Page 5 of 48
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Posted: Sunday 01 October 2017 21:23
by sejonr
moroen wrote: Sunday 01 October 2017 17:15
sejonr wrote: Sunday 01 October 2017 10:03
moroen wrote: Friday 29 September 2017 12:14
It appears that the coap-client can't connect to the ikea-gateway. Have you tried testing the coap-client from the command-line?
$ coap-client -k your_key_goes_here coaps://ip/.well-known/core
Regards,
M
Hi M
When i putting in my ip and Key i got this. I am new in Linux so i need help :) I run another Coap-script that i find on the web an could find IKEA lamps. (I removed my IKEA Key)
I using Domoticz V3.8153, Python 3.4, Ikea gateway version 1.1.0015.
coap-client -k "MY Key" coaps://192.168.1.45/.well-known/core
v:1 t:CON c:GET i:190c {} [ ]
<//15001/65541>;ct=0;obs,<//15001/65536>;ct=0;obs,<//15001/65542>;ct=0;obs,<//15001/65544>;ct=0;obs,<//15001/65543>;ct=0;obs,
So, the coap-client works, the next step is to run tradfri.tac from the command-line and post the output...
Regards,
M
Hi M
I got this...When i have stopped the service ikea-tradfri.service
Waiting for connection
Connected from IPv4Address(TCP, '127.0.0.1', 36926)
Data received: b'{"action": "setConfig", "key": "My Key", "gateway": "192.168.1.45", "observe": "True"}'
But when i start the service and restart domoticz i got this!
IKEA-tradfri COAP-adaptor version 0.3 started (command line)!
Unhandled error in Deferred:
Here is the ikea-tradfri.service file. I got the same problem when i dont have "/home/pi" and when i have other than user/groop =root i got COAP-adaptor connection fault.
[Unit]
Description=IKEA Tradfri COAP-adapter
[Service]
Type=simple
Environment=IKEA_HOME=/home/pi/domoticz/plugins/IKEA-Tradfri
ExecStart=/usr/local/bin/twistd --nodaemon \
--rundir=${IKEA_HOME} \
--pidfile=${IKEA_HOME}/twistd.pid \
--python=${IKEA_HOME}/tradfri.tac
User=root
Group=root
Restart=always
[Install]
WantedBy=multi-user.target
Very mutch thanks for your help! I realy want this to work :)
Brgd
R
Posted: Sunday 01 October 2017 21:30
by Ravenbankie
sejonr wrote: Sunday 01 October 2017 21:23
Hi M
Regards,
M
Hi M
[Unit]
[Service]
Type=simple
User=root
Group=root
Restart=always
[Install]
Brgd
R
You need to change the environment path to the path of your specific situation. In my situation it was /home/osmc/domoticz/plugins ..
The user and group needs to be the user and group that have root rights. In my case it is osmc:osmc
Posted: Sunday 01 October 2017 21:35
by sejonr
Hi M
Regards,
M
Hi M
[Unit]
[Service]
Type=simple
User=root
Group=root
Restart=always
[Install]
Brgd
R
A little more information when i run: python3 -i -m pytradfri IP KEY with my IP and KEY
I got this message..............
DEBUG:pytradfri.api.libcoap_api:Executing 192.168.1.45 get ['status']
DEBUG:pytradfri.api.libcoap_api:Received: v:1 t:CON c:GET i:9809 {} [ ]
File "/usr/lib/python3.4/runpy.py", line 170, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.4/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/home/pi/pytradfri/pytradfri/__main__.py", line 19, in <module>
api = api_factory(sys.argv[1], sys.argv[2])
File "/home/pi/pytradfri/pytradfri/api/libcoap_api.py", line 131, in api_facto ry
request(Command('get', ['status']))
File "/home/pi/pytradfri/pytradfri/api/libcoap_api.py", line 78, in request
return _execute(api_commands[0])
File "/home/pi/pytradfri/pytradfri/api/libcoap_api.py", line 72, in _execute
api_command.result = _process_output(return_value, parse_json)
File "/home/pi/pytradfri/pytradfri/api/libcoap_api.py", line 159, in _process_ output
return json.loads(output)
File "/usr/lib/python3.4/json/__init__.py", line 318, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
raise ValueError(errmsg("Expecting value", s, err.value)) from None
ValueError: Expecting value: line 1 column 1 (char 0)
Thank you again :)
Posted: Monday 02 October 2017 15:37
by moroen
Unhandled error in Deffered on startup usually means that the port already is taken, perhaps tradfri.tac is already running?
Try:
$ sudo systemctrl stop ikea-tradfri
$ python3 tradfri.tac
I have just commited a small change to the tradfri.tac, which should give a more informative message if port-taken is the case...
Regards,
M
Posted: Monday 02 October 2017 20:54
by strelniece
Having some problems me too
can controll the lamp using coap-client, so so far so good.
running tradfri.tac gives (with service stopped)
pi@pi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
  File "tradfri.tac", line 2, in <module>
    from twisted.internet import protocol, task, reactor, endpoints
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/reactor.py", line 38, in <module>
    from twisted.internet import default
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/default.py", line 56, in <module>
    install = _getInstallFunction(platform)
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/default.py", line 44, in _getInstallFunction
    from twisted.internet.epollreactor import install
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/epollreactor.py", line 24, in <module>
    from twisted.internet import posixbase
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/posixbase.py", line 18, in <module>
    from twisted.internet import error, udp, tcp
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/tcp.py", line 28, in <module>
    from twisted.internet._newtls import (
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/_newtls.py", line 21, in <module>
    from twisted.protocols.tls import TLSMemoryBIOFactory, TLSMemoryBIOProtocol
  File "/usr/local/lib/python3.4/dist-packages/twisted/protocols/tls.py", line 63, in <module>
    from twisted.internet._sslverify import _setAcceptableProtocols
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/_sslverify.py", line 38, in <module>
    TLSVersion.TLSv1_1: SSL.OP_NO_TLSv1_1,
AttributeError: 'module' object has no attribute 'OP_NO_TLSv1_1'
service start as should. Added Trådfri in hardware but no devices. the log in Domoticz (debugging mode) says:
2017-10-02 20:46:48.315 (Trådfri) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-10-02 20:46:50.271 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-02 20:46:50.271 (Trådfri) Not connected - nextConnect: 3
2017-10-02 20:46:52.281 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-02 20:46:52.281 (Trådfri) Not connected - nextConnect: 2
2017-10-02 20:46:54.286 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-02 20:46:54.286 (Trådfri) Not connected - nextConnect: 1
2017-10-02 20:46:54.286 (Trådfri) Transport set to: 'TCP/IP', 127.0.0.1:1234.
2017-10-02 20:46:54.287 (Trådfri) Connect directive received, action initiated successfully.
2017-10-02 20:46:54.337 (Trådfri) Calling message handler 'onConnect'.
2017-10-02 20:46:54.337 (Trådfri) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-10-02 20:46:56.293 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-02 20:46:56.294 (Trådfri) Not connected - nextConnect: 3
2017-10-02 20:46:58.299 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-02 20:46:58.299 (Trådfri) Not connected - nextConnect: 2
2017-10-02 20:47:00.306 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-02 20:47:00.306 (Trådfri) Not connected - nextConnect: 1
2017-10-02 20:47:00.306 (Trådfri) Transport set to: 'TCP/IP', 127.0.0.1:1234.
Any help?
Posted: Monday 02 October 2017 23:08
by sejonr
moroen wrote: Monday 02 October 2017 15:37
Try:
Regards,
M
Already tryed that and got this then it waits...
Posted: Tuesday 03 October 2017 1:47
by moroen
strelniece wrote: Monday 02 October 2017 20:54 Having some problems me too
Any help?
There's probably an error with the version of openssl, it's been discussed in this thread previously. You might find this link helpfull:
https://github.com/django/daphne/issues/83
It's for django and python 2.x, but there's at least two solutions to try!
Regards,
M
Posted: Tuesday 03 October 2017 1:49
by moroen
sejonr wrote: Monday 02 October 2017 23:08 Already tryed that and got this then it waits...
It probably waits for a return from the coap-client/gateway. It might be a long shot, but have you tried to cycle the power on the gateway? It seems the gateway might hang, while still responding to pings, no coap is returned...
Regards,
M
Posted: Tuesday 03 October 2017 8:32
by strelniece
moroen wrote: Tuesday 03 October 2017 1:47
Any help?
Regards,
M
Ah, thanks, missed that one, but did at least partly solved the problem, but my lamp will not turn up in devices list,
tradfri.tac gives:
pi@automata:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
Connected from IPv4Address(TCP, '127.0.0.1', 58398)
Data received: b'{"key": "xxxxxxxxxxx", "action": "setConfig", "observe": "True", "gateway": "192.168.0.43"}'
Unhandled Error
  File "/usr/local/lib/python3.4/dist-packages/twisted/python/log.py", line 103, in callWithLogger
    return callWithContext({"system": lp}, func, *args, **kw)
  File "/usr/local/lib/python3.4/dist-packages/twisted/python/log.py", line 86, in callWithContext
    return context.call({ILogContext: newCtx}, func, *args, **kw)
  File "/usr/local/lib/python3.4/dist-packages/twisted/python/context.py", line 122, in callWithContext
    return self.currentContext().callWithContext(ctx, func, *args, **kw)
  File "/usr/local/lib/python3.4/dist-packages/twisted/python/context.py", line 85, in callWithContext
    return func(*args,**kw)
--- <exception caught here> ---
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/posixbase.py", line 614, in _doReadOrWrite
    why = selectable.doRead()
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/tcp.py", line 205, in doRead
    return self._dataReceived(data)
  File "/usr/local/lib/python3.4/dist-packages/twisted/internet/tcp.py", line 211, in _dataReceived
    rval = self.protocol.dataReceived(data)
  File "tradfri.tac", line 69, in dataReceived
    self.factory.initGateway(self, command['gateway'], command['key'], command['observe'])
  File "tradfri.tac", line 250, in initGateway
    for group in self.groups:
builtins.TypeError: 'Group' object is not iterable
Domoticz log gives:
2017-10-03 08:19:03.212 PluginSystem: Restarting I/O service thread.
2017-10-03 08:19:03.213 (Trådfri) Calling message handler 'onDisconnect'.
2017-10-03 08:19:03.213 (Trådfri) Device has disconnected
2017-10-03 08:19:04.766 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-03 08:19:04.766 (Trådfri) Not connected - nextConnect: 3
2017-10-03 08:19:06.773 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-03 08:19:06.773 (Trådfri) Not connected - nextConnect: 2
2017-10-03 08:19:08.777 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-03 08:19:08.777 (Trådfri) Not connected - nextConnect: 1
2017-10-03 08:19:08.777 (Trådfri) Transport set to: 'TCP/IP', 127.0.0.1:1234.
2017-10-03 08:19:08.777 PluginSystem: Starting I/O service thread.
2017-10-03 08:19:08.778 (Trådfri) Connect directive received, action initiated successfully.
2017-10-03 08:19:08.828 (Trådfri) Calling message handler 'onConnect'.
2017-10-03 08:19:08.828 (Trådfri) Connected successfully to: 192.168.0.43
2017-10-03 08:19:08.828 (Trådfri) Received 61 bytes of data:.
2017-10-03 08:19:08.828 (Trådfri) 7b 22 73 74 61 74 75 73 22 3a 20 22 4f 6b 22 2c 20 22 61 63 {"status":."Ok",."ac
2017-10-03 08:19:08.828 (Trådfri) 74 69 6f 6e 22 3a 20 22 63 6c 69 65 6e 74 43 6f 6e 6e 65 63 tion":."clientConnec
2017-10-03 08:19:08.828 (Trådfri) 74 22 2c 20 22 76 65 72 73 69 6f 6e 22 3a 20 22 30 2e 33 22 t",."version":."0.3"
2017-10-03 08:19:08.829 (Trådfri) 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. }
2017-10-03 08:19:08.829 (Trådfri) Calling message handler 'onMessage'.
2017-10-03 08:19:08.829 (Trådfri) Received: b'{"status": "Ok", "action": "clientConnect", "version": "0.3"}'
2017-10-03 08:19:09.029 (Trådfri) Sending 97 bytes of data:.
2017-10-03 08:19:09.029 (Trådfri) 7b 22 6b 65 79 22 3a 20 22 63 74 4c 69 54 62 62 64 74 4f 49 {"key":."xxxxxxxxxx
2017-10-03 08:19:09.029 (Trådfri) 61 67 6c 45 43 22 2c 20 22 61 63 74 69 6f 6e 22 3a 20 22 73 xxx",."action":."s
2017-10-03 08:19:09.029 (Trådfri) 65 74 43 6f 6e 66 69 67 22 2c 20 22 6f 62 73 65 72 76 65 22 etConfig",."observe"
2017-10-03 08:19:09.030 (Trådfri) 3a 20 22 54 72 75 65 22 2c 20 22 67 61 74 65 77 61 79 22 3a :."True",."gateway":
2017-10-03 08:19:09.030 (Trådfri) 20 22 31 39 32 2e 31 36 38 2e 31 31 2e 34 33 22 7d .. .. .. ."192.168.0.43"}
2017-10-03 08:19:09.230 PluginSystem: Restarting I/O service thread.
2017-10-03 08:19:09.231 (Trådfri) Calling message handler 'onDisconnect'.
2017-10-03 08:19:09.231 (Trådfri) Device has disconnected
2017-10-03 08:19:10.784 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-03 08:19:10.784 (Trådfri) Not connected - nextConnect: 3
2017-10-03 08:19:12.788 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-03 08:19:12.788 (Trådfri) Not connected - nextConnect: 2
2017-10-03 08:19:14.792 (Trådfri) Calling message handler 'onHeartbeat'.
2017-10-03 08:19:14.792 (Trådfri) Not connected - nextConnect: 1
2017-10-03 08:19:14.792 (Trådfri) Transport set to: 'TCP/IP', 127.0.0.1:1234.
2017-10-03 08:19:14.793 PluginSystem: Starting I/O service thread.
2017-10-03 08:19:14.793 (Trådfri) Connect directive received, action initiated successfully.
regards
F
Posted: Tuesday 03 October 2017 16:36
by sejonr
moroen wrote: Tuesday 03 October 2017 1:49
Regards,
M
It didnt work. I m sorry I give up :( I think i will use another solution here on this forum instead.
Posted: Tuesday 03 October 2017 19:24
by Lars65
I have manage to get it working, except for domoticz where I get this:
2017-10-03 19:09:10.263 (Ikea) Connected successfully to: 192.168.1.233
2017-10-03 19:09:10.314 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:09:12.669 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:09:24.092 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:09:34.113 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:09:42.130 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:09:52.099 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:12:12.123 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:12:16.131 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:12:28.105 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-10-03 19:12:38.124 Error: (Ikea) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Ex
in putty i get this:
pi@DomoticzComplete:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
Connected from IPv4Address(TCP, '127.0.0.1', 51072)
Data received: b'{"gateway": "192.168.1.233", "observe": "True", "key": "cpsallg GYwgxbeMz", "action": "setConfig"}'
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65540, 'Name' : 'Lottas lampa', 'State': False, 'Level': 254, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65541, 'Name' : 'Lars lampa', 'State': False, 'Level': 254, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65541, 'Name' : 'Lars lampa', 'State': True, 'Level': 254, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65540, 'Name' : 'Lottas lampa', 'State': True, 'Level': 254, 'Hex': None}]}
Error in annouce:
any suggestions?
Posted: Tuesday 03 October 2017 21:14
by moroen
Lars65 wrote: Tuesday 03 October 2017 19:24 I have manage to get it working, except for domoticz where I get this:
any suggestions?
You have to match the branch of domoticz with the correct branch of the plugin! :)
The plugin's master branch should work with the master-branch of domoticz (aka latest stable) and the development-branch of the plugin is for the development-branch of domoticz (aka. latest beta)...
From the error message, I think your're using the development branch of the plugin with the latest domoticz stable...
Regards,
M
Posted: Tuesday 03 October 2017 21:16
by moroen
sejonr wrote: Tuesday 03 October 2017 16:36
Sorry that it didn't work out, if tradfri.tac hangs after setConfig, it's waiting for a reponse from the coap-client...
Regards,
M
Posted: Tuesday 03 October 2017 22:59
by sejonr
moroen wrote: Tuesday 03 October 2017 21:16
Regards,
M
I just controlled one of my IKEA-Lamps with a coap-client command :) So the coap client works but when i run pytradfri commands i get lots of failure like this.....Is it something about ownership? Or a library that is missing?
pi@raspberrypi:~/pytradfri $ sudo python3 -i -m pytradfri 192.168.1.45 sNglOCRRD 0lHRXO0
DEBUG:pytradfri.api.libcoap_api:Received: v:1 t:CON c:GET i:bc25 {} [ ]
Posted: Tuesday 03 October 2017 23:50
by Ravenbankie
i'm also pretty lost.
when i run python3 tradfri.tac i get the data below. So for all i know it's working including the plugin. right?
Connected from IPv4Address(TCP, '127.0.0.1', 35828)
Data received: b'{"action": "setConfig", "gateway": "192.168.1.10", "key": "CODE", "observe": "False"}'
Data received: b'{"action": "getLights"}'
Device settings not found for TRADFRI bulb GU10 W 400lm. Creating defaults!
Device settings not found for TRADFRI bulb E27 opal 1000lm. Creating defaults!
Device settings not found for TRADFRI bulb E27 CWS opal 600lm. Creating defaults        !
Device settings not found for TRADFRI bulb E14 W op/ch 400lm. Creating defaults!
Device settings not found for TRADFRI bulb E27 W opal 1000lm. Creating defaults!
{"action": "getLights", "status": "Ok", "result": [{"DeviceID": 65546, "Name": "        TRADFRI bulb GU10 W 400lm 3", "Type": "Light", "Dimmable": true, "HasWB": true,        "HasRGB": false}, {"DeviceID": 65539, "Name": "lamp2 tv", "Type": "Light", "Dimm        able": true, "HasWB": true, "HasRGB": false}, {"DeviceID": 65540, "Name": "lamp1        tv", "Type": "Light", "Dimmable": true, "HasWB": true, "HasRGB": false}, {"Devi        ceID": 65547, "Name": "hal", "Type": "Light", "Dimmable": true, "HasWB": true, "        HasRGB": false}, {"DeviceID": 65545, "Name": "TRADFRI bulb GU10 W 400lm 4", "Typ        e": "Light", "Dimmable": true, "HasWB": true, "HasRGB": false}, {"DeviceID": 655        48, "Name": "eettafel", "Type": "Light", "Dimmable": true, "HasWB": true, "HasRG        B": false}, {"DeviceID": 65537, "Name": "kleurlamp woonkamer", "Type": "Light",        "Dimmable": true, "HasWB": true, "HasRGB": false}, {"DeviceID": 65543, "Name": "        trapkast", "Type": "Light", "Dimmable": true, "HasWB": true, "HasRGB": false}, {        "DeviceID": 65542, "Name": "wc beneden", "Type": "Light", "Dimmable": true, "Has        WB": true, "HasRGB": false}, {"DeviceID": 65538, "Name": "overloop", "Type": "Li        ght", "Dimmable": true, "HasWB": true, "HasRGB": false}, {"DeviceID": 176742, "N        ame": "Group - slaapkamer", "Type": "Group", "Dimmable": true, "HasWB": false},        {"DeviceID": 134152, "Name": "Group - gang", "Type": "Group", "Dimmable": true,        "HasWB": false}, {"DeviceID": 173639, "Name": "Group - groep woonkamer", "Type":        "Group", "Dimmable": true, "HasWB": false}, {"DeviceID": 147804, "Name": "Group        - Groep wc en trapkast", "Type": "Group", "Dimmable": true, "HasWB": false}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65546, 'Name'        : 'TRADFRI bulb GU10 W 400lm 3', 'State': False, 'Level': 35, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65539, 'Name'        : 'lamp2 tv', 'State': True, 'Level': 68, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65540, 'Name'        : 'lamp1 tv', 'State': True, 'Level': 73, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65547, 'Name'        : 'hal', 'State': False, 'Level': 35, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65545, 'Name'        : 'TRADFRI bulb GU10 W 400lm 4', 'State': False, 'Level': 35, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65548, 'Name'        : 'eettafel', 'State': True, 'Level': 76, 'Hex': 'f1e0b5'}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65537, 'Name'        : 'kleurlamp woonkamer', 'State': True, 'Level': 152, 'Hex': '0'}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65543, 'Name'        : 'trapkast', 'State': False, 'Level': 81, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65542, 'Name'        : 'wc beneden', 'State': True, 'Level': 71, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 65538, 'Name'        : 'overloop', 'State': False, 'Level': 10, 'Hex': None}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 176742, 'Name        ': 'slaapkamer', 'State': False, 'Level': 0}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 134152, 'Name        ': 'gang', 'State': False, 'Level': 0}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 173639, 'Name        ': 'groep woonkamer', 'State': False, 'Level': 0}]}
{'action': 'deviceUpdate', 'status': 'Ok', 'result': [{'DeviceID': 147804, 'Name        ': 'Groep wc en trapkast', 'State': False, 'Level': 0}]}
Disconnected
When i add it in domoticz (see below) it won't add the devices. and it looks like won't do anything. How can i find the error in domoticz?
i'm on the AIOCOAP branch with Python 3.6.2
2017-10-03 23:58:21.036 (tradfri) Calling message handler 'onConnect'.
2017-10-03 23:58:21.036 (tradfri) Connected successfully to: 192.168.1.10
2017-10-03 23:58:22.039 (tradfri) Sending 96 bytes of data:.
2017-10-03 23:58:22.039 (tradfri) 7b 22 61 63 74 69 6f 6e 22 3a 20 22 73 65 74 43 6f 6e 66 69 {"action":."setConfi
2017-10-03 23:58:22.039 (tradfri) 67 22 2c 20 22 67 61 74 65 77 61 79 22 3a 20 22 31 39 32 2e g",."gateway":."192.
2017-10-03 23:58:22.039 (tradfri) 31 36 38 2e 31 2e 31 30 22 2c 20 22 6b 65 79 22 3a 20 22 50 168.1.10",."key":."P
2017-10-03 23:58:22.039 (tradfri) 36 50 36 67 30 37 79 7a 5a 57 6f 65 53 44 34 22 2c 20 22 6f code_serial",."o
2017-10-03 23:58:22.039 (tradfri) 62 73 65 72 76 65 22 3a 20 22 54 72 75 65 22 7d .. .. .. .. bserve":."True"}
2017-10-03 23:58:30.507 (tradfri) Calling message handler 'onHeartbeat'.
2017-10-03 23:58:32.513 (tradfri) Calling message handler 'onHeartbeat'.
2017-10-03 23:58:34.520 (tradfri) Calling message handler 'onHeartbeat'.
2017-10-03 23:58:36.526 (tradfri) Calling message handler 'onHeartbeat'.
Posted: Wednesday 04 October 2017 0:34
by moroen
sejonr wrote: Tuesday 03 October 2017 22:59
I'm not able to determine why pytradfri fails, but this line suggest that the library doesn't get a response it can decode from the coap-client. Just to make sure, which version of coap-client do you have?
Regards,
M
Posted: Wednesday 04 October 2017 9:30
by sejonr
moroen wrote: Wednesday 04 October 2017 0:34
Regards,
M
I used the version fr.o.m. This URL
https://learn.pimoroni.com/tutorial/san ... om-your-pi
Brgd
R
Posted: Wednesday 04 October 2017 9:40
by moroen
sejonr wrote: Wednesday 04 October 2017 9:30
Ah, that might be the problem. Please try to install coap-client using the instructions/script from pytradfri:
https://github.com/ggravlingen/pytradfr ... -client.sh
Regards,
M
Posted: Wednesday 04 October 2017 11:12
by sejonr
moroen wrote: Wednesday 04 October 2017 9:40
Regards,
M
Hi When i did that i have some error during installation. Can i use sudo before make install ?
Tanks :)
Regards R
Posted: Wednesday 04 October 2017 13:01
by globulus
Hi moroen,
I had the same error than andi2016 :
python3 tradfri.tac produces
Disconnected
coap-client -k xxx coaps://192.168.1.108/15004/
returns
v:1 t:CON c:GET i:c822 {} [ ]
[159174]
and
coap-client -k xxx coaps://192.168.1.108/.well-known/core
returns
v:1 t:CON c:GET i:d62f {} [ ]
<//15001/65537>;ct=0;obs,<//15001/65536>;ct=0;obs,<//15004/159174>;ct=0;obs,<//15005/159174>;ct=0;obs,<//15005/159174/211086>;ct=0;obs,<//15005/159174/218489>;ct=0;obs,<//15005/159174/208756>;ct=0;obs,<//15001>;ct=0;obs,<//15001/reset>;ct=0,<//status>;ct=0;obs,<//15005>;ct=0;obs,<//15004>;ct=0;obs,<//15004/add>;ct=0,<//15004/remove>;ct=0,<//15006>;ct=0;obs,<//15011/15012>;ct=0;obs,<//15011/9034>;ct=0,<//15011/9030>;ct=0,<//15011/9031>;ct=0,<//15011/9063>;ct=0,<//15011/9033>;ct=0,<//15010>;ct=0;obs
As I added a second group of bulbs to the gateway, it worked !
So the problem seems to be linked to the number of groups.
However, in Domoticz, I added a group from the devices list with the green arrow.
I tried successfuly to change the dim level in the switch tab once and then domoticz crashed with a segmentation fault.
Now Domoticz does not start anymore :
2017-10-04 12:48:19.102  (Tradfri - Group - chambre) Updating device from 0:'1' to have values 0:'1'.
2017-10-04 12:48:19.105  (Tradfri) Received 121 bytes of data:.
2017-10-04 12:48:19.105  (Tradfri)     7b 22 73 74 61 74 75 73 22 3a 20 22 4f 6b 22 2c 20 22 61 63     {"status":."Ok",."ac
2017-10-04 12:48:19.106  (Tradfri)     74 69 6f 6e 22 3a 20 22 64 65 76 69 63 65 55 70 64 61 74 65     tion":."deviceUpdate
2017-10-04 12:48:19.106  (Tradfri)     22 2c 20 22 72 65 73 75 6c 74 22 3a 20 5b 7b 22 4e 61 6d 65     ",."result":.[{"Name
2017-10-04 12:48:19.106  (Tradfri)     22 3a 20 22 73 61 6c 6f 6e 22 2c 20 22 53 74 61 74 65 22 3a     ":."salon",."State":
2017-10-04 12:48:19.107  (Tradfri)     20 74 72 75 65 2c 20 22 4c 65 76 65 6c 22 3a 20 35 37 2c 20     .true,."Level":.57,.
2017-10-04 12:48:19.107  (Tradfri)     22 44 65 76 69 63 65 49 44 22 3a 20 31 35 39 31 37 34 7d 5d     "DeviceID":.159174}]
2017-10-04 12:48:19.107  (Tradfri)     7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     }
2017-10-04 12:48:19.108  (Tradfri) Calling message handler 'onMessage'.
2017-10-04 12:48:19.108  (Tradfri) Received: b'{"status": "Ok", "action": "deviceUpdate", "result": [{"Name": "salon", "State": true, "Level": 57, "DeviceID": 159174}]}'
2017-10-04 12:48:19.109  (Tradfri - Group - salon) Updating device from 1:'22' to have values 1:'22'.
Erreur de segmentation
