Page 5 of 123
Posted: Wednesday 21 December 2016 14:05
by ERRORR2
I will try, but I never did it before)
Posted: Wednesday 21 December 2016 20:43
by levynger
Excellent work!
i been working on Beta 17/12 so far seems very stable and works excellent.
i have noticied 2 things though:
The door sensor after 1 minute will send "Closed" message (or earlier if closed of course..)
this means i cant create a notification if the door is open for 10 minute... 1 minute is the longer..
the motion sensor will not update triggers for less then 60 seconds periods, for some implementation i guess its more than enough.
Just got the humidity sensor.. cant wait for the next update with this sensor support included..
Posted: Wednesday 21 December 2016 22:15
by deennoo
To users who got zigbee wall plug, can you confirm that plug is a part of zigbee network and act as a network extender ?
Posted: Wednesday 21 December 2016 22:18
by pavelbor
deennoo wrote:To users who got zigbee wall plug, can you confirm that plug is a part of zigbee network and act as a network extender ?
How we can know/confirm that?
Posted: Wednesday 21 December 2016 22:20
by corbin
It is easier to compile on Linux following the guide in the Wiki, you could setup a VM to test with.
With the way Christmas is going here, I won't have time to do anymore for a week.
Posted: Wednesday 21 December 2016 23:13
by deennoo
pavelbor wrote:deennoo wrote:To users who got zigbee wall plug, can you confirm that plug is a part of zigbee network and act as a network extender ?
On zigbee always powered device have to be a part and extender of the mesh network, if a sensor is "connected" to it, message have to go like this
Sensor->plug->gateway
Gateway is the coordinator
Plug acting like a repeter/router
Batterie device are end network device
Put a sensor (switch/door/pir/temp) out of the network range, and put a wallswitch on halfway between the gateway and the sensor and check if sensor is reported or not.
Posted: Friday 23 December 2016 8:54
by ERRORR2
Compiled! And now I can see my socket) Thanks! Waiting for build, allowing to control)
Posted: Friday 23 December 2016 9:03
by pavelbor
Hello, what about temp&humidity sensors, do you see them ?
Posted: Friday 23 December 2016 10:35
by ERRORR2
No, I can't see my temp&humidity sensor, only zigbee socket.
Posted: Friday 23 December 2016 15:12
by tiboo86
Corbin said that he had a few lines of codes to finalize before he could put it online to be able to retrieve the information of the temprétaures & humidity sensors.
You have to be patient and corbin has already done a very good job
For information, thumb those who would have a problem with their gateway.
The first version of the gateway released before 2016, does not have the function LAN developper.
A gateway must be left after 2016 or the AQARA version.
Posted: Saturday 24 December 2016 18:57
by ZEMI
I've added Gateway as in instruction
https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara) but nothing appeared in "Devices". With Yeelight bulbs it's all ok. I need to enter this password somewhere?
- Spoiler: show
- Xiaomi_01.png (31.96 KiB) Viewed 4644 times
Sorry for noob question) May be i need to download any plugin? I use the latest beta.
Posted: Saturday 24 December 2016 21:06
by levynger
ZEMI wrote:I've added Gateway as in instruction
- Spoiler: show
No password needed.
did you go to "Switches" tab and press Learn Light/Switch ? you have 5 seconds to press the switch, or buttons on the MI sensors (door, motion etc)
it should recognize them during the learning time appears on screen.
Posted: Saturday 24 December 2016 22:42
by ZEMI
I've tried, but nothing, it even doesn't see gateway. May be i can set somewhere is't IP manually?
- Spoiler: show
- shot_161225_003417.png (67.02 KiB) Viewed 4622 times
- shot_161225_003433.png (99.65 KiB) Viewed 4622 times
Posted: Sunday 25 December 2016 22:24
by icibt
- Spoiler: show
I have the same problem. Added my Yeelight's without a problem... but can't add my Gateway. Did you found a solution?
Posted: Sunday 25 December 2016 22:35
by Coldman
icibt wrote:ZEMI wrote:I've added Gateway as in instruction
- Spoiler: show
I had the same problem on Windows 10x64, under Ubuntu everything is working.
Отправлено с моего MI PAD 2 через Tapatalk
Posted: Sunday 25 December 2016 23:16
by ZEMI
icibt wrote: I have the same problem. Added my Yeelight's without a problem... but can't add my Gateway. Did you found a solution?
No, i don't, also Windows 10 x64
Posted: Monday 26 December 2016 0:00
by arkoko
levynger wrote:The door sensor after 1 minute will send "Closed" message (or earlier if closed of course..)
I confirm that bug and it's a nasty restriction using door sensor with Domoticz.
Just tested with original MiHome app and there sensor stay "open" as long is it open.
Posted: Monday 26 December 2016 2:09
by Coldman
arkoko wrote:levynger wrote:The door sensor after 1 minute will send "Closed" message (or earlier if closed of course..)
I confirm this bug too, window is open still but the sensor has status "off" after 1 minute in log.
Отправлено с моего ONE A2001 через Tapatalk
Posted: Tuesday 27 December 2016 6:44
by corbin
Cool! Please compile from
https://github.com/corbinmunce/domoticz again and you (hopefully) will have control of your socket. As usual you will need to fully refresh your browser cache, and then add the Xiaomi Gateway again with the gateway settings (password, ip, port - only the password needs to be correct).
Also door sensors should now continue to detect as open, when they are left open.
Temp and battery sensors are not quite done yet.
Posted: Tuesday 27 December 2016 6:55
by corbin
For anyone having no devices being found, please ensure your cache is cleared. If you are using Chrome, try
https://chrome.google.com/webstore/deta ... kbap?hl=en as recommended by apazga.
I use Chrome for development, with cache disabled under the network tab, but it still seems to cache sometimes which is a pain.
