Page 5 of 7
Re: Weekly programming
Posted: Friday 03 August 2018 11:15
by syrhus
I didn't work on my domoticz for a while.
I will try to upgrade to the latest version and modify this tool on septembre.
Posted: Wednesday 19 September 2018 9:49
by syrhus
I have updated the source code to work with the latest version v4.9700
https://gist.github.com/syrhus/8fbb01fb ... be210993c8
Posted: Thursday 20 September 2018 13:59
by elgarne
I checked two days ago and thought you forgot about it. Merci beaucoup.
Posted: Thursday 20 September 2018 14:11
by syrhus
Hi elgarne
You're welcome and thank you for the french reply (are your french?) ;)
I'm working on a new functionality, showing 2 weeks (odd & even) because some people suggest that as they are living with 2 different kind of weeks,1 with child and the other without.
Posted: Thursday 20 September 2018 14:59
by elgarne
I'm absolument french and living in Paris (area) ;)
And I'm exactly in the same situation as people asking for odd and even weeks.
I needed to empty the browser cache to have it working.
Posted: Thursday 20 September 2018 15:42
by syrhus
Good news, I've updated the code on Github to see Odd&Even week numbers
planning.css and planning.js file have changed.
Remove the application cache of the web navigator.
Let me know if it is working fine with this new version on 2 weeks (and if it is still working on 1 week)
Posted: Thursday 20 September 2018 15:46
by elgarne
Seems working fine. Could not find how to empty cache on Safari (the menu command does not seem to work) but using the private mode works fine.
Posted: Thursday 20 September 2018 16:00
by syrhus
Great!
You can force to reload all cached files by changing the ref in the html5.appcache file on the www folder
CACHE MANIFEST
# ref 2
CACHE:
Posted: Thursday 20 September 2018 21:55
by Patricen
This feature is really great!
What about requesting that it enters in the mainstream of Domoticz source code?
Patrice
Posted: Wednesday 10 October 2018 18:43
by garethhowell
I'm obviously not getting something here.
I'm running 4.9700. I've downloaded the latest from github, copied the files to the necessary places and updated html5.appcache to force the browser cache to update. However, I see no change in the UI. I just see the original timer screen. I even tried restarting the domoticz service.
I see no errors in the console, but I also don't see the new js file.
One thing, despite having added new css and js files, there is no instruction to add them to the appcache. I take it this means they don't get cached.
Gareth
Posted: Monday 29 October 2018 15:42
by syrhus
Hi gareth
This is really not easy to clear the application cache. Are you using Chrome?
About the application cache, keep it mind this is a absolutely useless! Application cache is used for offline application; how Domoticz could work offline? You see a screen with wrong state and wrong values!
So, the manifest should be adjust to cache only the web page for the offline alert. That's all.
About your concern, have you tried to open your web site in private mode? Is it working fine?
Posted: Tuesday 30 October 2018 8:22
by garethhowell
Thanks for coming back to me.
I’d been having a number of UI display-related issues that affected the display of devices: not just this module.
Eventually, I did a clean install of Domoticz and those problems went away. I’ve not got around to trying this module again, but I will soon.
Posted: Tuesday 30 October 2018 14:40
by syrhus
Oups!!!
I'm sorry, I thought i fixed a bug on table header and I left a bug on it.
So, pleae, download the new fixed planning.js file from github
Apologized for this.
Posted: Wednesday 12 December 2018 11:23
by syrhus
New update!
I edited the first post with new screen capture
- you can choose time range : 1h, 30mins, 15mins, 10mins
- deactivate the entire "program" (stand by mode) and activate it later
- program on 2 weeks with the odd&even mode
Source on github https://gist.github.com/syrhus/8fbb01fb ... be210993c8
Posted: Wednesday 12 December 2018 22:09
by Nautilus
Great job, this seems like a great feature for Domoticz. Why it is not merged with the master branch?
Posted: Thursday 13 December 2018 8:49
by syrhus
I have already asked to gizmocuz...
Posted: Thursday 13 December 2018 9:08
by Nautilus
syrhus wrote: Thursday 13 December 2018 8:49 I have already asked to gizmocuz...
Ok, and the answer was "no"? Any specific reason for this? Might be one option to just make a pull request (unless that is what you already did of course :))...
Posted: Thursday 13 December 2018 9:25
by syrhus
No answer.
When I made a pull request about another subject like remove the useless and ugly manifest application cache, he suggested to discuss first, what I did with a post on the forum before adding this pull request...
I don't want to bore him and I don't want to waste my time to send again and again some email or create a pull request to be rejected like the applicationcache.
Posted: Thursday 13 December 2018 11:57
by Nautilus
syrhus wrote: Thursday 13 December 2018 9:25 No answer.
Ok, I don't know any details about appcache except that indeed it has been flagged as deprecated for quite a while already. On the other hand there's people saying it's needed to speed things up and e.g. adding to home screen on iOS devices. How (un)important it is in practice, I cannot comment.
I guess Gizmocuz meant that if there is such a file in place, it might make sense to discuss its purpose first before making a pull request that basically clears the whole file.
There are dozens of pull requests merged each month, quite many without any specific discussion, so I'm hoping you would reconsider and give this feature a chance to be merged into master branch :)
Posted: Thursday 13 December 2018 12:59
by syrhus
I understand easily that Gizmocuz has a lot of requests and a lot of stuff to manage this beautiful product that Domoticz is.
I will try one day to make a pull request, may be it will be approved ;)
