Dashticz - Module - Garbage collector Topic is solved
Lokonli
Re: Dashticz - Module - Garbage collector
Post by Lokonli »
Enz0jacco wrote: Friday 20 November 2020 0:35 okay number 1 is fixed by just inserting a new image in the img/garbage folder with the new color.
still looking to get rid of the colon:P
For the colon:
In latest beta there is a new garbage block parameter to configure the date separator.
block['garbage'] = {
  date_separator: ' => '	//change it to any text you like
HansieNL
Post by HansieNL »
Lokonli wrote: Monday 23 November 2020 18:09 Check latest beta:
/* This will give the block a red border if trash collection is collected for today */
.trash.trashtoday {
    border-color: red
/* This will give the block a green border if trash collection is collected for tomorrow*/
.trash.trashtomorrow {
    border-color: green
/* This will reduce the opacity in case no trash is scheduled for today or tomorrow */
.trash:not(.trashtoday):not(.trashtomorrow) .dt_state {
    opacity: 0.2 !important;
/* This will increase the font of the trash row that is scheduled for today */
.dt_state .trashtoday {
    font-size: 20px
Thanks for this option. I'll see tomorrow if the garbage icon and info changes.
Edit: works great!
Blah blah blah
Enz0jacco
Post by Enz0jacco »
working like a charm! thanx Lokonli
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Lokonli wrote: Monday 23 November 2020 21:23
For the colon:
Lokonli
Is it possible to line the seperator after the text ?
Lokonli
Post by Lokonli »
For the colon:
Lokonli
Check beta 3.6.8 :)
madpatrick
Lokonli wrote: Friday 27 November 2020 23:42
Lokonli
Check beta 3.6.8 :)
Great !!
HansieNL
Post by HansieNL »
With the latest garbage update the text is to long to fit the block on iPad in portret mode.
@lokonli Is it possible to disable the new table layout?
Blah blah blah
Lokonli
Post by Lokonli »
HansieNL wrote: Saturday 28 November 2020 14:40 With the latest garbage update the text is to long to fit the block on iPad in portret mode.
How did it look before?
I can remove the table formatting but then the line 'restafval: 9-12-2020' still won't fit.
Was the font smaller in the previous release?
madpatrick
Somehow it changed the font settings and also the image to an icon
Lokonli
Post by Lokonli »
madpatrick wrote: Saturday 28 November 2020 18:55 Somehow it changed the font settings and also the image to an icon
I've added the block parameter 'layout' to the garbage block.
To use the previous plain text layout use:
    layout: 0
The new table layout is default, and can be set with:
   layout: 1
fvdp80
Domoticz version: 4.10303
Post by fvdp80 »
Does someone know why the collection dates from Mijnafvalwijzer are messed up?
config.js
	blocks['mygarbage'] = {
   	 company: 'mijnafvalwijzer',
   	 zipcode: 'xxxX',
   	 street: xxx',
   	 housenumber: xxx,
   	 maxitems: 5,
   	 width: 4,
	 use_names: 1,
	 garbage_mapping: {
		gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
		pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
		papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
	 garbage: {
		gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    		pmd: {kliko: 'orange', code: '#db5518', name: 'Plastic', icon: 'img/garbage/kliko_orange.png'},
    		papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
Lokonli
Post by Lokonli »
Hmm, something goes wrong with the filtering. I'll check.
Lokonli
Post by Lokonli »
The 2021 data has been added, but wasn't handled correctly.
Fixed in latest beta.
madpatrick
Lokonli wrote: Wednesday 02 December 2020 22:52 I've added the block parameter 'layout' to the garbage block.
    layout: 0
   layout: 1
Working great !
poweredge
Post by poweredge »
I read thru the topic - but could find any pointer. can someone tell me how i can:
1 change the date/time/format ? (my other calenders/home agenda is displayed correctly but not the 'afvalwijzer'/den bosch region)
2 the locale is on nl-NL but i see still as well the english names.
DM2021.1 (pri+sec) VM/RPI4. Dashticz @touchscreen. IT: Dell ESXi cluster, UPS, fiber+4g WAN. Smart: Aeotec/Neo/Qubino/Eurotronic zwave, Philips Hue, P1, rfxom433, OTGW, ITHO WiFi, Shelly shutter/water sens, NEST v3, 9x Alexa
Enz0jacco
Post by Enz0jacco »
with the new update my break line between the trash type and date is not working anymore. I tried to put the line break in the date separator but that just gives me a </br>.
any other way to get the trash type on top and the date on the bottom?
thnx!
Lokonli
Post by Lokonli »
Enz0jacco wrote: Wednesday 09 December 2020 9:00 with the new update my break line between the trash type and date is not working anymore. I tried to put the line break in the date separator but that just gives me a </br>.
thnx!
You should get the 'old' behavior if you add 'layout: 0' to your block definition.
(but then of course you'll loose the table formatting)
Lokonli
Post by Lokonli »
poweredge wrote: Wednesday 09 December 2020 8:16 Untitled.png
Did you already try with both config settings:
config['calendarlanguage'] = 'nl_NL';
config['language'] = 'nl_NL';
poweredge
Post by poweredge »
config['calendarlanguage'] = 'nl_NL'; did the trick - date format now correct and language adjusted as well .. already had the datatimeformatting OK but not this one ... appreciated ;-)
Enz0jacco
Post by Enz0jacco »
thnx!
That’s no problem for me! Thnx again!
Sent from my iPad using Tapatalk
