Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Kerel
Re: Easy Domoticz to Alexa Integration
Post by Kerel »
Madgeni wrote:weird! can you post a screenshot of the thermostat from Devices? What's the Type and SubType?
Device:
Madgeni wrote:also, can you rerun a discovery, and post a timestamp in here?
09:31, CEST time.
Madgeni
Post by Madgeni »
ok, so the Type is "Heating", which isn't currently discovered. I'll change it, and we'll see what happens!
Kerel
Post by Kerel »
Great! Will test later on :).
Madgeni
Post by Madgeni »
Can you try now?
IDANIT
Post by IDANIT »
Great Job, Keep up. Can't add a review "We were unable to submit your review at this time."
Madgeni
Post by Madgeni »
Thanks IDANIT - can I ask you to try again when you get a chance? Cheers :)
renerene
Post by renerene »
no ha-bridge software to maintain and host.
more out of the box.
In that case I'll keep with HA bridge, for the moment.
Madgeni
Post by Madgeni »
I'm curious as to why?
Floppy
Domoticz version: 3.8144
Post by Floppy »
Hey Madgeni, could you please help me. i cannot get controlicz working.
Got https working and can login remote.
My switches and scenes are in a room plan but when i discover in Alexa nothing is found.
I can see your server ip in the logging but only once! Would expect your ip every time i hit discover in Alexa.
Madgeni
Post by Madgeni »
Hi Floppy - i'll look now. Can you PM me the email address you've used?
Floppy
Post by Floppy »
THX for your PM. I cannot reply probably because this was my first post :)
Changed my password and did a reboot but still no devices found.
Madgeni
Post by Madgeni »
pleased to announce that Set Colour (Alexa - change the kitchen light colour to red) now works :) Please try and let me know!
Madgeni
Post by Madgeni »
Floppy wrote:THX for your PM. I cannot reply probably because this was my first post :)
Think this might be an ISP issue :(
Alcloud
Post by Alcloud »
@Madgeni
Set Colour works now like a charm! Thank you very much!
Madgeni
Post by Madgeni »
Glad it's of use - can I ask that you leave a review on Amazon? Thanks!
renerene
Post by renerene »
1)I don't have roomplans. Making them, -to me- sounds like similar effort to maintain HA bridge. Both are simple tasks, but hey, what's the win?
Also, with one Alexa device I want to command my entire house, so why roomplans?
2)Disadvantages of HAbridge are not tackled:
- the commands are not intuitive. "Alexa,turn door on" should be "Alexa, lower the door screen".
- it's been long ago since HA installation, but if I remember correct, not all keywords were allowed (limited, try and error) and I could not get it to more then one keyword, so "screens kitchen" did not work
I use HA Bridge on a daily basis to switch screens and lights.
IDANIT
Post by IDANIT »
renerene wrote: 1)I don't have roomplans. Making them, -to me- sounds like similar effort to maintain HA bridge. Both are simple tasks, but hey, what's the win?
I think You missing the point. We talking this kind of roomplans.
Domoticz (6).png (334.86 KiB) Viewed 2823 times
As You can see I have three rooms which I can steer with one alexa. Adding room and devices to it, is easy like 123... and it takes no more than couple of seconds.
Madgeni
Post by Madgeni »
Thanks IDANIT - to be fair to renerene, Alexa doesn't currently have the language for open/close/up/down - but they will come. I also believe (i've never used the HA bridge myself) that the native skill has more functionality than the bridge, and again, more will come!
Kerel
Post by Kerel »
Madgeni wrote:Can you try now?
Got my Thermostat discovered now and I'm able to read the temperature, thanks! But I'm not able to set the temperature with Alexa. What info should I share with you to have a look at this? I'm using a Honeywell thermostat of type "Round Connected" and using the "Evohome" plugin in Domoticz.
Madgeni
Post by Madgeni »
dropped you a PM
