[Plugin now available in Beta] Help with Yeelight Bulb
weiweipossible
Re: Help with Yeelight Bulb
Post by weiweipossible »
corbin wrote:
weiweipossible wrote:Hi all,
I'm a developer from Yeelight and I'm so glad that many people here like Yeelight bulbs!
Good to see you here :)
:D Actually it's you who bring me here!
Derik
Post by Derik »
dear...
Looks the Yeelight is killing my Domoticz....
When i remove the light in my lan domoticz is crashing....
And it is turning in to a loop of crashes.
Yeelight hardware off, domoticz stable...
corbin
Post by corbin »
ok I will investigate further and hopefully get it stable.
its been running stable on my Linux VM and Windows, but just taking a guess there could be a memory leak that shows up faster on Raspberry Pi. (I'm very much a beginner with c++)
farhanito
Post by farhanito »
Take your time.
What you're doing is great, I'm sure we'll get there.
domer
Post by domer »
Holy sh!t corbin&weiweipossible! Does this also work on Yeelight led strips?
deennoo
Post by deennoo »
Just a question who isn't clear for me :
Does e27 rgb bulb are able to provid warm white ?
http://domo-attitude.fr
Derik
Post by Derik »
deennoo wrote:Just a question who isn't clear for me :
When you get the goed setting yes..
RGBW all the colors you want
Derik
Post by Derik »
corbin wrote:ok I will investigate further and hopefully get it stable.
Did you change something..
Now stable without a bulb in my lan
corbin
Post by corbin »
Nothing changed publicly as yet, But I have been testing on a Raspberry Pi image running in QEMU, seems stable but slow - don't know if that is normal with the VM or not.
Are you saying that when you have a Yeelight device added in Domoticz, but you then remove the physical bulb from your network, that it causes a problem?
corbin
Post by corbin »
domer wrote:Holy sh!t corbin&weiweipossible! Does this also work on Yeelight led strips?
Not yet, but it will support the strip light in the future.
deennoo
Post by deennoo »
Ok thx will get one for lab office
weiweipossible
Are you talking about the old BLE light strip? No, it doesn't.
If you are talking about our new WiFi light strip, yes it is. We have already released the strip in Chinese market, I believe you will get the strip very soon through some channel.
Besides that, all Yeelight further WiFi product will support the same open API.
Derik
Post by Derik »
Some idea what.. can i order this...??
Derik
Post by Derik »
corbin wrote:Nothing changed publicly as yet, But I have been testing on a Raspberry Pi image running in QEMU, seems stable but slow - don't know if that is normal with the VM or not.
Yes i added the hardware.[ on my CB2 [ like RPI ] ]
Test a bulb works oke.
Only when i remove the bulb in my lan, domoticz still crashing.
Derik
Post by Derik »
@ weiweipossible
Could you please make working Api ith a color, for a http action.
Like the hue script;
curl -H "Accept: application/json" -X PUT --data '{"on": true,"bri": 500,"hue": 13088,"sat": 212,"xy": [0.5128,0.4147],"ct": 467,"alert": "none","effect": "none","colormode": "xy","reachable": true}' http://192.168.5.36/api/newdeveloper/lights/4/state
With this option the bulb is always 1 color..
domer
Post by domer »
You really got me startled with your comment so I had to double check what I had ordered and it luckily was WiFi strip...atleast seller says so :lol:. Anyway thumps up for this!
Good to hear!
weiweipossible
Derik wrote:@ weiweipossible
Sorry, I'm afraid we can't do that. We choose to implement the open API in a simple way (Restful API (what you asked for) is a bit heavier because you have to implement HTTP layer on top TCP. This is OK and suitable for a gateway or hub, but it's too heavy for a bulb).
Besides that, if we implement the same form of API, we may receive a letter from Philips' lawyer ... just like when we develop this bulb using the everyone-is-using PWM technique ...
corbin
Post by corbin »
Derik, can you put these commands in a bash script and then call from Domoticz? In a way it is better than using HTTP, and works in Linux.
sunrise (change IP address for bulb)
echo -ne '{"id":1, "method":"start_cf", "params":[3,1,"50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"]}\r\n' | nc -w1 192.168.5.14 55443
turn on and set to color (change 65280 to the color you want)
echo -ne '{"id":1,"method":"set_scene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.14 55443
Derik
Post by Derik »
mm
Did make a dummy for the scriptcommand
Changed your ip to my ip [ ido have the 5 range to :-) ]
Did make the file:
Dit put the script:
did make the xxx on the right place:
The light is working with his own switch correct..
Only when i push the dummy switch with the script there is no thing happening...
farhanito
Post by farhanito »
Does the script works in terminal? Maybe nc isn't installed
