Easiest way to migrate Openzwave to ZWave-JS-UI
- Egregius
- Domoticz version: v2024.7
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
And also for MQTT and Gateway?
- Domoticz version: 2025.1
I have already updated the Wiki with help of your comments.
https://www.domoticz.com/wiki/Zwave-JS- ... n_Domoticz
mgugu
Excellent. No more possible confusion now.waltervl wrote: Friday 23 December 2022 9:45 I have already updated the Wiki with help of your comments.
And this is valid also for zigbee2mqtt.
- Egregius
What's the reason to have a different prefix in MQTT and Homeassistant?
mgugu
Prefix in HA is used for config messages and MQTT prefix used for update messages. This allows to have 2 different topics, improving readability in MQTT explorer and also to avoid possible MQTT loop.
mgugu
And after a successfull integration, NEVER CHANGE the prefixes !
- Egregius
OK, and which one is set in domoticz then? The MQTT one or the HA one?
mgugu
Only HA prefix is set in domoticz UI. MQTT prefix, used for updates, is sent automatically to domoticz through config messagesEgregius wrote: Friday 23 December 2022 11:40 OK, and which one is set in domoticz then? The MQTT one or the HA one?
JuanUil
- Domoticz version: 4.11083
HI all,
I also have struggeld a lot with switching to ZWave-JS-UI.
But now all is working verry well and better then in OZW.
I have made a tutorial to complete install.
For the moment it is only in Dutch and maybe not complete.
Coming time I will translate and update.
you can download it from :
https://mega.nz/file/3JxQ3Y7R#LIFf5wcVo ... KTAX1e5dFA
good luck!
Jan
good luck!
Jan
- madpatrick
- Domoticz version: 2025.2
Good Job !!
HansF
Thanks Jan, for putting this together!
- gizmocuz
Instead of directly installing these applications/servers on your machine, why not use docker-compose?
I recommend this much more above a direct install
You will have all configuration/data files in each docker-compose folder, and it is very easy to backup/migrate/test/update
Everything is also available in docker-compose
It also does not take any additional system resources
JuanUil
The englisch version of the manual can now be found on:
https://mega.nz/file/jQInXCJI#j-uMcnlrX ... YzUippScHs
Enjoy!
Jan
Enjoy!
Jan
- madpatrick
@gizmocuz
Is it possible to have a notice up front when OZW will be disabled from Domoticz?
This gives me time to build a latest release from source and to switch to ZWave-JS-UI
Thanks !
Keep up the good work
Thanks !
MikeyMan
Hmm... I restarted domoticz several times, but that i didn't notice.mgugu wrote: Friday 23 December 2022 8:59 From my experience, contrary to what is suggested in wiki configuration screenshot, retain flag MUST be set to ON.
This allows the broker to keep in memory the config messages which are necessary each time domoticz is restarted.
If you need to remove definitely devices from domoticz (for example in case you remove a zwave node), you have to remove the corresponding config messages, simply by publishing "" at the config message topic (with MQTT explorer for example).
What behaviour did you see that makes you think this? Can check again.
mgugu
Domoticz does not store mqtt config messages, so if these messages are not retained neither by the broker, after a restart yo will still see the devices in domoticz but they are not responding. You then need to make a manual refresh in the mqtt gateway to make them working again.MikeyMan wrote: Monday 02 January 2023 10:57 Hmm... I restarted domoticz several times, but that i didn't notice.
- elzorrovega
Hello All,
I take this opportunity to wish you All Happy New Year!
We hesitate to sail unto uncharted waters but then again sometimes we have no choice. After closely following your discussions, I understood that Open Z-Wave development is stopped and the only option is to use Zwave-JS-UI in the very near future.
To this effect Domoticz needs to use MQTT gateways, MQTT Broker like Mosquitto and an application such as Zwave-JS-UI to communicate to field devices. Web pages below have been very helpful - Thanks a lot JuanUil - to allow me to almost succeed this exercise but I still have some snags!
https://www.domoticz.com/wiki/MQTT - MQTT Broker Mosquitto
https://www.domoticz.com/wiki/Zwave-JS-UI
DOMOTICZ CONFIGURATION
MIGRATION STATUS
Mosquitto Broker is installed and configured as recommended for Raspbian environment
https://randomnerdtutorials.com/how-to- ... pberry-pi/
Docker is installed and running. Below is the ps ouput
I am new to Docker but to my understanding, one runs an image of an application in localised environment (locally/cloud).
According to https://zwave-js.github.io/zwave-js-ui/ ... tallation
There are three way to install Zwave-JS-UI image
1- Run using volumes
2- Run using local folder
3- Run as a service
I understood, that in all cases we are to download an Zwave-JS-UI image. I chose the second option and data is placed in store directory. I was able to access the Zwave-JS-UI image after running the following in LCI
Terminal shows activity and web interface allows configuration. However, after restarting the Raspberry Pi, the Zwave-JS-UI is not accessible.
Running docker command again brings back the web interface.
QUESTIONS
JuanUil in his walk-through points to dev/serial/by-id/usb-0658_0200-if00:/dev/zwave' .
I used /dev/serial/by-id/usb-0658_0200-if00.
Is :/dev/zwave a must to communication via Z-Wave node?
Docker documentation recommends to add parameter --restart unless-stopped to docker command line and prefers not to use process managers like upstart, systemd or supervisor.
What is the best way to Start Docker Containers Automatically After a Reboot?
Thanks in advance for your help.
El Zorro.
Domoticz version 2022.1 release runs in the following environment
Update Raspberry Pi 3 Model B+
Hardware : BCM2835
Revision : a020d3
Serial : 00000000cc7e2232
Model : Raspberry Pi 3 Model B Plus Rev 1.3
Linux raspberrypi 5.15.76-v8+ #1597 SMP PREEMPT Fri Nov 4 12:16:41 GMT 2022 aarch64 GNU/Linux - Bullseye -64 bit OS
Z-Wave Node
idVendor 0x0658 Sigma Designs, Inc.
idProduct 0x0200 Aeotec Z-Stick Gen5 (ZW090) - UZB
pi@raspberrypi:~ $ pstruc.sh | grep erd
root 668 0.1 5.5 1354332 50072 ? Ssl 17:19 0:04 /usr/bin/dockerd
root 521 0.0 3.4 1335144 31576 ? Ssl 17:19 0:02 /usr/bin/containerdAccording to https://zwave-js.github.io/zwave-js-ui/ ... tallation
3- Run as a service
sudo docker run --rm -it -p 8091:8091 -p 3000:3000 -e TZ=Europe/Paris --device=/dev/serial/by-id/usb-0658_0200-if00 \
-v $(pwd)/store:/usr/src/app/store zwavejs/zwave-js-ui:latest
QUESTIONS
El Zorro.
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
zwave-js: 15.3.1
home id: 3714679688
- sincze
- Domoticz version: 2024.4
Did a first trial run.
Before I started (on a Pi):
Additionally
The nodes were created
in Domoticz, still only based on their NodeID but that seems logical as the names did not come through from OZW.
- With udev I always fix the tty devices to a name. As this will enable me to use /dev/ttyUSB-ZStick-5G as a device https://www.domoticz.com/wiki/PersistentUSBDevices
- Spoiler: show
- Created an overview of all my Domoticz ZWAVE nodeID's in excel so I would be able to identify them later.
- Followed the wiki
(thanks!)
- Disabled the ZWAVE Stick in Domoticz (Production)
- Started the Z-Wave JS UI Docker
- Added Network Security Keys [Settings -> Z-Wave -> Security Keys (S0 Legacy, S2 Unauthenticated, S2 Authenticated, and S2 Access Control))
- After that Control Panel started building up the Network Inventory.
- Unfortunately the Device Names and Locations that I defined in OZW were not transferred into Z-Wave JS.
- Manufacturer name of some Fibaro Power Switching Nodes were and others were not detected (Fibargroup vs Unknown manufacturer 0xXXXX).
Additionally
- Installed a Domoticz (TEST) docker
- Added the Autodiscovery Hardware
- Enabled MQTT Dicovery in Z-Wave JS UI. + Retained Discovery
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
