Page 38 of 55
Re: [MyDomoAtHome] Support thread
Posted: Wednesday 01 February 2017 3:47
by markjgabb
ok idiot me i missed a } at the end, but now I'm getting a port undefined error
  "app_name": "MyDomoAtHome",
  "auth": { "username": "admin", "password": "******" },
   "domoticz": {
    "ssl": false,
    "host": "127.0.0.1",
    "port": "8080",
    "path": "/",
    "auth": { "username": "remote", "password": "******"},
  "port": "3002",
  "passcode": ""
Posted: Wednesday 01 February 2017 4:25
by markjgabb
please ignore all of the above....
have resolved by rewriting the config.json
is it just me or is the code in the git readme not laid out correctly?
https://github.com/empierre/MyDomoAtHome
Posted: Wednesday 01 February 2017 22:12
by mlamie
gerardosamara wrote: Q1 : Does anybody is using this configuration ?
Q2 : Wireshark is not catching messages from/to the IP of Imperihome phone ?
I do have the same setup. If you look at the github page you can see the alarm panel is on the TODO list. It is only partial supported (probably it means display the status of the Domoticz alarm panel).
Since it is quite annoying I made a work around.
1) Under setup - hardware include the Dummy device, this allows you to create dummy devices
2) Press create virtual sensor and type a name (i used AlarmActive) and select Switch as sensor type
3) Under setup - devices you will find the Dummy device created and also it will be shown as a Switch (AlarmActive)
4) Create a new event as shown in the below Domoticz screenshot
5) Now you can arm and disarm the alarm via a selector switch in ImperiHome (In ImperiHome you can protect the switch with a passcode)
if (devicechanged['AlarmActive'] == 'On') then
        commandArray['Domoticz Security Panel']='Arm Away'
   print('Setting Arm Away')
if (devicechanged['AlarmActive'] == 'Off') then
        commandArray['Domoticz Security Panel']='Disarm'
   print('Setting Disarm')
Posted: Wednesday 01 February 2017 23:00
by gerardosamara
Thank you very much @mlamie for the answer and the proposed work around .
Posted: Sunday 05 February 2017 15:23
by Jimbolaya
How do I display temperatures in Fahrenheit? Best I can figure out is there needs to be a setting in the config.json file. Something like "TemperatureFormat": "English - F". I've tried a few variations with no success.
Posted: Monday 06 February 2017 12:58
by jhenrikb
Hello, I'm having issues with the auth username and PW on domoticz with imperihome.
Which is what? Currently im running domoticz without auth to get it working on imperihome. I Would also like to have a UN and PW on the IH app too.
"auth": { "username": "admin", "password": "******" }, //this is the IH username and PW?
"domoticz": {
"ssl": false,
"port": "8080",
"path": "/",
"auth": { "username": "remote", "password": "******"}, // this is domoticz auth username and pw correct?
"port": "3002",
"passcode": ""
Posted: Thursday 09 February 2017 12:42
by waaren
Hi mlami,
I am struggling to get buienradar on my imperihome (I only get the globe symbol) . Can you please share the steps you took ?
Posted: Thursday 09 February 2017 13:28
by mlamie
Press an empty spot on your dashboard to add a widget
Select webpage
At local URL use the following address: http://api.buienradar.nl/image/1.0/Rada ... =640&h=480
P.s. you can resize by changing the values w=&h= like:
http://api.buienradar.nl/image/1.0/Rada ... =150&h=150
Posted: Thursday 09 February 2017 18:43
by waaren
Thx mlami; it's working now. I was under the impression that I had to use the external URL. (Not sure where i can use that one for now :-) )
Posted: Thursday 16 February 2017 21:03
by zes00
Hi.
Does anyone know why some of my devices show up as "no group" in the imperihome app? Seems to be only the "dimmer" devices in domoticz that isnt recognized as a switch/dimmer in imperihome. the "no group" tab isnt in my IOS app(only scenes, switches and utility), so its kinda annoying only being able to access my devices from android(which I do not use).
is there something I could have done wrong when setting up domoticz/MDAH gateway? what could I try to do to fix this?
Raspberry PI3,
Domoticz V3.5877
Node V4.2.2
npm v2.15.11
attaching printouts of devices
Domoticz used devices:
   "ActTime" : 1487272867,
   "ServerTime" : "2017-02-16 20:21:07",
   "Sunrise" : "07:53",
   "Sunset" : "17:04",
   "result" : [
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "LastUpdate" : "2017-02-14 21:41:35",
         "Name" : "Film",
         "PlanID" : "",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "Status" : "On",
         "Type" : "Scene",
         "TypeImg" : "scene",
         "UsedByCamera" : false,
         "XOffset" : 0,
         "YOffset" : 0,
         "idx" : "1"
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "LastUpdate" : "2017-02-16 20:13:49",
         "Name" : "Lys stue",
         "PlanID" : "",
         "PlanIDs" : [ 0 ],
         "Status" : "On",
         "Type" : "Group",
         "TypeImg" : "group",
         "XOffset" : 0,
         "YOffset" : 0,
         "idx" : "2"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "236.181 V",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "razberry master",
         "HardwareTypeVal" : 21,
         "HaveTimeout" : false,
         "ID" : "00000201",
         "LastUpdate" : "2017-02-16 20:21:05",
         "Name" : "Spenning (V)",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Voltage",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "current",
         "Unit" : 1,
         "Used" : 1,
         "Voltage" : 236.1810,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "6"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "4.3 A",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "0201",
         "Name" : "Strømtrekk (A)",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "CM113, Electrisave",
         "Timers" : "false",
         "Type" : "Current",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "displaytype" : 0,
         "idx" : "7"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CounterToday" : "19.273 kWh",
         "CustomImage" : 0,
         "Data" : "1454.516 kWh",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000201",
         "LastUpdate" : "2017-02-16 20:20:48",
         "Name" : "Effekt (kWh)",
         "Options" : "0",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "kWh",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Usage" : "976.1 Watt",
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "8"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Set Level: 19 %",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "00000301",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-02-16 06:00:01",
         "Level" : 19,
         "LevelInt" : 19,
         "MaxDimLevel" : 100,
         "Name" : "Lys gang (20%)",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Set Level: 19 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Dimmer",
         "SwitchTypeVal" : 7,
         "Timers" : "true",
         "Type" : "Light/Switch",
         "TypeImg" : "dimmer",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "210",
         "YOffset" : "389",
         "idx" : "9"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "24.6 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HaveTimeout" : true,
         "ID" : "0401",
         "LastUpdate" : "2017-02-07 05:17:16",
         "Name" : "Temperatur stue",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "SubType" : "LaCrosse TX3",
         "Temp" : 24.60,
         "Timers" : "false",
         "Type" : "Temp",
         "TypeImg" : "temperature",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "200",
         "YOffset" : "20",
         "idx" : "16"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Heat",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000501",
         "LastUpdate" : "2017-02-14 20:11:05",
         "Mode" : 1,
         "Modes" : "0;Off;1;Heat;2;Cool;3;Resume;4;Fan Only;5;Dry Air;6;Auto Changeover;",
         "Name" : "Thermostat Mode",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Thermostat Mode",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "mode",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "17"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0.0",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "0000501",
         "Name" : "Heating 1",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SetPoint" : "0.0",
         "SubType" : "SetPoint",
         "Timers" : "false",
         "Type" : "Thermostat",
         "TypeImg" : "override_mini",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "18"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "0.0",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "0000502",
         "Name" : "Cooling 1",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SetPoint" : "0.0",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "19"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Auto Low",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000501",
         "Mode" : 0,
         "Modes" : "0;Auto Low;1;On Low;2;Auto High;3;On High;4;Unknown 4;5;Unknown 5;",
         "Name" : "Thermostat Fan Mode",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Thermostat Fan Mode",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "mode",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "22"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Set Level: 20 %",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000601",
         "Image" : "Light",
         "Level" : 20,
         "LevelInt" : 20,
         "Name" : "Lysekrone spisestue",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Set Level: 20 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "94",
         "YOffset" : "279",
         "idx" : "24"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 3,
         "HardwareName" : "Hue",
         "HardwareType" : "Philips Hue Bridge",
         "HardwareTypeVal" : 38,
         "HaveGroupCmd" : false,
         "ID" : "000003E9",
         "Image" : "Light",
         "LastUpdate" : "2017-02-16 16:52:07",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Utelys trapp",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "RGBW",
         "SwitchType" : "On/Off",
         "Timers" : "true",
         "Type" : "Lighting Limitless/Applamp",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "38"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 3,
         "ID" : "000003EA",
         "Image" : "Light",
         "LastUpdate" : "2017-02-16 20:13:55",
         "Level" : 100,
         "LevelInt" : 100,
         "Name" : "Spottere mur stue",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "RGBW",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "246",
         "YOffset" : "152",
         "idx" : "47"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000701",
         "Image" : "Light",
         "LastUpdate" : "2017-02-14 21:20:52",
         "Level" : 37,
         "LevelInt" : 37,
         "Name" : "Lys takvifte stue",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "140",
         "YOffset" : "80",
         "idx" : "59"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Set Level: 65 %",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000801",
         "Image" : "Light",
         "Level" : 65,
         "LevelInt" : 65,
         "Name" : "Spotskinne TVstue",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Set Level: 65 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "true",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "420",
         "YOffset" : "79",
         "idx" : "71"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000929",
         "Image" : "Light",
         "LastUpdate" : "2017-01-18 12:13:41",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Røykvarsler 1etg",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SwitchType" : "Smoke Detector",
         "SwitchTypeVal" : 5,
         "Timers" : "false",
         "TypeImg" : "smoke",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "85"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000A29",
         "Image" : "Light",
         "LastUpdate" : "2017-02-15 18:44:18",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Røykvarsler 2etg",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "94"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000B29",
         "Image" : "Light",
         "LastUpdate" : "2017-01-17 19:47:07",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Røykvarsler kjeller",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "103"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 101,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000E01",
         "Image" : "Danalock",
         "LastUpdate" : "2017-02-16 20:04:21",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Ytterdør",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "115"
   "status" : "OK",
   "title" : "Devices"
Gateway Devices:
{"devices":[{"id":"S0","name":"MyDomoAtHome","type":"DevGenericSensor","params":[{"key":"Value","value":"0.2.7","unit":"","graphable":"false"}]},
{"id":"SC1","name":"Film","type":"DevScene","room":"Scenes","params":[{"key":"LastRun","value":1487104895000}]},
{"id":"SC2","name":"Lys stue","type":"DevMultiSwitch","room":"Scenes","params":[{"key":"LastRun","value":1487272429000},{"key":"Value","value":"On"},{"key":"Choices","value":"On,Off"}]},
{"id":"6","name":"Spenning (V)","type":"DevGenericSensor","room":"Utility","params":[{"key":"Value","value":"237.075","unit":"V","graphable":"true"}]},
{"id":"7","name":"Strømtrekk (A)","type":"DevElectricity","room":"Utility","params":[{"key":"Watts","value":"0","unit":"W","graphable":"true"}]},
{"id":"8","name":"Effekt (kWh)","type":"DevElectricity","room":"Utility","params":[{"key":"Watts","value":"997.9","unit":"W"},{"key":"ConsoTotal","value":"1455","unit":"kWh","graphable":"true"}]},
{"id":"9","name":"Lys gang (20%)","type":"DevDimmer","params":[{"key":"Status","value":"1"},{"key":"Level","value":"19"}]},
{"id":"16","name":"Temperatur stue","type":"DevTemperature","params":[{"key":"Value","value":24.6,"unit":"°C","graphable":"true"}]},
{"id":"18","name":"Heating 1","type":"DevThermostat","room":"Switches","params":[{"key":"cursetpoint","value":"0.0"},{"key":"curtemp","value":"0.0"},{"key":"step","value":"0.5"},{"key":"curmode","value":"default"},{"key":"availablemodes","value":"default"}]},
{"id":"19","name":"Cooling 1","type":"DevThermostat","room":"Switches","params":[{"key":"cursetpoint","value":"0.0"},{"key":"curtemp","value":"0.0"},{"key":"step","value":"0.5"},{"key":"curmode","value":"default"},{"key":"availablemodes","value":"default"}]},
{"id":"24","name":"Lysekrone spisestue","type":"DevDimmer","params":[{"key":"Status","value":"1"},{"key":"Level","value":"20"},{"key":"Energy","value":"9.8"}]},
{"id":"38","name":"Utelys trapp","type":"DevRGBLight","room":"Switches","params":[{"key":"tatus","value":0}]},
{"id":"47","name":"Spottere mur stue","type":"DevRGBLight","params":[{"key":"Status","value":0}]},
{"id":"59","name":"Lys takvifte stue","type":"DevDimmer","params":[{"key":"Status","value":"0"},{"key":"Level","value":"0"},{"key":"Energy","value":"0.0"}]},
{"id":"71","name":"Spotskinne TVstue","type":"DevDimmer","params":[{"key":"Status","value":"1"},{"key":"Level","value":"65"},{"key":"Energy","value":"0.0"}]},
{"id":"85","name":"Røykvarsler 1etg","type":"DevSmoke","room":"Switches","params":[{"key":"Armable","value":"0"},{"key":"ackable","value":"0"},{"key":"Armed","value":"1"},{"key":"Tripped","value":"0"},{"key":"lasttrip","value":"1484738021000"}]},
{"id":"94","name":"Røykvarsler 2etg","type":"DevSmoke","room":"Switches","params":[{"key":"Armable","value":"0"},{"key":"ackable","value":"0"},{"key":"Armed","value":"1"},{"key":"Tripped","value":"0"},{"key":"lasttrip","value":"1487180658000"}]},
{"id":"103","name":"Røykvarsler kjeller","type":"DevSmoke","room":"Switches","params":[{"key":"Armable","value":"0"},{"key":"ackable","value":"0"},{"key":"Armed","value":"1"},{"key":"Tripped","value":"0"},{"key":"lasttrip","value":"1484678827000"}]},
{"id":"115","name":"Ytterdør","type":"DevSwitch","room":"Switches","params":[{"key":"Status","value":"0"}]}]}
Posted: Monday 20 February 2017 8:31
by markis
Has anyone been able to configure MDAH when domoticz is only running SSL and port 443?
All examples and guides I've seen is about HTTP and I cannot get it to work with only HTTPS.
Gateway adress is added in Setup/settings/Local Networks.
Raspberrry Pi3
$ node --version
v4.2.2
$ npm --version
2.15.11
$ cat /etc/mydomoathome/config.json
"auth": null,
"domoticz": {
"ssl": true,
"port": "443",
"path": "/",
"auth": null
"port": 3003,
"passcode": ""
Posted: Monday 27 February 2017 21:00
by waynekramer
epierre wrote:
ahmedadelhosni wrote: Nothing new in the same log file.
Is there any log file rather than usage.log ?
Is there a compiled version released before Friday ? as it was working on last Friday after those changes. I guess it was 0.1.17
Can you please provide the .deb to install and test ?
I gues this will not help solve it.
best to do:
in one console:
sudo service mydomoathome stop
sudo -u www-data /usr/share/mydomoathome/bin/mydomoathome
in another console:
sudo curl http://ip:3002/system
sudo curl http://ip:3002/rooms
sudo curl http://ip:3002/devices
from this you should see if it breaks.
I have the same problem as my devices can't be seen in my browser (I have an error page) : a curl http://127.0.0.1:3002/devices replies me :"curl: (7) Failed to connect to 127.0.0.1 port 3002: Connexion refusée"
so I tested your above solution to see where it breaks and this is the results :
info: Domoticz server: http://127.0.0.1:8080/json.htm
info: Node version: 4.2.2
info: MDAH version: MyDomoAtHome 0.2.8
info: OS version: Linux linux 4.4.38-v7+
info: Hostname: raspberrypi 192.168.1.58 in /var/www /usr/share/mydomoathome
info: MDAH port: 3002
info: Refreshing version cache: v0.2.8
/usr/share/mydomoathome/app/mdah.js:2337
            for (var i = 0; i < data.result.length; i++) {
TypeError: Cannot read property 'length' of undefined
    at Request._callback (/usr/share/mydomoathome/app/mdah.js:2337:44)
    at Request.self.callback (/usr/share/mydomoathome/app/node_modules/request/request.js:200:22)
    at emitTwo (events.js:87:13)
    at Request.emit (events.js:172:7)
    at Request.<anonymous> (/usr/share/mydomoathome/app/node_modules/request/request.js:1067:10)
    at emitOne (events.js:82:20)
    at Request.emit (events.js:169:7)
    at IncomingMessage.<anonymous> (/usr/share/mydomoathome/app/node_modules/request/request.js:988:12)
    at emitNone (events.js:72:20)
    at IncomingMessage.emit (events.js:166:7)
error: Forever detected script exited with code: 1
error: Script restart attempt #1
error: Script restart attempt #2
I'm not sure on how to interpret these datas and I really don't have any ideas on how to solve it. Could somebody please help me ?
Thank you !
Posted: Tuesday 28 February 2017 19:19
by jaha
Hi trying to get MDAH running
I had excluded the MDAH getaway in local networks but still gettings this error
{"devices":[{"id":"S00","name":"Unable to connect to Domoticz","type":"DevGenericSensor","room":"Utility","params":[{"key":"Value","value":"https://172.16.40.14:443/json.htm"}]},{"id":"S01","name":"Please add this gateway in Setup/settings/Local Networks","type":"DevGenericSensor","room":"Utility"}]}
My config.json
"auth": null,
"domoticz": {
"ssl": true,
"host": "172.16.40.14",
"port": "443",
"path": "/",
"auth": null
"port": "3002",
"passcode": ""
Auth is off in domoticz and the network is excluded from auth.
If I run the command from the machine it works:
curl --insecure https://172.16.40.14/json.htm?type=devi ... order=Name
Posted: Thursday 09 March 2017 14:34
by Cloud
I use Fibaro Shutters in my environment. I have the problem that the Shutters always show 100 % in Imperihome when completely closed or opened. So i cant tell if they are opened or closed.
The level values in domoticz are 100 for completely closed and 0 for opened. Other values between 0 and 100 work without problems. Anyone know a solution for that?
Complete Closed Blind
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Closed",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "razberry2",
         "ID" : "00000A01",
         "Image" : "Light",
         "LastUpdate" : "2017-03-09 14:24:28",
         "Level" : 100,
         "LevelInt" : 100,
         "Name" : "Jalousie Schlafzimmer",
         "PlanID" : "5",
         "PlanIDs" : [ 5 ],
         "Status" : "Closed",
         "StrParam1" : "",
         "StrParam2" : "",
         "SwitchType" : "Blinds Percentage",
         "SwitchTypeVal" : 13,
         "Timers" : "false",
         "TypeImg" : "blinds",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "1926",
         "YOffset" : "1268",
         "idx" : "162"
Complete Open Blind
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000401",
         "Image" : "Light",
         "LastUpdate" : "2017-03-09 11:41:05",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Jalousie Wohnzimmer Couch",
         "PlanID" : "3",
         "PlanIDs" : [ 3 ],
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "1372",
         "YOffset" : "2887",
         "idx" : "54"
Posted: Sunday 12 March 2017 14:46
by levynger
I have a starnge behaviour with a Dummy selector,
i added few leveles with custom python scripts that controls me TV.
only through the imperihome app, selecting any level (not 0) will also trigger level 0 (off) command.
this doesnt happen when selecting levels from domoticz UI.
Posted: Monday 13 March 2017 20:22
by Evelen
I think I have updatet MyDomoAtHome now.
How can I check if i have the last version of "MyDomoAtHome"? (Ubuntu Server)
I think it don't worked.
## Run `apt-get install nodejs` (as root) to install Node.js v4.x LTS Argon and npm
flemmingss@VM4:~/domoticz/MyDomoAtHome$ sudo apt-get install nodejs
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies.
 linux-headers-generic-lts-utopic : Depends: linux-headers-3.16.0-77-generic but it is not going to be installed
 nodejs : Depends: rlwrap but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Posted: Friday 24 March 2017 15:22
by anno
Error by install by step sudo apt-get install MyDomoAtHome
E: Unable to locate package MyDomoAtHome
Also this error when trying to install node, see attachment
Posted: Saturday 25 March 2017 21:16
by EdddieN
I have been trying to get the Evohome temperature sensors into the app but no luck so far, then I saw on this post someone that uses them (see attached). Any idea how to do it? it does seem that Domoticz does not present the Evohome sensors to Blockly, neither to the Imperihome API?
Posted: Monday 27 March 2017 20:50
by anno
anno wrote:Error by install by step sudo apt-get install MyDomoAtHome
So nobody here knows something about this. than also not about the following:
Posted: Tuesday 28 March 2017 14:05
by mlamie
Don't know if it solves the issue, but on the github installation page it says: Important remark: do not install as roos (I expect a typing error = root), but sudo as an unprivilegied user
