I solved the crashing by clearing data and then NOT enable the Scenes menu item.NiklasO wrote:This does not help. My app still crash. Why do you instruct on how to clear data for Google Maps?
I cleared data for both Maps(?) and Domoticz app. It crashes as soon I have added the server settings again.
I use the paid version...
jackfagner
Re: Domoticz app 2.0
NiklasO
- Target OS: -
I can't even get to that menu? It crashes before I can change any settings.jackfagner wrote:I solved the crashing by clearing data and then NOT enable the Scenes menu item.NiklasO wrote:This does not help. My app still crash. Why do you instruct on how to clear data for Google Maps?
Can someone provide the older apk?
I like the app and paid for it but it's not good when the app stays dead for days... :/
Last edited by NiklasO on Saturday 27 February 2016 13:08, edited 1 time in total.
nukie
- Domoticz version: V3.5817
On Android 5.0.2 on HTC M7 the Lite (0.1.236) app crash on startup (not tested paid on HTC). On Android 6.0.1 (Nexus 6) both the paid (0.1.236) and lite (0.1.236) app works great. Domoticz V2.4790
RPi 3 Domoticz, Z-stick Gen5, RFXtrx433E, Philips HUE
Tellstick ZnetV2, Samsung smartthings, Ikea Trådfri
Skippiemanz
- Domoticz version: 4.10233
The app sends a push notification when my door bell is pressed. I didn't set this but a general "test" message is send. Where is this message configurable? Now I added a notification message "test bericht" and receive them both. Under with message service is domoticz app manageable? And would it be possible to send a picture with the message? I now use telegram for that but I would really love to have this all in one app!
Paid version 0.1.236 android 5.1.1 Galaxy s6 edge
Verstuurd vanaf mijn SM-G925F met Tapatalk
four2six
I'm not sure i found everything there is to find about the NFC integration. Is it included yet? I'm asking as i can't connect any Switch to a NFC connection.
Would be a cool feature, so... any ideas?
- galadril
- Domoticz version: latest
I've fixed this issue.mstrandbo wrote:@galadril: I received your PM, but I am unfortunately unable to reply. I have set up viewer-access for you, though... Oh well
Will be in the next release
- galadril
Looking into this!sweup wrote:Hi, after last update i got instant FC when opening the app. Tried reboot without success. Unfortunately I haven't root and I haven't find any app to take logs without root. Im using Xperia Z5 5.1.1
- galadril
NiklasO wrote:I can't even get to that menu? It crashes before I can change any settings.jackfagner wrote:I solved the crashing by clearing data and then NOT enable the Scenes menu item.NiklasO wrote:This does not help. My app still crash. Why do you instruct on how to clear data for Google Maps?
I found that the issue is related to the Swedish translation.
I'll be working on a fix!
To work around this issue.,
- Clear cache of the app
- Set your phone language to English
- Start app and set the language to English in the app (so that the language doesn't change when you change your phone language back to Swedish)
- Change the phone language back to your desired language.
- galadril
NFC should be implemented in the latest version.four2six wrote:I'm not sure i found everything there is to find about the NFC integration. Is it included yet? I'm asking as i can't connect any Switch to a NFC connection.
Open the NFC Connections page from the settings and put your phone on the NFC tag to register the tag.
Then you can configure a switch by long pressing the row
four2six
Thanks, that worked. I just ticked the box at the front of the row, it asked me for a switch, but wouldn't accept my input. Seems to be a bug.galadril wrote: Open the NFC Connections page from the settings and put your phone on the NFC tag to register the tag.
But thanks for your quick help!
edit:
well, it did work with connecting a nfc tag to a switch, but i can't use it in the app. Whenever i use the tag while the dashboard of the app shows, it just offers me to open other apps to read the tag. Domoticz is not among them.
NiklasO
- Target OS: -
Thanks. I saw your answer at play store. Is the update on its way out or do we need to do the work around?
- galadril
I've uploaded a new version to the play store!NiklasO wrote:Thanks. I saw your answer at play store. Is the update on its way out or do we need to do the work around?
Normally it takes less then 2 hours to receive the update.
Sorry for any inconvenience caused!!
NiklasO
- Target OS: -
It's ok. The app is really good when it's working.galadril wrote:I've uploaded a new version to the play store!NiklasO wrote:Thanks. I saw your answer at play store. Is the update on its way out or do we need to do the work around?
I made some changes in the Swedish translation a couple of days ago. Some words where written apart when they should be one word. I also changed some names to fit the domoticz web version (I am also responsible for the Swedish translation for the service)
Edit
If allowed to wish a function..
I would like a widget that only takes up the space of one icon that toggles selected switch/scene from on or off. Like in the other app. Domoticz. The one widget there now takes up a bit space. The caption is not needed but the current atatus of the device indicated (on or off) with a light/color or something like that.
Jango
Yeah same switch order as on server! [GRINNING FACE WITH SMILING EYES]
There is one problem, the client crashes when I want to see graphs.
Beta version
0.1.239
Beta version
0.1.239
How does the notification function work? I'm running the stable version of Domoticz, there isn't an option to push notifications to the app in the settings.
sweup
Working fine now! Thanks for great work.galadril wrote:Looking into this!sweup wrote:Hi, after last update i got instant FC when opening the app. Tried reboot without success. Unfortunately I haven't root and I haven't find any app to take logs without root. Im using Xperia Z5 5.1.1
Re: RE: Re: Domoticz app 2.0
Same problem here. Client crashes when opening a graph. Version 0.1.239. Besides that its working great!Jango wrote:Yeah same switch order as on server! [GRINNING FACE WITH SMILING EYES]
Beta version
0.1.239
Same here, crashes when trying to open a graph.mickmack wrote:Same problem here. Client crashes when opening a graph. Version 0.1.239. Besides that its working great!Jango wrote:Yeah same switch order as on server! [GRINNING FACE WITH SMILING EYES]
Beta version
0.1.239
jannl
- Domoticz version: 2025.5.x
Same here crash when opening graph. Sort order on dashboard is great. Too bad the alpha sort order still is not correct.
maluko
here have same crash too
Android: 5.1.1
Equip.: Nexus5
Domoticz app: 0.1.240
Crash on:
- the last version had crash wen try add new server, now wiht last i can press and put the data but when press to store goes down.
- Graphics not working
-Dashboard sorting not working
Android: 5.1.1
Equip.: Nexus5
Crash on:
