Thank you very much for your supportSjonnie2017 wrote: Friday 18 December 2020 18:14 Config.js indeed! I modified my Dashticz dashboards some time ago so I forgot the extension (and was too lazy to check before posting)
I can't remember I had this error when I installed Dashticz on my Pi. But from what I read here (https://peppe8o.com/install-home-assist ... th-docker/) it does not have to be a problem (I am extrapolating.. I know).
What happens if you follow this guide: https://dashticz.readthedocs.io/en/mast ... board.html. It will only show your favorites from Domoticz but at least it is a start to see if the installation is OK. Just mark out the username and password lines and see what happens.
Dashticz V3 - Automatic installation
- fabry91
- Domoticz version: 2022.2
Re: Dashticz V3 - Automatic installation
- fabry91
Hello, back again with some boaring question, hope someone can help me, even if they'll be stupid question, I already read the manuale and understood that it's a grind, but how:
- I can have the clock in the first column in the center of the whole free speace remaning? (red box named "clock)
- I can remove the space between the switches? (blue box crossed)
- I can have 5 box with the streaming of the cam? (red box named "cam")
The problem is that I don't understand what size and number I need to put, I'm attaching a screen of the config file.
Thank you in advance
- LAYOUT.jpg (145.04 KiB) Viewed 834 times
- config1.jpg (35.97 KiB) Viewed 834 times
- config2.jpg (41.74 KiB) Viewed 834 times
Lokonli
Try the following:
Two columns.
Column 1 width 5
Column 2 width 7
(Sum of column width should be 12)
Assign all switches to column 1 and give them width 6.
Make clock basicclock, width 12, scale 0.5, and place in column 2
All cams width 6, place in column 2 as well.
Two columns.
Column 1 width 5
Column 2 width 7
- fabry91
Hello Lokonli,Lokonli wrote: Monday 21 December 2020 23:49 Try the following:
Two columns.
Column 1 width 5
Column 2 width 7
thank you very much for your reply, only thing I don't have understand, how can I set the scale in the blocks of the clock?
I never had write the code for adding a camera, how can I do it? Like, what is the right code of the block?
I'm attaching the current layout and script.
Thank you very much
- layout.jpg (97.13 KiB) Viewed 818 times
- config.jpg (38.31 KiB) Viewed 818 times
Lokonli
if you give columns[2] width:7 instead of width:12 then it will fit right of the first column.
Do you have camera's that provide an image link? and a mjpeg link?
Try this:
https://dashticz.readthedocs.io/en/mast ... meras.html
Instead of a camera block you can add a button, which shows a small preview. If you push the button, a popup window shows a bigger image.
Check:
https://dashticz.readthedocs.io/en/mast ... ttons.html
Try this:
Check:
- fabry91
Hello Lokonli,Lokonli wrote: Tuesday 22 December 2020 21:49 if you give columns[2] width:7 instead of width:12 then it will fit right of the first column.
Try this:
Check:
it takes a little long to understand but finally done!
Thank you very much for your help and fast replies!!
Now I'm figuring out how to put the clock in the center of the upper space.
- Untitled.jpg (112.3 KiB) Viewed 805 times
Lokonli
Are you using the beta branch or master branch?
In beta branch I've added 'basicclock', which you can scale to the preferred width.
- fabry91
I am using the beta branch, it says me that a new version is available (v3.7.1), how can I update the current v3.7.0? This will cause a lost of the config?Lokonli wrote: Wednesday 23 December 2020 0:32 Are you using the beta branch or master branch?
Thank you!
- fabry91
Hello @Lokonli, news about how to update to 3.7.2?fabry91 wrote: Thursday 24 December 2020 12:11I am using the beta branch, it says me that a new version is available (v3.7.1), how can I update the current v3.7.0? This will cause a lost of the config?Lokonli wrote: Wednesday 23 December 2020 0:32 Are you using the beta branch or master branch?
Thank you!
Thank you and Happy New Year
- fabry91
Thank you Lokonli, everything done!Lokonli wrote: Thursday 31 December 2020 19:04 Did you already try this:?
viewtopic.php?f=67&t=34997
And next time it will just be 'git pull'
