Dashticz - Module - Garbage collector Topic is solved
Enz0jacco
Re: Dashticz - Module - Garbage collector
Post by Enz0jacco »
Enz0jacco wrote: Wednesday 09 December 2020 13:26
Lokonli wrote:
Enz0jacco wrote: Wednesday 09 December 2020 9:00 with the new update my break line between the trash type and date is not working anymore. I tried to put the line break in the date separator but that just gives me a </br>.
any other way to get the trash type on top and the date on the bottom?
thnx!
You should get the 'old' behavior if you add 'layout: 0' to your block definition.
(but then of course you'll loose the table formatting)
That’s no problem for me! Thnx again!
Sent from my iPad using Tapatalk
unfortunately adding layout: 0 is not allowing me to put the brake line after the name of the container in the garbage config file (name: 'GFT<br>'). this was working before the beta update.
I also tried to put the break line as date seperator (date_separator: '<br>'), which gave me the name with <br> as well.
I also tried different variants like <br/> and <br /> with no luck.
any other ideas to put a break line between the name of the container and the date?
Lokonli
Post by Lokonli »
Enz0jacco wrote: Wednesday 09 December 2020 20:55
O, yes, you're right.
Little mistake in the garbage template.
It's fixed in latest beta. Update with 'git pull'. You have to clear the cache, otherwise the new template file is not loaded.
You can insert a line break by defining date_separator:'<br>'
Enz0jacco
Post by Enz0jacco »
Lokonli wrote: Wednesday 09 December 2020 21:11
unfortunately that doesn't work.
I did the git pull, cleared the cache and have the following code
blocks['garbage'] = {}
blocks['garbage']['date_separator'] = '<br>';
blocks['garbage']['layout'] = 0;
am I missing something.
oh yeah I did the git pull again just to veriy and it said up to date.
Lokonli
Post by Lokonli »
yesterday I've created 3.6.9: Did you receive that update?
If not, maybe you're on the wrong branch:
git checkout beta
git pull
Check that git doesn't report any error.
If it's still not working I'll add a layout:2 option, to explicitly set the line break in the garbage template already.
Enz0jacco
Post by Enz0jacco »
did the checkout beta and received the latest with git pull.
it gave me the following message:
Your branch is up to date with 'origin/beta'.
unfortunately no result:(
Enz0jacco
Post by Enz0jacco »
the weird thing is i can insert anything at date-separator like = - , and it works fine.
you would expect that once u put <br> it gives me <br> literally, but instead it gives me a space in that case
Lokonli
Post by Lokonli »
Enz0jacco wrote: Friday 11 December 2020 14:06 the weird thing is i can insert anything at date-separator like = - , and it works fine.
I can't explain why it's not working. Maybe some interaction with your custom.css?
Anyway, I've added the option layout:2 to latest beta. It will add the <br> between the dataseparator and the date.
Could you test this one?
(update with git pull)
This should work ...
Enz0jacco
Post by Enz0jacco »
Lokonli wrote: Friday 11 December 2020 21:08
So I tried the git pull and layout 2 but it did't work. so I took a look at the css file and put everything between /* */ and then it worked. so it was my css file:( I'm sorry for the inconvenience Lokonli.
I'm very glad now about the garbage collector so thank you very much!
Lokonli
Post by Lokonli »
Good to know it's working.
For my learning: what in custom.css caused the problem?
Enz0jacco
Post by Enz0jacco »
I had this:
.trash .col-data,
.trash .state div.trashtoday,
.trash .state div.trashtomorrow {
        display: flex !important;
	justify-content: center !important;
	align-items: center !important;
	text-align: center; !important; }
and removed the trashtoday and tomorrow so like this:
.trash .col-data {
Lokonli
Post by Lokonli »
Thanks.
The display:flex in combination with align-items: center will indeed align vertically.
Enz0jacco
Post by Enz0jacco »
is there a way to adjust the trashdate from xx-xx-xxxx to xx-xx.
so removing the year. For me its pretty obious which year it should be:P
Chris12
Domoticz version: 2021.1
Post by Chris12 »
@lokonli, how to add some extra paces between the garbage type and date?
I use this:
date_separator: ' -    ',
but no extra spaces are added, due to the browser is removing it I think
(https://www.w3schools.com/html/html_entities.asp)
I tried with &nbsp; but that gives me the text &nbsp;
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
Lokonli
Post by Lokonli »
You could shift the garbage date to the right by adding the following to custom.css:
.trash table {
    width: 100%
or if you prefer to make the separator wider:
.trashsep {
    width: 50px
Chris12
Post by Chris12 »
thanks! thats works fine. Appreciate all the help you give!
cduijker
Post by cduijker »
I am struggling with some css modifications:
I would like to move the table with the dates of the garbage module to the right so it doesn't cover the garbage bin image.
When I add margin-left: 40px; to
<div class="col-xs-8 col-data state"><table> in the dev-tools of a browser it displays correctly..
However; how do I add that to the custom.css file?
regards,
Chris
Lokonli
Post by Lokonli »
cduijker wrote: Tuesday 29 December 2020 11:57 I am struggling with some css modifications:
regards,
Chris
Normally the garbage icon is not covered. Can you post your custom.css and the block definition of your garbage block?
Which browser do you use for Dashticz? OS version?
cduijker
Post by cduijker »
custom.css :
CUSTOM CSS FILE
.trashcan {
height: 50px !important;
max-width: 75px !important;
opacity:1 !important;
Block definition :
date_separator: ' : ',
layout: 1,
I use the chromium browser on a RPI, but on my windows machine with Chrome it looks the same..
regards
Lokonli
Post by Lokonli »
cduijker wrote: Tuesday 29 December 2020 15:33 custom.css :
CUSTOM CSS FILE
.trashcan {
Block definition :
layout: 1,
regards
You've increased the size of the garbage icon.
Currently, the other parts of the blocks are not adjusted. I plan to improve that in a future version.
For now, you have to adjust the text position and the width, for instance with the following in custom.css:
.garbage .col-data {
   width: calc(100% - 45px - 30px);
   left: 30px
cduijker
Post by cduijker »
Thanks for the quick reply! It is working perfectly now!
