Page 5 of 14
Re: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Wednesday 27 January 2021 23:16
by whoami
JanJaap wrote: Tuesday 26 January 2021 19:48
Hi Whoami, no, I don't see the same errors (am connected to EU server as well).
Hi Falcon8. That is an interesting situation, please switch to verbose logging and show me the loglines so I can see what the response from the webserver looks like, so I can improve handling multiple power stations. Since I've got only 1, did not exactly know what it would look like. Preferably, create an issue in the
Goodwe github.
JanJaap, I did some testing, but it looks like the api of Sems portal has changed? Is that correct?
The output device normally sends the daily, current and total output. Now it only shows the total and not the current and daily anymore...
I use Dashticz and read the 3 values of the idx from your plugin. Since yesterday only the total is displayed as described.
Posted: Wednesday 27 January 2021 23:59
I use this plugin also and have no issues with it. Nothing changed recently.
Did you change something on your system? What does the original device widget say in the Domoticz gui?
I use the plugin of
https://github.com/JanJaapKo/domoticz-GoodWeSEMS
I did not updated to the latest version, changed 12 days ago.... Perhaps you did resulting in your issue (not likely though)
Posted: Thursday 28 January 2021 11:44
by JanJaap
I'm also not experiencing any different behavior on the output part. All widgets give the 'normal' data.
Posted: Thursday 28 January 2021 12:33
by Wiljums
No changelog of latest version?
Verstuurd vanaf mijn SM-G950F met Tapatalk
Posted: Thursday 28 January 2021 13:07
by JanJaap
Posted: Tuesday 09 February 2021 13:01
by Wiljums
Hi, I don't receive the input string data (Voltage, current and power per string) anymore. I do receive inverter temperature, current, voltage en kWh.
I updated to the latest version, but no effect. I don't see errors in the Domoticz log. What could be wrong here?
Could it be because they changed the web interface?
Posted: Tuesday 09 February 2021 20:14
by JanJaap
The plugin takes the combined field and splits that up into separate widgets for current and voltage. Also the plugin multiplies them to get the input power (in separate widget).
So I'm not sure what you are doing, but this plugin is working as it should. If you are processing the data in an other environment I propose o do that same thing. combined field is called "pv_input_1" in the json object. I use the below code to split (in python obviously)
inputVoltage,inputAmps = inverter["pv_input_1"].split('/')
Btw if you enable debug logging in the plugin, it will spit out all the returned data fields to get an idea what is in the return object form the SEMS portal.
Posted: Wednesday 10 February 2021 8:40
by Wiljums
nvm
Posted: Wednesday 10 February 2021 9:28
by Wiljums
It seems like I'm still on 1.1.1 (probably due to migration and installing the old version). When trying to update I get:
>> got it updated to 1.2.6 and working again.
Posted: Wednesday 24 March 2021 11:02
by whoami
JanJaap wrote: Thursday 28 January 2021 11:44
It looks like there are sometimes hickups when connecting to api of the semsgateway, it works now fine and will igonere the error once in a week.
Other question, I use this script to see what I earned today:
on = { timer = { "every 15 minutes" }}, -- script draait iedere 5 minuten
-- on = { devices = { "Stroom"}}, -- Verwijder -- aan het begin van deze regel en plaats -- voor bovenstaande regel als je het script wilt draaien zodra er een nieuw verbruik aan Domoticz is doorgegeven
execute = function(dz)
-- Devices
local vandaagKwh = dz.devices('Zonnepanelen').counterToday -- Stroommeter device
-- Dummy devices
local StroomKosten = dz.devices('Stroomkosten') -- Stroomkosten device
-- Eenheidsprijs in Euro's / Kwh
local kwhPrijs = 0.21000 -- Normaal tarief
-- Vaste kosten in Euro's per dag (zoals vastrecht)
local kwhPrijsVast = 0.0000
-- Kosten berekenen
local kwhKosten = dz.utils.round( (kwhPrijs * vandaagKwh) + kwhPrijsVast,2) -- rounded to two decimals and replace dot by comma
-- Kosten updaten
StroomKosten.updateCustomSensor(kwhKosten)
The device Zonnepanelen is the device from your plugin, but now I want to calculate it for the energy that is generated for the whole year.
So I adjusted the ('Zonnepanelen').counterToday into ('Zonnepanelen').Data because I saw in the JSON output this containt the value that I want to calcute into euros.
Offcourse the rest of the devices I also changed but I get the error:
lua:21: attempt to perform arithmetic on a nil value (local 'vandaagKwh')
So it looks like this is not the right datafield, can you help which one it is?
Posted: Wednesday 24 March 2021 11:38
whoami wrote: Wednesday 24 March 2021 11:02
You can get these value on the report page from the 'Zonnepanelen' so no need to calculate....
See the screenshot on
https://www.domoticz.com/wiki/Managing_ ... ice_Report
You will have to fill in the tariffs on the Setup - Settings - Tab Meters and Counters.
https://www.domoticz.com/wiki/Applicati ... ters_Setup
Posted: Wednesday 24 March 2021 15:35
by whoami
waltervl wrote: Wednesday 24 March 2021 11:38
Yes I know, but I want to see them on my dashticz dashboard, so that is why I made a dummy device with the correct values.
But now I want to see also the values for the whole year....
Posted: Wednesday 24 March 2021 16:33
Then you need to do something like in the following topic:
viewtopic.php?f=59&t=25156
You will have to get al historical generated energy per day from january 1st of this year and add them all up until 1 value.
Posted: Wednesday 24 March 2021 20:10
by whoami
The data is already visible in the device of zonnepanelen, but I can’t get a good count.... see my last detail about zonnepanelen.data
Posted: Thursday 25 March 2021 8:51
You better ask this dzVents question in the dzVents section as it is not Goodwe solar related.
Check the documentation of dzVents. I do not think it is there.
Posted: Saturday 05 June 2021 10:44
by JanLoule
Just this week installed RPi 4 with P1-USB cable to smart meter, and used the script to add the plug in to the Domoticz and got it working first pass. The GoodWe GW5000-DT works fine and I see on the power output in SEMS an output figure in Watt. In the Domoticz channels I activated channels 4, 14 and 15 resp output power, input-1 power, input-2 power. I am not sure what is what, input 1 and 2 are the power inputs from the two strings of panels? and output power is what is delivered to the switchboard ?
Posted: Saturday 05 June 2021 11:28
by JanJaap
I presume with channel you mean unit ID. Here's a short explanation:
1: inverter internal temperature
2: inverter output current [Ampere], what is going out of the inverter so when you have no consumers on, this is also the current going out of your house into the net
3: Inverter output voltage [Volt]
4: Inverter output power [kW/kWh]: the power delivered to the net, this is in the end what is earning you your investment back. Example: your panels produce 3 kW and you have you're oven running at 3,5 kW, then netto 0,5 kW comes in via the switch board. In the widgets you see the power at the moment (3kW in the example) and the amount of energy produced so far in kWh
5..8: the current and voltage of the input strings 1 and 2 (so that is what you could measure on the wires coming in form the panels)
10..13: the current and voltage of the input strings 3 and 4 (so that is what you could measure on the wires coming in form the panels)
There is allways minimum 1 input, some people have 2 (as I have) I think 3 and 4 is quite rare but it is in the interface nonetheless
9: inverter state: tells you if it is actually generating power or not
14..17: power of the inputs [kW]: this I calculate as it is not in the interface. But gives a better idea of the amount of energy produced by the various input strings (my 2 sets are facing east and west so I can see how this varies over the day)
So your p1 energy smart meter widget you can compare with unit 1 of the solar panels. Hope this helps.
Posted: Saturday 05 June 2021 15:01
by JanLoule
OK JanJaap, I see the data as you explained – makes sense.
Solar input power – string 1 = 341 Watt
Solar input power – string 2 = 522 Watt
= total input from the PV panels 863 Watt
Converted into power in the home grid:
Solar output power = 638 Watt
Effectively 79% …
Of this power I read (from the P1 meter) that phase L1 and phase L2 absorb the majority
The inverter is (as I understand) phase-balanced i.e. 1/3 of the output on each phase.
Phase L3 is not using power, hence 188 Watt flows back to the mains i.e. 29%.
The remaining 2/3 are used in the home grid by phase L1 and phase L2
The total power from the net to meet the house demand hence is
Usage L1 = 2619, plus Usage L2 = 1973, minus the production to the grid Delivery L3 = 188 Watt.
This totals 4404 Watt imported from the mains grid into the house.
- Screenshot Domoticz with GoodWe script running
- Domoticz-GoodWe.jpg (45.48 KiB) Viewed 2127 times
Posted: Monday 07 June 2021 20:42
by wlmpie
It is now possible to readout your inverter data from your local network when your firmware of an XS inverter is 1.xx.14 of higher. In my case 1.13.15.
The following user wrote some python code to do this.
https://github.com/borft/py-goodwe
Can this possibly be merged with the goodwe solar inverter plugin? (Unfortunately I am too much an amateur in programming to do this myself.)
see also
https://gathering.tweakers.net/forum/li ... /1799239/0 In Dutch
Posted: Monday 07 June 2021 21:33
by JanJaap
The tweaker post is quite a read. I've read it before (to some extend) but then it was still about sniffing it via USB which I did not want to go into. Somewhere in the 13 pages somebody discovered a Wifi trick. I'll dive into it, probably this weekend.....
Tnx for the hint, btw.
