Looking forward to that.freijn wrote: Thursday 17 October 2019 13:28 Very interesting indeed. Will try to install as well and perhaps optimize the script in order to sent the sensor info to Domoticz.
SolarEdge via LAN interface
- McMelloW
- Domoticz version: V2024.1
Re: SolarEdge via LAN interface
Greetings McMelloW
cmddlm
Hi everyone.
I can communicate with my solaredge SE3000H with command on windows console.
I have created 11 dummy devices with idx' numbers, correct ip and port of domoticz sever.
I have this dzVent script that doesn't update dummy devices :
timer = {'every minute'}
execute = function(domoticz,device)
domoticz.utils.osExecute('perl C:\\Mia\\solar2.pl -n -m 0 192.168.1.13 > C:\\Mia\\SEoutput.txt')
domoticz.log()
All seems to work and no errors appears in logging domotics.
Domotics create the file SEoutput.txt with correct content:
1581066840,4,1822,1850,129345,245.40,7.44,390.50,4.74,32.55,0,0
bat devices don't receive any updating and report all 0 value.
Thanks everybody who will help me.
domoticz.log()
cmddlm
I have to add that if I add a the command
Print 'Hallo' at the beginning of script perl solar2.pl, at the beginning of file SEoutput.txt Domoticz write correctly Hallo and values of my solaredge.
I think my script Solar2.pl have something wrong bat I don't know what.
I attach my file that I have modified in txt file.
- solar2.txt
- (22.9 KiB) Downloaded 90 times
freijn
- Domoticz version: Stable
You are missing the -z parameter
domoticz.log()
should be
domoticz.utils.osExecute('perl C:\\Mia\\solar2.pl -n -z -m 0 192.168.1.13 > C:\\Mia\\SEoutput.txt')
domoticz.log()
domoticz.log()
should be
domoticz.log()
freijn
Anybody worked on this already ?Micha123 wrote: Tuesday 15 October 2019 16:19 I found sunspec_ardexa
It ia a python script and is working much faster then the pearl script
https://pypi.org/project/sunspec-ardexa
I have found that
sunspec_ardexa log 192.168.1.140 1 /home/pi/sun
Generates a nice .csv file in the logdir. But where or in what file is this generated as I would like to make the json calls from
there directly into the Domoticz
Anybody ?
freijn
Contacted the support email address.
Till now very responsive , hopefully I get some hints so can modify the script for Domoyicz
cmddlm
Thanks frejjn. Now is all OK.freijn wrote: Saturday 08 February 2020 21:41 Hi
domoticz.log()
should be
domoticz.log()
freijn
Guys,
Who already installed the sunspec_ardexa python tool ?
Can you please run the below command and tell me in which directory your sunspec_ardexa.py is located ?
I like to see the full path.
If you do not understand the question.. please run the below command and sent the output
I have found where I can / have to change the file in order to use sunspec_ardexa as an interface between the SolarEdge and Domoticz.
I will have a test version ready this week, but need some help from you guys for testing on serveral systems and feedback on the install.
Will keep you updated...
Frank
sudo find / -name sunspec_ardexa.pyI will have a test version ready this week, but need some help from you guys for testing on serveral systems and feedback on the install.
Frank
- McMelloW
Frank,
I am not sure or i use it. But it is on my RPi present anyway.
pi@mcmellow-pi:~ $ sudo find / -name sunspec_ardexa.py
/usr/local/lib/python2.7/dist-packages/sunspec_ardexa.py
Greetings McMelloW
freijn
Perfect, McMellow
Same place as me
If I have made my modifications to the file, I think you would like to use it
Same place as me
- McMelloW
Please keep me updated.freijn wrote: Tuesday 18 February 2020 16:01 Perfect, McMellow
Same place as me
If I have made my modifications to the file, I think you would like to use it![]()
Greetings McMelloW
rogerthn
@Jackb Many thanks!Jackb wrote: Friday 06 September 2019 19:08 To make the script work you have to install several PERL modules:
I do have it working with update every minute when there is no light and "every second" when my Aeotec ZW074 MultiSensor Gen5+ gives Lux > 0 but energy Today in device SolarEdge Actual Power DC and AC is lower than https://monitoringpublic.solaredge.com/ ... /dashboard
Any suggestions?
PS
Crontab entry
1 0 * * * /home/pi/scripts/SolarEdge.sh > /tmp/SolarEdge.log 2>&1Code: Select all
#!/bin/bash
echo "$(date +%Y-%m-%d\ %H:%M:%S.%N) start"
HOUR=$(date +%H)
while [ "$HOUR" -lt 23 ]
do
Lux=$(wget -O - -q "http://192.168.C.D:8080/json.htm?type=devices&rid=63" | grep Data | awk -F '"' '{print $4}' | awk '{print $1}')
if [ "$Lux" -eq 0 ]
then
/usr/bin/perl /home/pi/scripts/SolarEdge.pl -m 0 -z 192.168.C.D
status=$?
if [ "$status" -ne 0 ];then
echo "$(date +%Y-%m-%d\ %H:%M:%S.%N) status = $status"
fi
/bin/sleep 60
status=$?
fi
/bin/sleep 1
fi
HOUR=$(date +%H)
done
echo "$(date +%Y-%m-%d\ %H:%M:%S.%N) done"
freijn
I fire the script to update the solar when the P1 update comes in.
I do fire it from the update event of the P1.
Within this P1 update event you could check the Lux...
rogerthn
I've no P1?freijn wrote: Saturday 22 February 2020 19:53 I fire the script to update the solar when the P1 update comes in.
freijn
Ohhh sorry... Still I would solve it in Lua of Dzvents.. not in bash...
freijn
Guys,
I have started a new topic for the Python SolarEdge script
https://www.domoticz.com/forum/viewtopi ... 65&t=31455
rogerthn
OK!freijn wrote: Sunday 23 February 2020 15:06 Ohhh sorry... Still I would solve it in Lua of Dzvents.. not in bash...
rogerthn
Thanks!freijn wrote: Sunday 23 February 2020 20:44 Guys,
My issue is that the dummy devices (Instant+Counter, Computed) gets correctly? updated with Power but the calculated? Energy is a bit to low.
Today I do have DC Energy = 6.084 kWh and AC = 5.994 kWh
https://monitoringpublic.solaredge.com/ ... /dashboard has 6.185 kWh
freijn
I do not have computed but from device :
Perfect match.. although SolarEdge does a round up...
rogerthn
OK, I'll change AC Power to From device and see, fingers crossed
You can get three decimals on the SolarEdge page if you change to month view and hover with the mouse over the days
