Page 5 of 6
Re: New Aeon Labs Multisensor Gen5 not supported in OpenZwav
Posted: Saturday 09 May 2015 15:46
by Doume
OK, thanks, I'll try soon
Posted: Saturday 09 May 2015 15:59
by Plaagje
Gettingthere wrote:Just wondering... How did ye include yer sensor? Because I see your hardware is yer Motherboard, and mine is my Z-Stick. Also I don't recognize the 'burglar' switch...
I added the line to the xml file as IDavid stated.
Then i entered inclusion mode:
and pressed the button on the Aeon 3 times.
Now i have the following devices:
Posted: Saturday 09 May 2015 17:36
by TheSpanishInq
gizmocuz wrote:latest beta is using the security branch now, hope its working
Seems to work with 2418 as well, with the security branch I pulled from OZW.
Good to see it's in Domoticz native though, so I can skip a few copy/edit statements with future updates.
I'm a but confused about the device-list though. Device #31 (in my setup) seems to be the viable motion sensor. I'd already renamed it so I don't know what name it had when it was detected. Device #29 and #30 get updated too and #32 seems to remain ON. Device #21 showed up when I pressed the include button on the multisensor but doesn't seem to get updates thereafter.
Is this by design or do I need to upgrade to latest trunk to get it wright?
New Aeon Labs Multisensor Gen5 not supported in OpenZwave ?
Posted: Saturday 09 May 2015 17:43
by gizmocuz
Nothing changed besides the security branch.... Something not working anymore?
Posted: Saturday 09 May 2015 17:49
by TheSpanishInq
It does seem to work OK, I just found it odd that the device IDs I mentioned show up and don't get any update (not seen in Domoticz thereafter) or remain ON or OFF all the time. Wondered if that is by design with this multisensor.
Posted: Sunday 10 May 2015 12:51
by gizmocuz
Unfortunately i do not know this sensor, but can you tell if you receive all possible sensors from it, and that they are updating?
(could be some time before some of them update , this so the battery lasts 2 years)
- PIR
- Temp
- Humidity
- Light
Posted: Sunday 10 May 2015 15:57
by Doume
Doume wrote:OK, thanks, I'll try soon
Just updated to version 2427 :
Now, the Zwave network seems to be handled in a better way (it doesn't stay anymore in 'red' state )
The Siren Aeon G5 seems to be 'seen' correctly (The 'panic' state has been resetted) , but I can't modify the specific parameters of the siren ( volume, sound type, and so on)
A big step forward, for sure....
Posted: Sunday 10 May 2015 18:42
by TheSpanishInq
gizmocuz wrote:
- PIR
- Temp
- Humidity
- Light
I do have those, which get regular updates. The sensor is receiving power from mains via an USB-power-adapter and I've setup the sensor to send updates every 5 minutes. The PIR sends an ON when it is off and montion is detected and sends an OFF when it was on and hasn't seen motion within the timeout that's set for that (240 seconds).
Besides these devices OZW sees several other devices that I don't know off. Two literally are called 'Unknown', another 'Level', with a green arrow behind them indicating I can add them to Domoticz.
They are shown in the screenshot I posted
above too (IDs 21, 27 and 35). The ones that get updated regularly have the time stamp highlighted.
The device with ID 31 still is ON (and gets updated), but I've no what it's for either.
Posted: Saturday 22 August 2015 19:50
by cpighin
I tried to include my new Aeotec Multisensor6 ZW100-C and the result is showed here
You may see that the sensor seems not to be correctly included since Domoticz (V2.2563) considers it as "
Aeotec Unknown: type=0002, id=0064".
What should I do?
Claudio
Posted: Sunday 23 August 2015 17:48
by TheSpanishInq
You'll probably have to
upgrade Domoticz
Support for the sensor is in the more recent versions. Dunno if it is in the beta binary for RPi.
Posted: Sunday 23 August 2015 21:20
by cpighin
I'm running Domoticz (V2.2563) and I cheched file /home/pi/domoticz/Config/manufacturer_specific.xml and I have found following line inside the "<Manufacturer id="0086" name="Aeotec">" part
<Product type="0002" id="004a" name="Multi Sensor Gen5" config="aeotec/multisensor_gen5.xml"/>
and in /home/pi/domoticz/Config/aeotec I see file
Claudio
Posted: Tuesday 25 August 2015 9:50
by cpighin
May anyone give any tip to correctly install new New Aeon Labs Multisensor Gen5?
Claudio
Posted: Tuesday 25 August 2015 21:59
by TheSpanishInq
You mentioned you have a Multisensor 6. In my manufacturer_specific.xml this show up:
<Product type="0002" id="0064" name="MultiSensor 6" config="aeotec/multisensor6.xml" />
<Product type="0102" id="0064" name="MultiSensor 6" config="aeotec/multisensor6.xml" />
<Product type="0202" id="0064" name="MultiSensor 6" config="aeotec/multisensor6.xml" />
First line seems to match... I guess you'll have to upgrade Domoticz.
Posted: Wednesday 26 August 2015 5:50
by cpighin
I'm running Domoticz (V2.2563) which is te last one
Claudio
Posted: Wednesday 26 August 2015 17:50
by TheSpanishInq
That's probably the latest stable. If you want Domoticz support for your sensor you'll have to compile the latest beta your self/use the latest beta binary. It's described in the
wiki.
Posted: Saturday 29 August 2015 19:15
by cpighin
I did few trials to overcome the issue but I had no success.
Among the various actions done I mention the repeated exclusions from the system of
Aeotec Multisensor6 ZW100-C, that from now on I will call
MultisensorGen5, followed by three inclusions.
Domoticz has never recognized properly MultisensorGen5 and has always included as "
Unknown Aeotec: type = 0002, id = 0064" even if in file was /home/pi/domoticz/Config/
manufacturer_specific.xml I found the following line in the "<Manufacturer id =" 0086 "name =" Aeotec ">"
and in /home/pi/domoticz/Config/aeotec file multisensor_gen5.xml was there.
It may perhaps be useful to inform that as a result of the three inclusions, Domoticz generated
8 devices in the first,
5 devices in the second,
7 devices in the third.
(if useful I can report on the various devices generated)
My understanding is that even if Domoticz has good data to use, it did not do as supposed. Why?
Is there a possibility to force Domoticz to use the right file to configure the MultisensorGen5?
Claudio
Posted: Saturday 29 August 2015 22:26
by TheSpanishInq
Are you sure? id=004a != id=0064...
Upgrade?
You could try to pull the specific config files from OZW-git. See if that 'll suffice.
Posted: Tuesday 01 September 2015 9:11
by cpighin
Any help to include correctly a Multisensor Gen5 on Domoticz?
Claudio
Posted: Wednesday 02 September 2015 14:18
by TheSpanishInq
Nope, not anymore. You don't seem to like my suggestions. Waste of time.
Posted: Wednesday 02 September 2015 20:54
by pvm
what about making an image of your current install. Switch Domoticz to beta channel,update , exclude, and include again. Latest gen5 can require latest openzwave lib.
When this does not work, restore the original image
