With help of Heatit support (they delivered me a new OTA update file) I have been able to update the firmware. Now the setpoint device is no longer created when (re-)including the device:madpatrick wrote: Wednesday 20 December 2023 20:32Your device 2042 should work and change the setpoint.stephanvdplas wrote: Wednesday 20 December 2023 20:11 Alas... one step further, but not yet there.
This parameter 9 (Heating setpoint) now works. I can read and set the setpoint and it actually sets it on the thermostat.
The devices that are created are shown here:
There is one setpoint, but it does not reflect the current setting. It also doesn't work setting the thermostat.
How can I create a device for the parameter 9 value?
Have you checked your firmware?
There is a known issue with setting the setpoint with the default firmware
Try to set your setpoint to > 26,5 C.
If this is working then the problem is with firmware.
What is going wrong?
