jackfagner
Re: Domoticz app 2.0
Post by jackfagner »
NiklasO wrote:This does not help. My app still crash. Why do you instruct on how to clear data for Google Maps?
I cleared data for both Maps(?) and Domoticz app. It crashes as soon I have added the server settings again.
I use the paid version...
I solved the crashing by clearing data and then NOT enable the Scenes menu item.
NiklasO
Post by NiklasO »
I can't even get to that menu? It crashes before I can change any settings.
Can someone provide the older apk?
I like the app and paid for it but it's not good when the app stays dead for days... :/
Last edited by NiklasO on Saturday 27 February 2016 13:08, edited 1 time in total.
nukie
Domoticz version: V3.5817
Post by nukie »
On Android 5.0.2 on HTC M7 the Lite (0.1.236) app crash on startup (not tested paid on HTC). On Android 6.0.1 (Nexus 6) both the paid (0.1.236) and lite (0.1.236) app works great. Domoticz V2.4790
RPi 3 Domoticz, Z-stick Gen5, RFXtrx433E, Philips HUE
Tellstick ZnetV2, Samsung smartthings, Ikea Trådfri
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
The app sends a push notification when my door bell is pressed. I didn't set this but a general "test" message is send. Where is this message configurable? Now I added a notification message "test bericht" and receive them both. Under with message service is domoticz app manageable? And would it be possible to send a picture with the message? I now use telegram for that but I would really love to have this all in one app!
Paid version 0.1.236 android 5.1.1 Galaxy s6 edge
Verstuurd vanaf mijn SM-G925F met Tapatalk
four2six
Post by four2six »
I'm not sure i found everything there is to find about the NFC integration. Is it included yet? I'm asking as i can't connect any Switch to a NFC connection.
Would be a cool feature, so... any ideas?
galadril
Domoticz version: latest
Post by galadril »
mstrandbo wrote:@galadril: I received your PM, but I am unfortunately unable to reply. I have set up viewer-access for you, though... Oh well :P
I've fixed this issue.
Will be in the next release
galadril
Post by galadril »
sweup wrote:Hi, after last update i got instant FC when opening the app. Tried reboot without success. Unfortunately I haven't root and I haven't find any app to take logs without root. Im using Xperia Z5 5.1.1
Looking into this!
galadril
Post by galadril »
I found that the issue is related to the Swedish translation.
I'll be working on a fix!
To work around this issue.,
- Clear cache of the app
- Set your phone language to English
- Start app and set the language to English in the app (so that the language doesn't change when you change your phone language back to Swedish)
- Change the phone language back to your desired language.
galadril
Post by galadril »
four2six wrote:I'm not sure i found everything there is to find about the NFC integration. Is it included yet? I'm asking as i can't connect any Switch to a NFC connection.
NFC should be implemented in the latest version.
Open the NFC Connections page from the settings and put your phone on the NFC tag to register the tag.
Then you can configure a switch by long pressing the row
four2six
Post by four2six »
galadril wrote: Open the NFC Connections page from the settings and put your phone on the NFC tag to register the tag.
Thanks, that worked. I just ticked the box at the front of the row, it asked me for a switch, but wouldn't accept my input. Seems to be a bug.
But thanks for your quick help!
edit:
well, it did work with connecting a nfc tag to a switch, but i can't use it in the app. Whenever i use the tag while the dashboard of the app shows, it just offers me to open other apps to read the tag. Domoticz is not among them.
NiklasO
Post by NiklasO »
Thanks. I saw your answer at play store. Is the update on its way out or do we need to do the work around?
galadril
Post by galadril »
NiklasO wrote:Thanks. I saw your answer at play store. Is the update on its way out or do we need to do the work around?
I've uploaded a new version to the play store!
Normally it takes less then 2 hours to receive the update.
Sorry for any inconvenience caused!! :oops:
NiklasO
Post by NiklasO »
It's ok. The app is really good when it's working. ;-)
I made some changes in the Swedish translation a couple of days ago. Some words where written apart when they should be one word. I also changed some names to fit the domoticz web version (I am also responsible for the Swedish translation for the service)
Edit
If allowed to wish a function..
I would like a widget that only takes up the space of one icon that toggles selected switch/scene from on or off. Like in the other app. Domoticz. The one widget there now takes up a bit space. The caption is not needed but the current atatus of the device indicated (on or off) with a light/color or something like that.
Jango
Post by Jango »
Yeah same switch order as on server! [GRINNING FACE WITH SMILING EYES]
There is one problem, the client crashes when I want to see graphs.
Beta version
0.1.239
ceedebee
Post by ceedebee »
How does the notification function work? I'm running the stable version of Domoticz, there isn't an option to push notifications to the app in the settings.
sweup
Post by sweup »
Looking into this!
Working fine now! Thanks for great work.
mickmack
Re: RE: Re: Domoticz app 2.0
Post by mickmack »
Jango wrote:Yeah same switch order as on server! [GRINNING FACE WITH SMILING EYES]
Beta version
0.1.239
Same problem here. Client crashes when opening a graph. Version 0.1.239. Besides that its working great!
Scoobydoo
Post by Scoobydoo »
Beta version
0.1.239
Same here, crashes when trying to open a graph.
jannl
Domoticz version: 2022.2
Post by jannl »
Same here crash when opening graph. Sort order on dashboard is great. Too bad the alpha sort order still is not correct.
maluko
Post by maluko »
here have same crash too
Android: 5.1.1
Equip.: Nexus5
Domoticz app: 0.1.240
Crash on:
- the last version had crash wen try add new server, now wiht last i can press and put the data but when press to store goes down.
- Graphics not working
-Dashboard sorting not working
