Import weather data other than Wunderground
Lokonli
Re: Import weather data other than Wunderground
Post by Lokonli »
Backlash wrote: Sunday 20 September 2020 18:39 nobody who can point us at the right direction?
If I look at the post of @Sarcas then the link seems to incorrect.
The OWM data is loaded via the CORS proxy, but that part is missing in the url. It should start with:
http://<domoticz ip:port>/vendor/dashticz/cors.php?https://api.openweathermap.org/data/2.5/weather?id=...
So I think there is something wrong with the CORS setting in CONFIG.js.
On the other hand:
There is no need for using the CORS proxy for the OWM data. In the latest beta I removed the CORS proxy for OWM data. I expect that will solve your issue.
Sarcas
Domoticz version: 2022.1ß
Post by Sarcas »
I am running beta version 3.5.2. Afaik it is the latest version.
Schermafbeelding 2.png (393.6 KiB) Viewed 1612 times
Domoticz on rPi4 - RFXCOM RFXtrx433 USB - ZW090 Z-Stick Gen5 EU - IKEA Tradfri - Philips HUE - YouLess meter - SolarEdge
Lokonli
Post by Lokonli »
I did not update the version number yet. Try to update with git pull, or download from Github.
Backlash
Domoticz version: Latest
Post by Backlash »
HansieNL wrote: Sunday 20 September 2020 19:29 Just tried my config with Dashticz 3.5 master and the 'weather_owm' block has no problem.
What settings do you use (without API key)?
changed from V3.5 master to V3.5.2 beta and problem solved
git fetch origin
git checkout beta
git pull
Sarcas
Post by Sarcas »
Lokonli wrote: Monday 21 September 2020 13:02 I did not update the version number yet. Try to update with git pull, or download from Github.
Works after the ‘git pull’ :D
HansieNL
Post by HansieNL »
Backlash wrote: Monday 21 September 2020 16:16
git fetch origin
git checkout beta
git pull
If you like you can change back to master and see if it then works o.k.
Blah blah blah
Backlash
Post by Backlash »
HansieNL wrote: Monday 21 September 2020 19:09
git fetch origin
git checkout beta
git pull
Back to master again V3.6 since yesterday, and it still works :)
cduijker
Post by cduijker »
I would like to use the weather widget from https://weatherwidget.io/ as it is highly customizable.
Does anybody know how to add the generated code in an iframe for Dashticz?
regards
Lokonli
Post by Lokonli »
I could create a custom html block type, in which you can just copy paste the html code. Would that be useful?
lzwfkv
Post by lzwfkv »
Lokonli wrote: Sunday 27 September 2020 18:16 I could create a custom html block type, in which you can just copy paste the html code. Would that be useful?
Hi Lokonli, yes it would for me.
Thanks.
cduijker
Post by cduijker »
That would be very nice!
Vomera
Post by Vomera »
cduijker wrote: Sunday 27 September 2020 17:56 I would like to use the weather widget from https://weatherwidget.io/ as it is highly customizable.
regards
I just made an html page in the same directory as the dashboard and made a refer to the frame
frames.voorspelling = {
  frameurl:"custom/forcast.html",
  height: 112,     //height of the block in pixels
  width: 12,
  scrollbars:false,
  refreshiframe:300000,
HansieNL
Post by HansieNL »
Would be great.
If I now use an iframe the block is not responsive and cuts the info in half.
Is there a way to auto resize the block to the iframe size?
Blah blah blah
Vomera
Post by Vomera »
HansieNL wrote: Monday 28 September 2020 12:59
Would be great.
You can change the height of the iframe, or you want it at 225px. Then indeed it would be cool to paste the html code
Lokonli
Post by Lokonli »
In beta 3.6.1 I've added the custom html block functionality.
See:
https://dashticz.readthedocs.io/en/beta ... /html.html
Give it a try :)
HansieNL
Post by HansieNL »
Lokonli wrote: Tuesday 29 September 2020 20:32 In beta 3.6.1 I've added the custom html block functionality.
See:
Give it a try :)
Just tried :D Works like a charm.
Blah blah blah
cduijker
Post by cduijker »
See:
Give it a try :)
Thanks a lot!
