Dashticz - Module - Calendar
gielie
Domoticz version: latest β
Re: Dashticz - Module - Calendar
Post by gielie »
mvveelen wrote:Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
This is my setting, with the locale set to nl but still no luck.
var calendars = {}
calendars.private = { maxitems: 3, icalurl: 'webcal://p40-
var _ICALENDAR_DATEFORMAT     = 'dddd DD MMMM YYYY';
var _ICALENDAR_LOCALE         = 'nl_NL'; //en,hu, etc.
Resulting in this
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
var calendars = {}
Resulting in this
Should work in latest beta. Please get it again..
BUT, you have to add the time:
var _ICALENDAR_DATEFORMAT     = 'dddd DD MMMM YYYY HH:mm';
gielie
Post by gielie »
confirmed, tanks for the fast solution.
- FIBARO FGS223
- Toon
- Kodi Media Server
rickvanakkeren
Post by rickvanakkeren »
Thanks for the good work! I got my calendars working (combined). It works pretty fine. But is it possible to display the month in text (like jan, feb, mar, apr) instead of a number?
And for recurring items, I see the date of the last appointment instead of the upcoming, and the time is displayed wrong (one hour late).
mvveelen
Post by mvveelen »
robgeerts wrote:
mvveelen wrote:I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
Your calendar shows right at my dashboard, I have this var set in config.js:
var _ICALENDAR_DATEFORMAT	= 'DD.MM HH:mm';
What do you have set in this variable?
Combined calendars should work again.
I still used the "friendly" setting. With this it displays right, thanks !
mikeoo
Post by mikeoo »
Trying to add my Google Calandar my can't get it working.
Added the code to CONFIG.js
This is only the part what i use in CONFIG.js. Of course there is more in CONFIG.js
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/' }
var columns = {}
columns[3] = {}
columns[3]['blocks'] = ['clock',buttons.buienradar,'streamplayer',calendars.private]
columns[3]['width'] = 2;
But i only get LOADING in Dashticz
When i past https://calendar.google.com/calendar/ in a browser i get my Calandar.
Do i need to change something in Gmail Calander setting also for this function to work.
capman
Post by capman »
mikeoo wrote:Trying to add my Google Calandar my can't get it working.
....cut....
You need to log in to your google calendar and go to "instellingen" or "setup" a think in english. It's the gear icon on the top right of your screen.
Then you click on agenda's left to labs (it's on the left top). On the next screen click on your agenda you want to use. Click on the green icon next to 'private adres' , its the icon that said 'ICAL'. Now opens a window with your link you have to paste in to your custom config.js.
var calendars = {}
calendars.business = { maxitems: 5, url: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/', icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxx/basic.ics' }
Hope it helps you out.
mikeoo
Post by mikeoo »
....cut....
var calendars = {}
Thank you. I found that ICAL part but because it was not mention on the first page that you need that url i was think the you only need the url for Googl Calandar. :lol:
now working fine.
robgeerts
Post by robgeerts »
Nice :)
Remove https://cors-anywhere.herokuapp.com/ from the url.
This is done within Dashticz itself...
EdwinK
Post by EdwinK »
For a second, I thought I had the combined calendars working. But ... nope. :(
rickvanakkeren
rickvanakkeren wrote:Thanks for the good work! I got my calendars working (combined). It works pretty fine. But is it possible to display the month in text (like jan, feb, mar, apr) instead of a number?
In addition: is it possible to also show the day of the week in text?
(like ma 15 mei - 16:00 - 17:00 - event)
qwerk
Post by qwerk »
it already is,
in the CONFIG.js change de icalendar dateformat
ddd DD-MM-...... etc
the ddd is the day in letters mo. tu. we.
dddd is the full day name
Trigun
Domoticz version: 4.10717
Post by Trigun »
Hi Guys, trying to setup the calender but am quite lost with all the info within this topic.
I am trying to setup a google calendar but don't know which info is right and which is not.
I assume I need 2 things:
1: the Icalender URL = which is ?
2: the ical url = which I have.
but whats next.
Thnx in advance guys!
htilburgs
Post by htilburgs »
Trigun wrote:Hi Guys, trying to setup the calender but am quite lost with all the info within this topic.
but whats next.
Have you already take a look at the wiki?
http://www.domoticz.com/wiki/Dashticz_V ... a_calendar
Hardware:
EdwinK
Post by EdwinK »
I believe the 'cors-anywhere...' part wasn't needed anymore, the script seems to handle it
robgeerts
Post by robgeerts »
Removed that part from the wiki ;)
poudenes
Domoticz version: 3.8993
Post by poudenes »
Is it correct that the calendar is still in progress? Updated this morning to latest beta and see the items and repeated items as well. Only items from 2018 and 2017 are listed...
Derik
Post by Derik »
dear all.Can i use the calendar module from the wiki? or do i need this code? Or????
Thanks For the great work
robgeerts
Post by robgeerts »
Take a look at the first post in this topic.
Derik
Post by Derik »
robgeerts wrote:Take a look at the first post in this topic.
I read the topic..
I see beta and not finished yet et..
Only when i use the first code this the ast version? :D :D ;)
