Heatit Z-wave thermostat
stephanvdplas
Domoticz version: 2023.1
Re: Heatit Z-wave thermostat
Post by stephanvdplas »
madpatrick wrote: Wednesday 20 December 2023 20:32
stephanvdplas wrote: Wednesday 20 December 2023 20:11 Alas... one step further, but not yet there.
This parameter 9 (Heating setpoint) now works. I can read and set the setpoint and it actually sets it on the thermostat.
The devices that are created are shown here:
There is one setpoint, but it does not reflect the current setting. It also doesn't work setting the thermostat.
How can I create a device for the parameter 9 value?
Your device 2042 should work and change the setpoint.
Have you checked your firmware?
There is a known issue with setting the setpoint with the default firmware
Try to set your setpoint to > 26,5 C.
If this is working then the problem is with firmware.
With help of Heatit support (they delivered me a new OTA update file) I have been able to update the firmware. Now the setpoint device is no longer created when (re-)including the device:
What is going wrong?
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
stephanvdplas
I reversed engineered it by using the browser development tools - network console. Though it is not the most beautiful solution, it works. I now have a device (on/off) for the heating and use an external thermometer and other triggers to turn it on or off.
stelling
Post by stelling »
Since two weeks the actual power usage of my Heat-IT thermostat is not reported in Domoticz anymore. Before that it worked fine. The power used is working fine.
- I have already removed the device and added it again. No improvement
- I have checked Z-wave JS UI and it is visible in there
- I'm running the beta version.
Does anybody has a suggestion how I can solve this?
