Dashticz V3 - Automatic installation
fabry91
Domoticz version: 2022.2
Re: Dashticz V3 - Automatic installation
Post by fabry91 »
Sjonnie2017 wrote: Friday 18 December 2020 18:14 Config.js indeed! I modified my Dashticz dashboards some time ago so I forgot the extension (and was too lazy to check before posting :oops: )
I can't remember I had this error when I installed Dashticz on my Pi. But from what I read here (https://peppe8o.com/install-home-assist ... th-docker/) it does not have to be a problem (I am extrapolating.. I know).
What happens if you follow this guide: https://dashticz.readthedocs.io/en/mast ... board.html. It will only show your favorites from Domoticz but at least it is a start to see if the installation is OK. Just mark out the username and password lines and see what happens.
Thank you very much for your support ;)
fabry91
Post by fabry91 »
Hello, back again with some boaring question, hope someone can help me, even if they'll be stupid question, I already read the manuale and understood that it's a grind, but how:
- I can have the clock in the first column in the center of the whole free speace remaning? (red box named "clock)
- I can remove the space between the switches? (blue box crossed)
- I can have 5 box with the streaming of the cam? (red box named "cam")
The problem is that I don't understand what size and number I need to put, I'm attaching a screen of the config file.
Thank you in advance :|
Lokonli
Post by Lokonli »
Try the following:
Two columns.
Column 1 width 5
Column 2 width 7
(Sum of column width should be 12)
Assign all switches to column 1 and give them width 6.
Make clock basicclock, width 12, scale 0.5, and place in column 2
All cams width 6, place in column 2 as well.
fabry91
Post by fabry91 »
Lokonli wrote: Monday 21 December 2020 23:49 Try the following:
Two columns.
Column 1 width 5
Column 2 width 7
Hello Lokonli,
thank you very much for your reply, only thing I don't have understand, how can I set the scale in the blocks of the clock?
I never had write the code for adding a camera, how can I do it? Like, what is the right code of the block?
I'm attaching the current layout and script.
Thank you very much ;)
Lokonli
Post by Lokonli »
if you give columns[2] width:7 instead of width:12 then it will fit right of the first column.
Do you have camera's that provide an image link? and a mjpeg link?
Try this:
https://dashticz.readthedocs.io/en/mast ... meras.html
Instead of a camera block you can add a button, which shows a small preview. If you push the button, a popup window shows a bigger image.
Check:
https://dashticz.readthedocs.io/en/mast ... ttons.html
fabry91
Post by fabry91 »
Lokonli wrote: Tuesday 22 December 2020 21:49 if you give columns[2] width:7 instead of width:12 then it will fit right of the first column.
Try this:
Check:
Hello Lokonli,
it takes a little long to understand but finally done! :o :mrgreen:
Thank you very much for your help and fast replies!! ;)
Now I'm figuring out how to put the clock in the center of the upper space.
Lokonli
Post by Lokonli »
Are you using the beta branch or master branch?
In beta branch I've added 'basicclock', which you can scale to the preferred width.
fabry91
Post by fabry91 »
Lokonli wrote: Wednesday 23 December 2020 0:32 Are you using the beta branch or master branch?
I am using the beta branch, it says me that a new version is available (v3.7.1), how can I update the current v3.7.0? This will cause a lost of the config?
Thank you!
fabry91
Post by fabry91 »
fabry91 wrote: Thursday 24 December 2020 12:11
Thank you!
Hello @Lokonli, news about how to update to 3.7.2?
Thank you and Happy New Year ;)
Lokonli
Post by Lokonli »
Did you already try this:?
viewtopic.php?f=67&t=34997
And next time it will just be 'git pull'
fabry91
Post by fabry91 »
Lokonli wrote: Thursday 31 December 2020 19:04 Did you already try this:?
Thank you Lokonli, everything done! ;)
