Dashticz - Feature Requests
Locked
HansieNL
Re: Dashticz - Feature Requests
Post by HansieNL »
robgeerts wrote:Just tested this and it works:
blocks[145] = {} // My "huiskamer"
blocks[145]['switch'] = true;
blocks['144_2'] = {} // My Thermostaat
blocks['144_2']['switch'] = true;
Hoi Rob,
Got a Toon thermostat myself and just tried, but I got same problem as Gielie. Temperature stays always on top.
Maybe you can check if there's a difference in thermostat?
If you want me to check some code, just let me know.
Blah blah blah
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
What did you try in config?
(I have a toon too).
Got the latest beta?
HansieNL
Post by HansieNL »
robgeerts wrote:What did you try in config?
This is what I added to config. And just did new pull with same result.
blocks[35] = {} //Toon (Toon Setpoint)
blocks[35]['switch'] = true;
Blah blah blah
robgeerts
Post by robgeerts »
And 35_1 or 35_2 ( with quotes) doesnt work either?
HansieNL
Post by HansieNL »
robgeerts wrote:And 35_1 or 35_2 ( with quotes) doesnt work either?
35_1 is working and has then the same look as other switches.
Blah blah blah
HansieNL
Post by HansieNL »
Still playing around with the setpoint / selector switch blocks.
For me no title is even better. The icon says enough. Would be great if both data values can be vertically centered aligned.
Maybe an option to add in the future?:
blocks[IDX]['title'] = false;
blocks[IDX]['align'] = true;
Naamloos 2.jpg (5.21 KiB) Viewed 4103 times
Blah blah blah
htilburgs
Post by htilburgs »
Rob, is it possible to have an icon / image option in the Calendar, like in the buttons?
I'm trying to minimalize the dashboard and let out as much as possible, like blocktitles.
Everything has an icon / image in front, except the calendar.
buttons.nunl = {width:4, icon: 'fa-newspaper-o', title: ' Nu.nl', url: 'http://www.nu.nl'}
for the calendar:
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
If people don't want it, the simple leve the icon: '' and then they have no icon.
Hardware:
HansieNL
Post by HansieNL »
htilburgs wrote:Rob, is it possible to have an icon / image option in the Calendar, like in the buttons?
for the calendar:
You mean the icon like in the block in the RSS feed, traffic, etc?
Blah blah blah
htilburgs
Post by htilburgs »
Yip
Hardware:
HansieNL
Post by HansieNL »
htilburgs wrote:Yip
You were talking about the buttons, that's why I was confused. Now it's clear. ;)
Blah blah blah
htilburgs
Post by htilburgs »
I meant like in the rss feed, etc..
But I like the feature as in the buttons, just the option icon: or image: in the variable.
example:
or
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', image: 'img/calendar.png',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
Hardware:
HansieNL
Post by HansieNL »
htilburgs wrote:I meant like in the rss feed, etc..
example:
or
Or even better this one
Blah blah blah
htilburgs
Post by htilburgs »
+1
Hardware:
capman
Re: Sonos AlbumArt button
Post by capman »
A wanna do the same but for my logitech media server on my NAS.
http://www.domoticz.com/forum/viewtopic ... 60#p134389
So far no response from anybody who can help me out. :(
HansieNL
Post by HansieNL »
I can't help you with this because I'm no coder, but I like the idea.
Maybe you can create a feature request issue on GitHub for this?
Blah blah blah
capman
Post by capman »
Okee , a will try this . Thanks 4 the tip 8-) Maybe we get some response.
jake
Post by jake »
Feature request:
- Ability to change amount of digits in a block value (for instance: don't show 7.123 kWh today, but 7.1 kWh today)
- Ability to change a block's value unit (for instance not 1500 Watt, but 1500 W) this to save space in the block
Not needed for me, but possibly for some specific cases
- Ability to convert a block value (for instance, not 1500W, but 1.5kW)
Derik
Post by Derik »
Dear all.
When it is possible and someone can make this ...
The withings scale and perhaps the other options, from this nice hardware....
https://www.withings.com/nl/en/
There is a Api:
https://oauth.withings.com/api+
Hope..
Thanks In advance
Derik
Post by Derik »
And. perhaps...
Near the buienradar from the country NL
Perhaps a button on local level...
https://www.buienradar.nl/weer/nijmegen/nl/2750053
:D :D :D
HansieNL
Post by HansieNL »
Derik wrote:And. perhaps...
:D :D :D
You can create your own map and put it in an iframe. https://www.buienradar.nl/overbuienrada ... s-weerdata
var frames = {}
frames.buienradar = {refreshiframe:10000, height:270, frameurl:"https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.68573&lng=3.89659&overname=2&zoom=8&naam=4321az&size=2&voor=1",width:12}
Add frames.buienradar to one of your colums.
Blah blah blah
Locked
