Page 5 of 8
Re: Is it possible to add Shelly 2PM GEN 3 to Domoticz?
Posted: Wednesday 14 May 2025 18:47
by Daro1003
Could you remove the "Function" node, called "Blinds + Percentage" and replace it with this new "Function" node?
And test again and let me know.
Now everything works fine :) Great
So, if this works, can you show me the debug output of the following flow, in all positions )Open. Close and a slider position)
Then I can implement that.
I added this flow in a new flow, I don't know if it's good but I think it's ok:
Data:
CLOSED:
OPEN:
15%:
I have a question:
How can I copy this working flow now and save it somewhere on the disk, even in the form of the code you are sending me? I would like to have a ready code to import for the next shelly gen 3
Posted: Thursday 15 May 2025 22:06
by FireWizard
Hello @Daro1003,
I have created a flow for the Shelly to Domoticz.
It should update the Domoticz widget only. So it does not activate any actions, that you might have configured for the Switch.
See:
        "id": "3be52bd193485cf4",
        "type": "function",
        "z": "589aa1f8113f3797",
        "name": "Control Domoticz Switch",
        "func": "let clientId = msg.topic. split (\"/\")[0];\n\nfor (let i = 0; i < flow.keys().length; i++) {\n\n    if (clientId === flow.get(flow.keys()[i])) {\n\n        let idx = parseInt(flow.keys()[i].substring(3));\n\n//        msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 2, \"svalue\": msg.payload.current_pos }\n\n        if (msg.payload.current_pos === 100) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 0, \"svalue\": \"0\" }\n        }\n\n        if (msg.payload.current_pos === 0) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 1, \"svalue\": \"100\" }\n        }\n\n        if ((msg.payload.current_pos > 0) && (msg.payload.current_pos < 100)) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 2, \"svalue\": msg.payload.current_pos.toString() }\n        }\n        return msg\n    }\n}\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 450,
        "y": 520,
        "wires": [
                "6b107f279c3940b6",
                "ad6d65a29fe88f81"
        "id": "6b107f279c3940b6",
        "type": "debug",
        "name": "debug 34",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 700,
        "y": 580,
        "wires": []
        "id": "3b439aac5f94e681",
        "type": "debug",
        "name": "debug 35",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 400,
        "y": 580,
        "wires": []
        "id": "ad6d65a29fe88f81",
        "type": "mqtt out",
        "name": "Domoticz In",
        "topic": "domoticz/in",
        "qos": "1",
        "retain": "false",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "38b35487299a036d",
        "x": 710,
        "y": 520,
        "wires": []
        "id": "ce1c7ba4d1dbea73",
        "type": "mqtt in",
        "name": "Shelly Cover Status In",
        "topic": "shelly2pmg3-34cdb0774d4c/status/cover:0",
        "qos": "1",
        "datatype": "auto-detect",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 180,
        "y": 520,
        "wires": [
                "3be52bd193485cf4",
                "3b439aac5f94e681"
        "id": "8fc9517938bfac09",
        "type": "comment",
        "name": "Shelly  ====> Domotcz Switch",
        "info": "",
        "x": 540,
        "y": 460,
        "wires": []
        "id": "38b35487299a036d",
        "type": "mqtt-broker",
        "name": "Raspberry Pi 1",
        "broker": "192.168.10.51",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
The only thing you have to do is to configure your own MQTT Settings
Can you test with your wall switch, that the indication on the widget is correct. And let me know.
You asked also:
I have a question:
How can I copy this working flow now and save it somewhere on the disk, even in the form of the code you are sending me? I would like to have a ready code to import for the next Shelly gen 3
Do it as follows:
1. Go to the "Hamburger" menu at the top right.
2. Select "Export".
3. You see the nodes, you are about to export. Select "Local".
4. In the field "Export as" give it any name you want, e.g. flows.shelly_2pmgen3 or whatever and you have saved it.
To retrieve them:
2. Select "Import".
3. Select "Local".
4. You see the flow with the name, you have saved it, e.g. flows.shelly_2pmgen3.
5. Select that file and press "Import¨
And you are done.
Posted: Friday 16 May 2025 7:15
by Daro1003
I improvised the flow - there is an immediate connection.
Unfortunately, when I click the switch on the wall it does not change the state of the switch in Domoticz.
After importing - I didn't change anything.
Where should I insert the Domoticz switch IDX?
Where do I insert the shelly ID?
Posted: Friday 16 May 2025 9:33
by FireWizard
Hello @Daro1003,
What do you see in the Debug nodes?
Then it should be connected to your MQTT broker.
Okay
This is already done.
Do you run this flow in the same tab as the flow from Domoticz to Shelly?
Posted: Friday 16 May 2025 13:41
by Daro1003
Debug nodes after pressing the key are active.
Slider in domoticz NO.
YES.
Posted: Friday 16 May 2025 16:03
by FireWizard
Hello @Daro1003,
It is clear for me, why you don't see anything.
You still use my index number (12). See "Debug" node idx:12.
It is very unlikely that your Domoticz Switch (Blinds + Percentage) has also the Idx 12.
In my post, dated 12 May 2025, 18:46 , I wrote:
1. In the first stream, you have to configure the relationship between the Domoticz Switch index and the Shelly Client ID.
Open that "Change" node and edit the fields. a description is included in the "Comment" node, called "Configuration"
This has to done once for all "Blinds Percentage" Switches.
Did you ever do that? I don't think so.
If you follow the guideline in the "Comment" node, it should work.
It is very simple. Change IDX12 to IDXxxx, where xxx is the IDX number of your Domoticz switch.
Try it,
Posted: Friday 16 May 2025 16:07
by Daro1003
YES - s this the node:
My shelly switch idx is 1060
I have changed it.
Posted: Friday 16 May 2025 17:01
by FireWizard
Hi @Dare1003,
Yes, that is the one, that I mean.
Check it.
I have changed it.
And does it work now?
Posted: Friday 16 May 2025 17:52
by Daro1003
As the screen has, I had it set to my own id 1060 from the moment you sent this flow.
Currently, the slider from the local key does not work.
NO
Posted: Friday 16 May 2025 19:02
by FireWizard
Hi, @Daro1003,
And the other way around, from Domoticz to Shelly
Posted: Friday 16 May 2025 20:18
by Daro1003
I don't understand.
Where else should I check the settings - change
Posted: Saturday 17 May 2025 9:45
by FireWizard
Hello @Daro1003,
I don't understand
I mean, if you push the button in Domoticz or move the slider, does the the Shelly still react?
The only setting, you have to make is the Change node and that is okay, as you showed me
Posted: Saturday 17 May 2025 10:18
by Daro1003
I change this setting and it still doesn't work.
YES
This is how the roller blind reacts and works.
Look:
Interestingly:
1. It gives an export of the entire flow:
        "id": "42ee6529ee50e2d7",
        "type": "tab",
        "label": "Shelly 2PM Gen 3",
        "disabled": false,
        "info": "",
        "env": []
        "id": "e4fb67a1676b6fbc",
        "type": "change",
        "z": "42ee6529ee50e2d7",
        "name": "Set Domoticz IDX ",
        "rules": [
                "t": "set",
                "p": "IDX1060",
                "pt": "flow",
                "to": "shelly2pmg3-34cdb0774d4c",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 510,
        "y": 160,
        "wires": [
        "id": "c7de321d99fcf212",
        "type": "inject",
        "name": "Inject Domoticz IDX",
        "props": [],
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "x": 260,
        "y": 160,
        "wires": [
                "e4fb67a1676b6fbc"
        "id": "f75f4261a70c5c06",
        "type": "comment",
        "name": "Configuration",
        "info": "Insert the Domoticz Idx of the \nBlinds Percentage Switch in the field\nflow, starting with IDX.\n\nExample: The Domoticz Idx number = 12.\nFlow variable is IDX12.\n\nInsert the Shelly Client IDX\nas string after \"to the value\".\n\nExample: shelly2pmg3-34cdb0774d4c",
        "x": 490,
        "y": 100,
        "wires": []
        "id": "9ad8dad88fdcd9ef",
        "type": "mqtt in",
        "name": "Domoticz Out",
        "topic": "domoticz/out",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 210,
        "y": 380,
        "wires": [
                "d82c121e2b5d39f9"
        "id": "d82c121e2b5d39f9",
        "type": "switch",
        "name": "Filter Domoticz switchType",
        "property": "payload.switchType",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "Blinds Percentage",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 460,
        "y": 380,
        "wires": [
                "75bd2171da300327",
                "9e0b171deaf56eae"
        "id": "86ebb137bda2e7e8",
        "type": "debug",
        "name": "debug 27",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 960,
        "y": 340,
        "wires": []
        "id": "0ca516e44f5f4ef9",
        "type": "mqtt out",
        "name": "Shelly Cover Command Out",
        "topic": "",
        "qos": "1",
        "retain": "false",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "7aff5cd755ba2941",
        "x": 1020,
        "y": 380,
        "wires": []
        "id": "75bd2171da300327",
        "type": "debug",
        "name": "debug 33",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 700,
        "y": 340,
        "wires": []
        "id": "b6797b827d56bdb6",
        "type": "comment",
        "name": " Domotcz Switch ====> Shelly",
        "info": "",
        "x": 540,
        "y": 260,
        "wires": []
        "id": "8027b04f8a7b2b31",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 590,
        "y": 580,
        "wires": [
                "7c55fef71ce86a9d",
                "25ecbf3343c343d0"
        "id": "7c55fef71ce86a9d",
        "type": "debug",
        "name": "debug 34",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 840,
        "y": 640,
        "wires": []
        "id": "ab9f88e4ce77f221",
        "type": "debug",
        "name": "debug 35",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 540,
        "y": 640,
        "wires": []
        "id": "25ecbf3343c343d0",
        "type": "mqtt out",
        "qos": "1",
        "retain": "false",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 850,
        "y": 580,
        "wires": []
        "id": "f7240543f683a8f2",
        "type": "mqtt in",
        "qos": "1",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 320,
        "y": 580,
        "wires": [
                "8027b04f8a7b2b31",
                "ab9f88e4ce77f221"
        "id": "50be06b3fc0c2c00",
        "type": "comment",
        "info": "",
        "x": 680,
        "y": 520,
        "wires": []
        "id": "9e0b171deaf56eae",
        "type": "function",
        "name": "Blinds + Percentage ",
        "func": "// Function Blinds and Percentage\n\nmsg.topic = flow.get (\"IDX\" + msg.payload.idx.toString()) + \"/command/cover:0\";\nmsg.idx = msg.payload.idx;\n\n//Closed\nif (msg.payload.nvalue === 0) { msg.payload = \"close\" };\n\n//Open\nif (msg.payload.nvalue === 1) { msg.payload = \"open\" };\n\n//Percentage\nif (msg.payload.nvalue === 2) { msg.payload = \"pos,\" + msg.payload.Level.toString() };\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 380,
        "wires": [
                "0ca516e44f5f4ef9",
                "86ebb137bda2e7e8"
        "broker": "192.168.0.40",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "7aff5cd755ba2941",
        "name": "Shelly",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
As you can see, the IDX is already correct
2. I import and paste the code
3.
The % indicator works after using the button on the wall - great
Raising and lowering with buttons in domoticz works - Correct operation
The slider in domoticz works. Sets the blind in the appropriate position - Correct operation
Problem:
The indication of the open and closed position of the roller shutter is incorrect:
The inscription indicates the shutter is closed, while the shutter is open.
The slider indicates the shutter is closed, while the shutter is open.
Replacing the node function: "Blinds + Percentage" - nothing helps.
I think you're close to getting this flow going.
Posted: Saturday 17 May 2025 14:34
by FireWizard
Hello @daro1003,
You wrote:
YES
Okay
Look:
Interestingly:
Yes, that is also the intention, but click on "Local".
2. Select "Export".
See point 3: Select "Local"
Problem:
Please can you replace the node, called "Control Domoticz Switch", with the following node.
        "type": "function",
        "func": "let clientId = msg.topic. split (\"/\")[0];\n\nfor (let i = 0; i < flow.keys().length; i++) {\n\n    if (clientId === flow.get(flow.keys()[i])) {\n\n        let idx = parseInt(flow.keys()[i].substring(3));\n\n        //Open (for Reversed Position)\n        if (msg.payload.current_pos === 0) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 1, \"svalue\": \"100\" }\n        }\n\n        //Closed (for Reversed Position)\n        if (msg.payload.current_pos === 100) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 0, \"svalue\": \"0\" }\n        }\n\n        //Percentage (for Reversed Position)\n        if ((msg.payload.current_pos > 0) && (msg.payload.current_pos < 100)) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 2, \"svalue\": msg.payload.current_pos.toString() }\n        }\n        return msg\n    }\n}\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 450,
        "y": 520,
        "wires": [
                "6b107f279c3940b6",
                "ad6d65a29fe88f81"
I think it should work.
Test it and let me know.
Posted: Saturday 17 May 2025 14:37
by Daro1003
YES
I replaced the node - unfortunately it did not help, it still works the same.
Posted: Saturday 17 May 2025 15:54
by FireWizard
Hello @Daro1003,
Then try this new "Function" node.
        "type": "function",
        "func": "let clientId = msg.topic. split (\"/\")[0];\n\nfor (let i = 0; i < flow.keys().length; i++) {\n\n    if (clientId === flow.get(flow.keys()[i])) {\n\n        let idx = parseInt(flow.keys()[i].substring(3));\n\n        //Open (for Reversed Position)\n        if (msg.payload.current_pos === 100) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 1, \"svalue\": \"100\" }\n        }\n\n        //Closed (for Reversed Position)\n        if (msg.payload.current_pos === 0) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 0, \"svalue\": \"0\" }\n        }\n\n        //Percentage (for Reversed Position)\n        if ((msg.payload.current_pos > 0) && (msg.payload.current_pos < 100)) {\n            msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 2, \"svalue\": msg.payload.current_pos.toString() }\n        }\n        return msg\n    }\n}\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 450,
        "y": 520,
        "wires": [
                "6b107f279c3940b6",
                "ad6d65a29fe88f81"
Let me know
Posted: Saturday 17 May 2025 16:34
by Daro1003
Działa odpowiednio cały przepływ.
Dziękuję za dużo pracę jaką włożyłeś w uruchomienie tej integracji.
I understand that for the next shelly driver I change the IDX and shelly ID as in the picture.
W nowym przepływie zmieniamy IDX i ID shelly.png (32.01 KiB) Viewed 2189 times
Posted: Saturday 17 May 2025 16:49
by Daro1003
Question:
Would you have the time and desire to fight with the roller shutter controller on Tasmota?
I have one in stock for testing.
It is half the price of shelly and may be less prone to failures.
I would like to test it and try to run it in domoticz. Unfortunately, integration via the Tasmoticz plugin does not work.
https://nous.technology/product/b3t.html
https://nous.technology/product/manual? ... s%C5%82ugi
Posted: Saturday 17 May 2025 19:56
by FireWizard
Hello @Daro1003,
I understand, no Google understands, that:
means
The entire flow works properly.
Thank you for the great work you put into getting this integration up and running.
Thank you and that's fine for me.
You should do the following
Remove the "Debug" nodes, if you are satisfied with the final result.
Or if you want them to stay on the canvas, disable them, by clicking the right button
NO, ABSOLUTELY NOT
Never edit the visible text in the import or export function.
Work only on the canvas.
If you want to add another Shelly 2PM Gen 3 to the system, do the following
In Domoticz:
1. Create a new virtual Switch in Domoticz.
2. Configure this Switch as "Blinds Percentage" and tick the box "Reverse position"
3. Note its IDX number ( perhaps 1061 ???)
In Node-RED
1. Open the "Change" node, called "Set Domoticz IDX", by double clicking.
2. Click the +add button and another field will be added.
3. Add the Domoticz IDX and the Shelly ClientID in the same way as the first item in the node.
4, Deploy
6. Activate the "Inject" node.
That's all and then the new Shelly should work
You asked also in another post:
I have never used a Tasmota flashed device and so I have zero experience with it. Could be a challenge, but
I suggest that a more experienced user support you.
Question for you too,
For the Shelly, do you want more data in Domoticz, such as:
1. Power/Energy consumption
2. Temperature
Let me know.
Have a good weekend and Regards
Posted: Saturday 17 May 2025 20:11
by Daro1003
NO
2. Temperature
YES
In Node-RED
I don't know how to do it ;/ Can you upload a screenshot?
