Page 5 of 11
Re: framb0ise v2 - awesome new dashboard!
Posted: Tuesday 25 April 2017 13:07
by tontze
safi78 wrote:tontze wrote:
Blinds still dotn have control over it, i have "blinds inverted" control
That's correct. This project is 2 days live.
If you want to add it yourself, be my guest, otherwise add a request to the 'issues' page? Like suggested in the first post? That way we can keep track of all the work we still have to do, Rome wasn't built in 1 day
Yes im sry, i got impression that it was allready added after jvdz presented code for it
Posted: Tuesday 25 April 2017 16:27
by safi78
No prob. But we don't both don't have blinds inverted. Could you send a json file of that device? Then we can implement it for you?
Posted: Tuesday 25 April 2017 16:43
by safi78
No more config.js
- Screen Shot 2017-04-25 at 16.26.19.png (247.15 KiB) Viewed 3331 times
Posted: Tuesday 25 April 2017 17:17
by qwerk
nicely done, where does framboise store the password?
and the thicks?
Posted: Tuesday 25 April 2017 17:57
by tontze
"ActTime" : 1493135755,
"ServerTime" : "2017-04-25 18:55:55",
"Sunrise" : "05:31",
"Sunset" : "21:13",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Open",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 6,
"HardwareName" : "RFLink",
"HardwareType" : "RFLink Gateway USB",
"HardwareTypeVal" : 46,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "00D04282",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-25 08:00:02",
"Level" : 99,
"LevelInt" : 99,
"MaxDimLevel" : 100,
"Name" : "Blinds",
"Notifications" : "false",
"PlanID" : "4",
"PlanIDs" : [ 4 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "BrelMotor",
"SwitchType" : "Blinds Inverted",
"SwitchTypeVal" : 6,
"Timers" : "true",
"Type" : "Light/Switch",
"TypeImg" : "blinds",
"Unit" : 193,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "966",
"YOffset" : "219",
"idx" : "162"
"status" : "OK",
"title" : "Devices"
Do you mean this json ?
-T
Posted: Tuesday 25 April 2017 18:18
by jvdz
marcotrumpet wrote:Hi
Just started yesterday with that awesome dashboard. No problem at all, but.. if I connect to http://myddns:port/framb0ise when I'm under wifi it's ok, if I go out I can connect to the page but nothing is listed.. It seems that I don't have any roomplans.. If I connect to domoticz main page with the same ddns everythings works fine.
Did you also put that host ( http://myddns:port) in config.js?
Jos
Posted: Tuesday 25 April 2017 18:23
by jvdz
@tontze ,
Am I correct to assume that this blind doesn't have an percentage option, but merely UP/DOWN ( and possibly STOP)?
Jos
Re: RE: Re: framb0ise v2 - awesome new dashboard!
Posted: Tuesday 25 April 2017 18:26
by marcotrumpet
jvdz wrote:marcotrumpet wrote:Hi
Jos
Yes I did. But the domoticz local port and the external one I use eith ddns are different. If I set in config "http://ddns:domoticzinternalport" or "http://ddns:domoticzexternalport" nothing appen
Inviato dal mio SM-G950F utilizzando Tapatalk
EDIT
My bad.. using "http://ddns:externalport" work!
thanks mate
Posted: Tuesday 25 April 2017 18:42
by Maikie
For my information, updating just by cloning from git again with this command?
git clone https://github.com/safi78/framb0ise
Posted: Tuesday 25 April 2017 19:09
by qwerk
my smoke detectors are red again, without smoke or fire
Posted: Tuesday 25 April 2017 20:06
by jvdz
marcotrumpet wrote:jvdz wrote:marcotrumpet wrote:Hi
EDIT
thanks mate
Sounds great, but you do realize that this setup is using one single static setup at this moment, so it can either be the internal or external port.
Maybe we should simply use the original URL's ip:port.
Jos
Posted: Tuesday 25 April 2017 22:49
by safi78
Maikie wrote:For my information, updating just by cloning from git again with this command?
yes. with the new settings window your settings will be stored for future updates.
Posted: Tuesday 25 April 2017 22:50
by safi78
qwerk wrote:my smoke detectors are red again, without smoke or fire
Something went wrong with our first Pull Request, some code got reverted to older state. I just fixed this for you (again)
Posted: Tuesday 25 April 2017 22:52
by safi78
qwerk wrote:nicely done, where does framboise store the password?
and the thicks?
All stuff is stored in 'local storage'. very safe and secure, only YOUR browser can access this, nothing is accessible for others or send over.
It's like a very permanent cookie
Posted: Tuesday 25 April 2017 23:07
by CaesarPL
Good evening, first of all - great job, thank you very much!
Excuse me for silly question, but how can I configure Traffic and Weather? Does it work only for Netherlands?
EDIT:
Ahhhh, DarkSky is missing. But what about Traffic?
Posted: Tuesday 25 April 2017 23:09
by safi78
CaesarPL wrote:Good evening, first of all - great job, thank you very much!
And, if you can provide us with a good api for a source for Traffic and Weather in $yourcountry i'd gladly take a look?
Posted: Tuesday 25 April 2017 23:10
by safi78
EDIT:
What do you mean with your EDIT?
Posted: Tuesday 25 April 2017 23:26
by CaesarPL
safi78 wrote:CaesarPL wrote:Good evening, first of all - great job, thank you very much!
EDIT:
Silly again and tired a bit. I thought that I don't have Weather as I haven't configured DarkSky, yet. Now I understand that Weather and Traffic works only in Netherlands. Duh, I always wanted to move to Netherlands from Poland...
Posted: Tuesday 25 April 2017 23:29
by safi78
CaesarPL wrote:safi78 wrote:CaesarPL wrote:Good evening, first of all - great job, thank you very much!
EDIT:
dobry wieczór
yeah I should doublecheck on the darksystuff an generate a warning ..
So, if you have a polish api, i can see what i can do? I'll need some help translating though, but a very close friend of mine is half Polish, that shouldn't be a problem
Posted: Tuesday 25 April 2017 23:36
by CaesarPL
safi78 wrote:
dobry wieczór
+1 ! Even letters are fine!
Unfortunately, I don't know any API that could work...
