var config = {}
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['domoticz_ip'] = 'http://192.168.0.151:8080';
config['app_title'] = 'Dashticz V3';
config['dashticz_refresh'] = '180';
config['auto_positioning'] = 0;
config['hide_topbar'] = 1
config['auto_swipe_back_to'] = 1
config['auto_swipe_back_after'] = 60
config['use_favorites'] = 0
config['owm_api'] = '1234567890';
config['owm_city'] = 'Dordrecht';
config['owm_name'] = 'Dordrecht';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '5';
config['owm_min'] = true;
config['owm_days'] = true;
config['garbage_company'] = 'hvc';
config['garbage_icalurl'] = 'https://inzamelkalender.hvcgroep.nl/ical/0505200000034185';
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = 1234AB';
config['garbage_street'] = 'Streetname';
config['garbage_housenumber'] = '123';
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = '4';
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
pmd: {kliko: 'orange', code: '#db5518', name: 'Plastic'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
black: {kliko: 'black', code: '#000000', name: 'Zwart'},
config['garbage_use_names'] = true;
config['garbage_use_colors'] = false;
config['garbage_icon_use_colors'] = false;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg9.jpg';
screens[2] = {}
screens[2]['background'] = 'bg9.jpg';
screens[2]['columns'] = [4,5,6]
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Het weer';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['key'] = 'blocktitle_3';
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Temperatuur';
blocks[21] = {} //Xiaomi sensor
blocks[21]['width'] = 4;
blocks[21]['title'] = 'Slaapkamer' //if you want change the name of switch different then domoticz
blocks[23] = {} //Xiaomi sensor
blocks[23]['width'] = 4;
blocks[23]['title'] = 'Kinderkamer' //if you want change the name of switch different then domoticz
blocks[25] = {} //Xiaomi sensor
blocks[25]['width'] = 4;
blocks[25]['title'] = 'Zolder' //if you want change the name of switch different then domoticz
blocks[30] = {} //Xiaomi sensor
blocks[30]['width'] = 4;
blocks[30]['title'] = 'Woonkamer' //if you want change the name of switch different then domoticz
blocks[39] = {} //Xiaomi sensor
blocks[39]['width'] = 4;
blocks[39]['title'] = 'Badkamer' //if you want change the name of switch different then domoticz
blocks[107] = {} //Xiaomi sensor
blocks[107]['width'] = 4;
blocks[107]['title'] = 'Buiten' //if you want change the name of switch different then domoticz
blocks['Temp-buiten'] = {
width:4,
idx: '107',
title: 'Buiten'
blocks['Zonnepanelen1'] = {
width:4,
idx: '37_1',
title: 'Opwek nu',
popup: 'Zonnepanelen-graph'
blocks['Zonnepanelen2'] = {
width:4,
idx: '37_2',
title: 'Opwek vandaag',
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['key'] = 'blocktitle_2';
blocks['blocktitle_2']['title'] = 'Verwarming';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['key'] = 'blocktitle_4';
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Zonnepanelen';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['key'] = 'blocktitle_5';
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Energieverbruik';
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['key'] = 'blocktitle_6';
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'Energieverbruik per fase';
blocks['blocktitle_7'] = {}
blocks['blocktitle_7']['key'] = 'blocktitle_7';
blocks['blocktitle_7']['type'] = 'blocktitle';
blocks['blocktitle_7']['title'] = 'Energieverbruik per apparaat';
blocks['blocktitle_8'] = {}
blocks['blocktitle_8']['type'] = 'blocktitle';
blocks['blocktitle_8']['title'] = 'Buienradar';
blocks['blocktitle_9'] = {}
blocks['blocktitle_9']['type'] = 'blocktitle';
blocks['blocktitle_9']['title'] = 'Verlichting';
blocks['blocktitle_10'] = {}
blocks['blocktitle_10']['type'] = 'blocktitle';
blocks['blocktitle_10']['title'] = 'Raspberry';
blocks['blocktitle_11'] = {}
blocks['blocktitle_11']['type'] = 'blocktitle';
blocks['blocktitle_11']['title'] = 'Apparaten';
blocks[5] = {} //Tado
blocks[5]['width'] = 6;
blocks[5]['title'] = 'Doeltemperatuur' //if you want change the name of switch different then domoticz
blocks[10] = {} //Tado
blocks[10]['width'] = 6;
blocks[10]['title'] = 'Vermogen' //if you want change the name of switch different then domoticz
blocks[68] = {} // Regen
blocks[68]['width'] = 12;
blocks[68]['switch'] = true;
blocks[68]['hide_title'] = true;
blocks[68]['last_update'] = false;
blocks[68]['image'] = 'cust_umbrella.png';
blocks['BW1'] = {
width:4,
idx: '45_1',
title: 'Vloerverwarming',
popup: 'BW1-graph'
blocks[46] = {} //BW-SHP6-1
blocks[46]['width'] = 4;
blocks[46]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz
blocks['BW2'] = {
width:4,
idx: '47_1',
title: 'CV ketel',
popup: 'BW2-graph'
blocks[48] = {} //BW-SHP6-2
blocks[48]['width'] = 4;
blocks[48]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz
blocks['BW3'] = {
width:4,
idx: '49_1',
title: 'Wasmachine Haier',
popup: 'BW3-graph'
blocks[50] = {} //BW-SHP6-3
blocks[50]['width'] = 4;
blocks[50]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz
blocks['BW4'] = {
width:4,
idx: '112_1',
title: 'Wasmachine Sams.',
popup: 'BW4-graph'
blocks[113] = {} //BW-SHP6-4
blocks[113]['width'] = 4;
blocks[113]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz
blocks['BW5'] = {
width:4,
idx: '53_1',
title: 'Koelkast',
popup: 'BW5-graph'
blocks[54] = {} //BW-SHP6-5
blocks[54]['width'] = 4;
blocks[54]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz
blocks['BW6'] = {
width:4,
idx: '114_1',
title: 'Vriezer',
popup: 'BW6-graph'
blocks[115] = {} //BW-SHP6-6
blocks[115]['width'] = 4;
blocks[115]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz\
blocks['BW7'] = {
width:4,
idx: '120_1',
title: 'Droger',
popup: 'BW7-graph'
blocks[121] = {} //BW-SHP6-7
blocks[121]['width'] = 4;
blocks[121]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz\
blocks['BW8'] = {
width:4,
idx: '122_1',
title: 'Diverse',
popup: 'BW8-graph'
blocks[123] = {} //BW-SHP6-8
blocks[123]['width'] = 4;
blocks[123]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz\
blocks['AVATTO-1'] = {
width:4,
idx: '110_1',
title: 'Airco',
popup: 'AVATTO-1-graph'
} //AVATTO-1
blocks[111] = {} //AVATTO-1
blocks[111]['width'] = 4;
blocks[111]['title'] = 'Aan/uit' //if you want change the name of switch different then domoticz
blocks[57] = {} //Slimme meter electriciteit
blocks[57]['width'] = 4;
blocks[57]['title'] = 'Electriciteit'; //if you want change the name of switch different then domoticz
blocks[57]['popup'] = 'Stroom-graph'
blocks['SM1'] = {
width:4,
idx: '57_1',
title: 'Energie nu',
popup: 'Stroom-graph'
blocks['SM2'] = {
width:4,
idx: '57_2',
title: 'Energie vandaag',
blocks['SM5'] = {
width:4,
idx: '57_5',
title: 'Teruglevering',
blocks['Gas'] = {
width:4,
idx: '67_1',
title: 'Gas vandaag',
popup: 'Gas-graph'
blocks[61] = {} //L1
blocks[61]['width'] = 4;
//blocks[61]['title'] = 'L1' //if you want change the name of switch different then domoticz
blocks[62] = {} //L2
blocks[62]['width'] = 4;
//blocks[62]['title'] = 'Slimme meter' //if you want change the name of switch different then domoticz
blocks[63] = {} //L3
blocks[63]['width'] = 4;
//blocks[63]['title'] = 'Slimme meter' //if you want change the name of switch different then domoticz
blocks[88] = {} //Xiaomi Mi Robot
blocks[88]['width'] = 12;
blocks[88]['icon'] = ''
blocks[88]['title'] = 'Xiaomi Mi Robot' //if you want change the name of switch different then domoticz
blocks[80] = {} //Raspberry
blocks[80]['width'] = 6;
blocks[80]['icon'] = ''
blocks[80]['title'] = 'CPU' //if you want change the name of switch different then domoticz
blocks[81] = {} //Raspberry
blocks[81]['width'] = 6;
blocks[81]['icon'] = ''
blocks[81]['title'] = 'Temp' //if you want change the name of switch different then domoticz
blocks[85] = {} //Raspberry
blocks[85]['width'] = 6;
blocks[85]['icon'] = ''
blocks[85]['title'] = 'Disk' //if you want change the name of switch different then domoticz
blocks['BW1-graph'] = {
title: ['Vloerverwarming'],
graph: ['line'],
devices: [45],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_45'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_45'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_45'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_45'
legend: false,
datasetColors:['red']
blocks['BW2-graph'] = {
title: ['CV ketel'],
graph: ['line'],
devices: [47],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_47'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_47'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_47'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_47'
legend: false,
blocks['BW3-graph'] = {
title: ['Wasmachine Kian'],
graph: ['line'],
devices: [49],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_49'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_49'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_49'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_49'
legend: false,
blocks['BW4-graph'] = {
title: ['Samsung wasmachine'],
graph: ['line'],
devices: [112],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_112'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_112'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_112'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_112'
legend: false,
blocks['BW5-graph'] = {
title: ['Koelkast'],
graph: ['line'],
devices: [53],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_53'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_53'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_53'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_53'
legend: false,
blocks['BW6-graph'] = {
title: ['Diverse'],
graph: ['line'],
devices: [114],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_114'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_114'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_114'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_114'
legend: false,
blocks['BW7-graph'] = {
title: ['Diverse'],
graph: ['line'],
devices: [120],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_120'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_120'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_120'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_120'
legend: false,
blocks['BW8-graph'] = {
title: ['Diverse'],
graph: ['line'],
devices: [122],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_122'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_122'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_122'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_122'
legend: false,
blocks['AVATTO-1-graph'] = {
title: ['Airco'],
graph: ['line'],
devices: [110],
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
Verbruik: 'd.v_110'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_110'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_110'
"Jaar": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_110'
legend: false,
blocks['Stroom-graph'] = {
title: ['Stroom'],
graph: ['line','bar','bar'],
devices: [57],
height: '350px',
toolTipStyle: true,
stacked: true,
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
netto: 'd.v_57+d.v2_57-d.r1_57-d.r2_57',
verbruik: 'd.v_57+d.v2_57',
teruglevering: '-d.r1_57-d.r2_57'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
"Maand": {
range: 'month',
filter: 'month',
data: {
"Jaar wk": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
"Jaar mnd": {
range: 'year',
filter: 'year',
groupBy: 'month',
data: {
legend: false,
datasetColors:['blue','red','yellow']
blocks['Stroom-graph']['width'] = 12;
blocks['Zonnepanelen-graph'] = {
title: ['Zonnepanelen'],
graph: ['bar'],
devices: [37],
height: '350px',
custom : {
"12 uur": {
range: 'day',
filter: '12 hours',
data: {
Opwek: 'd.v_37'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Opwek: 'd.v_37'
"Maand": {
range: 'month',
filter: 'month',
data: {
Opwek: 'd.v_37'
"Jaar wk": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Opwek: 'd.v_37'
"Jaar mnd": {
range: 'year',
filter: 'year',
groupBy: 'month',
data: {
Opwek: 'd.v_37'
legend: false,
beginAtZero: true,
datasetColors:['yellow']
blocks['Gas-graph'] = {
title: 'Gas',
graph: 'bar',
devices: [67],
height: '250px',
custom : {
"6 uur": {
range: 'day',
filter: '6 hours',
data: {
verbruik: 'd.v_67'
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
verbruik: 'd.v_67'
"Maand": {
range: 'month',
filter: 'month',
data: {
verbruik: 'd.v_67'
"Jaar wk": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
verbruik: 'd.v_67'
"Jaar mnd": {
range: 'year',
filter: 'year',
groupBy: 'month',
data: {
verbruik: 'd.v_67'
legend: false,
beginAtZero: true,
datasetColors:['white']
blocks['Gas-graph']['width'] = 12;
var publictransport = {}
publictransport.ovinfobus = {
show_via: false,
title: 'Bus 5',
station: '/dordrecht',
provider: '9292-bus',
destination:'Stadspolders via Centrum/CS',
show_via:false,
interval: '120',
show_lastupdate: false,
icon: 'fas fa-bus',
width:12,
results: 4
publictransport.ovinfotrain1 = {
show_via: false,
title: 'Treinen',
station: 'station-dordrecht',
destination: 'Lelystad Centrum,Amsterdam Centraal',
provider: '9292-train',
interval: '120',
icon: 'fas fa-train',
width:12,
results:4
var frames = {}
frames.buienradar = {
frameurl:'https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.81&lng=4.67361&overname=2&zoom=8&naam=Dordrecht&size=2b&voor=1',
refreshiframe: 600000,
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
blocks['gmail_calendars'] = {
type: 'calendar',
layout: 1,
icalurl: {
Jimmy: {
ics: 'https://calendar.google.com/calendar/ical/xxxxx/basic.ics',
color: 'white',
maxitem: 3
ics: 'https://calendar.google.com/calendar/ical/xxxxxxxxx/basic.ics',
color: '#ccc',
maxitems: 3
holidayurl: 'https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics',
maxitems: 4,
icon: 'fas fa-calendar',
lastweek: false,
isoweek: true,
width: 12
blocks[101] = {}
blocks[101]['width'] = 6;
blocks[101]['protected'] = true
blocks[101]['title'] = 'Jimmy PC'; //if you want change the name of switch different then domoticz
blocks[102] = {}
blocks[102]['width'] = 6;
blocks[102]['protected'] = true
blocks[102]['title'] = 'Jimmy laptop'; //if you want change the name of switch different then domoticz
blocks[103] = {}
blocks[103]['width'] = 6;
blocks[103]['protected'] = true
blocks[103]['title'] = 'Canon printer'; //if you want change the name of switch different then domoticz
blocks[104] = {}
blocks[104]['width'] = 6;
blocks[104]['protected'] = true
blocks[104]['title'] = 'Sams. printer'; //if you want change the name of switch different then domoticz
blocks[105] = {}
blocks[105]['width'] = 6;
blocks[105]['protected'] = true
blocks[105]['title'] = 'PS4'; //if you want change the name of switch different then domoticz
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['miniclock','settings']
columns[1] = {}
columns[1]['blocks'] = ['68','currentweather_big_owm','weather_owm','blocktitle_3','30','21','23','25','39','Temp-buiten','blocktitle_2','5','10']
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_4','Zonnepanelen1','Zonnepanelen2','SM5','blocktitle_5','SM1','SM2','Gas','Stroom-graph']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['width'] = 3;
columns[3]['blocks'] = ['clock','sunrise','garbage',publictransport.ovinfobus,publictransport.ovinfotrain1,'gmail_calendars','88']
columns[4] = {}
columns[4]['width'] = 5;
columns[4]['blocks'] = ['blocktitle_6','61','62','63','blocktitle_7','BW1','BW2','BW3','BW4','BW5','BW6','BW7','BW8','AVATTO-1','Gas-graph']
columns[5] = {}
columns[5]['width'] = 4;
columns[5]['blocks'] = ['blocktitle_8',frames.buienradar,'blocktitle_9']
columns[6] = {}
columns[6]['width'] = 3;
columns[6]['blocks'] = ['blocktitle_10','80','81','85','blocktitle_11','101','102','103','104','105']
