madgeni
Post by Madgeni »
re: decimal rounding - Google say:
"Assistant may round the number to give a better conversational answer. Saying a long decimal may not make sense. However in Celcius having some extra precision may be useful."
ricou0601
Domoticz version: 3.8834
Post by ricou0601 »
I can't manage to have my devices list in Google Assistant. Everytime I add [test] home Controlicz service and allow Google to access my account, it seems to work until the step "Room Management" , I'm redirect to the services list with a message "account liked" but my devices list is empty and service is not linked.
On controlicz.com, test button says "Controlicz can connect to tour Domoticz!"
On Google Action, my versio is "AoG Draft Snapshot - 1/23/18"
I tried :
To change Google Action version
To disable / enable Google Action
To create an user with limited devices authorization
To change language (i'm french)
To clear application cache
To update domoticz on the last beta
on an other device
I don(t know what to do next. Any ideas ?
Madgeni
Post by Madgeni »
ricou0601 wrote: Tuesday 23 January 2018 12:32 Hi,
Hi - can you change this to the one marked 'Under Review'?
ricou0601
Post by ricou0601 »
Done, but no changes :(
I tried every version but I've got the same result.
Update : I've just notice that when I change version for on review I'm on AoG V2 Snapshot - 1/23/18, 12:42 PM
Madgeni
Post by Madgeni »
Do you have devices in at least one room plan in Domoticz?
ricou0601
Post by ricou0601 »
No. I just add some devices and it works !!
Thanks a lot !
Lizard
Post by Lizard »
Hi Madgeni,
I tried to register with my email, Which seems to have worked, since I got a confirmation email. But on every link I click I get a htaccess password popup? Could it be caused because I don't use a normal gmail account but a google for domains email?
Madgeni
Post by Madgeni »
that shouldn't be an issue? i've got lots of users with non gmail accounts.
which link is causing the issue, the Simulation link?
Lizard
Post by Lizard »
I get the popup on almost every button I click.
'Test Domoticz' -> popup
Update profile -> profile opens but when I click the submit button -> popup
'Signup for Google Home' -> js popup with email sent after that popup
'Delete User' -> popup
This happens in Firefox and Chrome on Win 10 64bit.
Madgeni
Post by Madgeni »
ok, i've not heard anyone raise this, and i've just tested and logged into Controlicz ok :(
Lizard
Post by Lizard »
What happens when you create a new test user?
