Page 38 of 66
Posted: Saturday 05 September 2015 23:01
by ericjuh
trekker25 wrote:bizziebis wrote:
I have added a IsDark switch and adjusted the correct idx :
var idx_SunState = '113';
var idx_IsDonker = '113'; <!-- for day night css -->
but still only the night css is showing. What am i missing.
Can i easily what this variable
var IsNight = 'No';
during execution of the webpage in the console? Don't see any error logs in the console
EDIT even when i use this code:
// change CSS file, depending on sunset and sunrise using virtual switch named IsDonker and set the var IsNight
if(item.idx == idx_IsDonker && vdata == 'Off'){
document.getElementById('dark-styles').disabled = true; // day
IsNight = 'No';
if(item.idx == idx_IsDonker && vdata == 'On'){
document.getElementById('dark-styles').disabled = false; // night
IsNight = 'No';
or i make isNight 'Yes" in both if statements, doesn't make any difference?
I also haveing problems with day and night. It seems the variable is cast in frontpage_settings.js and it should change on the state of the virual button. But it doesnt.
I have set my id (91) in frontpage_settings.js:
var idx_IsDonker = '91'; <!-- for day night css -->
A bit later i see the variable beeing created:
In json i can clearly see the state of the button to "On" or "Off"
If i check frontpage.js i see the following code:
IsNight = 'No';
IsNight = 'Yes';
But still IsNight won't get a value "Yes".
I have made blocky's,but i disabled it to test it. When i turn my switch on or off, there is just nothing happening. When i put a different value in the creation of the variable, like:
var IsNight = 'Somethingdifferent';
Both, night and day arent working. If i change it to yes:
Everything is in daymode.
I dont have a clue where to look anymore. Any idea's?
Posted: Sunday 06 September 2015 21:10
by ericjuh
Seems like its still wrong in the gerard33 release i downloaded yesterday. Because the status is still calculated by the switch, but i see code getting the sunrise and sunset values.
I just can't get it to work.
Posted: Sunday 06 September 2015 21:40
by bierlaagh
I also use the release of G3rard
and I have a dark CSS when the sun has set and a day CSS when we have sunrise
As far as I know you have to create a virtual switch (is donker of is dark) The IDS of that switch should be in the FrontPage_Settings.js (somewhere near line 51)
you also need to make a blocky as discribed here:
http://www.domoticz.com/forum/viewtopic ... 120#p36615
I just tested it and disabled the blocky, so i could manualy switch the is donker and when isdonker is on i have the night css if it is off you have the Day CSS.
Posted: Sunday 06 September 2015 22:06
by ericjuh
Thanks for your reply. I got it working. It seems there is some code missing.
What i did:
I added this in frontpage_settings.js. NOTE!! day.jpg and night.jpg are files i made and not default. See attachment. I put the files in \css\images
var bg_day = 'day.jpg'; // Create variable with backgroundimage day
var bg_night = 'night.jpg'; // Create variable with backgroundimage day
var bg_size = 'cover'; // Create variable with value to fill background
I disabled the stringreplace at line 49 and 55 in frontpage.js. Not sure why G3rard added this part and why he didt a substring and removed the last 3 characters. Because the sunrise and sunset is a time, like:
"Sunrise" : "06:55",
"Sunset" : "20:11",
If you remove the last 3 characters you only get the hours. But maybe it was the idea to not look at the minutes.
function(data) {
if (typeof data != 'undefined') {
$.each(data, function(i,item){
if ( i == 'Sunrise' ) {
//console.log("Sunrise: ", item);
var_sunrise = item;
//remove seconds from time
//var_sunrise = var_sunrise.substring(0, var_sunrise.length - 3);
else if ( i == 'Sunset' ) {
//console.log("Sunset: ", item);
var_sunset = item;
//var_sunset = var_sunset.substring(0, var_sunset.length - 3);
I then replaced this code (start at line 151 and this code is looking for a virtual switch)
IsNight = 'No';
IsNight = 'Yes';
with (tnx @vil1driver):
var today=new Date();
var h1 = today.getHours();
var m1 = today.getMinutes();
var h2 = var_sunrise.substring(0, 2);
var m2 = var_sunrise.substring(3, 5);
var h3 = var_sunset.substring(0, 2);
var m3 = var_sunset.substring(3, 5);
h2 = parseInt(h2, 10);
m2 = parseInt(m2, 10);
h3 = parseInt(h3, 10);
m3 = parseInt(m3, 10);
var t1 = (60 * h1) + m1; // time
var t2 = (60 * h2) + m2; // sunrise
var t3 = (60 * h3) + m3; // sunset
if ( t1 < t3 && t1 > t2) {
// dag
IsNight = 'No';
document.body.style.background='black url(css/images/'+bg_day+') no-repeat top center fixed';
document.body.style.backgroundSize=bg_size;
} else {
// nacht
IsNight = 'Yes';
document.body.style.background='black url(css/images/'+bg_night+') no-repeat top center fixed';
I have now only 1 problem.
When i keep the site active i have no problems and it keeps refreshing. But when i close it for a few minutes and i open it again i keep getting a error on this part of the code.
//Check wether we want to add the last seen to the block
if (lastseen == '1') {
if (thisday == vdate) {
$('#ls_'+vlabel).html(convStringTime) // Show only the time if last change date = today
else {
$('#ls_'+vlabel).html(convStringTime+' | '+convStringDate) // Change this 'Last Seen' into something you like
if (lastseen == '2') {
It keeps saying that vdate isnt correct in this line:
Posted: Sunday 06 September 2015 22:51
by G3rard
"Sunset" : "20:11",
function(data) {
var_sunrise = item;
var_sunset = item;
In a previous version of Domoticz also the seconds were shown for the time of sunrise and sunset, so that's way I removed the last 3 characters (which were always :00). In the new version of Domoticz the seconds are already removed so you can indeed remove these lines.
But that part has nothing to do with the day /night theme.
Did you change anything regarding the css files? Because the themes work fine here.
But if the solution of vil1driver works then that's already settled.
The problem you now have with thisday/vdate will probably be caused be the code you have added.
Posted: Sunday 06 September 2015 22:55
by ericjuh
"Sunset" : "20:11",
function(data) {
var_sunrise = item;
var_sunset = item;
Tnx for your reply. I did add something in de css files, namely the first 2 cell's where split. But now they are one. But before that the virtuel switch wasnt working either.
I now get this error.. Maybe its because i add some code. But not sure why it is going wrong. All code i added is listed above.
http://i.imgur.com/F3DJ8Cy.png
[edit]
Image was to big, so i replaced it with only a hyperlink.
Posted: Sunday 06 September 2015 23:13
by G3rard
Changing the content of the css is no problem. I was wondering if you changed the filenames or something like that, but that seems not to be the case.
I am not sure what causes the vdate issue, but it must be caused by the code you have changed. Maybe you can try to change the lastseen code by commenting some lines out or debug by printing the vdate to the console.log.
I added that option which only shows the date in the cell when the lastseen date is not the current date. So if that's not important to you, it can be changed.
Posted: Monday 07 September 2015 8:56
by G3rard
That's a better solution which indeed will always work.
Posted: Monday 07 September 2015 14:49
by jossie67
Has some one managed to start a playlist on Kodi, with a button on frontpage?
Posted: Monday 07 September 2015 15:41
by bierlaagh
jossie67 wrote:Has some one managed to start a playlist on Kodi, with a button on frontpage?
that should not be such a problem.
create a virtual switch in domoticz (remember the IDX)
than you make 2 scripts
1. start playing playlist or something like that ,( i use play readio538, a duch radio station)
2. stop playlist
both with the extension .sh
here are my examples:
Start_radio538.sh
#!/bin/bash
curl -i -X POST -H "Content-Type: application/json" -d '{"method":"Player.Open","id":44,"jsonrpc":"2.0","params":{"item":{"file":"http://vip-icecast.538.lw.triple-it.nl/RADIO538_MP3.m3u"}}}' http://KODI-IP:KODI-PORT/jsonrpc
and stop_player.sh
#!/bin/bash
curl -i -X POST -H "Content-Type: application/json" -d '{"jsonrpc": "2.0", "method": "Player.Stop", "params": { "playerid": 0 }, "id": 44}' http://KODI-IP:KODI-PORT/jsonrpc
more info about the jsonrpc of codi can be found here:
http://kodi.wiki/view/JSON-RPC_API/v6
and some examples here
http://kodi.wiki/view/JSON-RPC_API/Examples
both scripts have to be executable : chmod +x thenameofthescript.sh
and attatched to the button : script://path/scriptname.sh for both the start and the stop ofcourse
hope that helps
to add this
Posted: Tuesday 08 September 2015 8:51
by jossie67
bierlaagh wrote:jossie67 wrote:Has some one managed to start a playlist on Kodi, with a button on frontpage?
hope that helps
to add this
Thanks, it working
Posted: Monday 14 September 2015 16:14
by galadril
I've been playing with your frontpage code and here are some results:
what do you think?
Posted: Monday 14 September 2015 16:34
by Heisenberg
Nice galadril!
is your template ready for production? Could you share the files?
Posted: Monday 14 September 2015 16:42
by galadril
Heisenberg wrote:is your template ready for production? Could you share the files?
It works for me now yes, but i need to change some code so that's it's easy to adjust for every one else.
@Hansbit > Should I make a new forum post then?
Or post it here?
Posted: Monday 14 September 2015 20:08
by ThinkPad
Own topic is better, people can talk about it easier then. Otherwise people will confuse what post is about what frontpage
It is looking good, but a bit small amount of devices. I show about 20 devices on my frontpage (temp/switches/energy etc)
Posted: Tuesday 15 September 2015 9:44
by SweetPants
ThinkPad wrote:It is looking good, but a bit small amount of devices. I show about 20 devices on my frontpage (temp/switches/energy etc)
How about putting your rooms on the place where you have the switches now?
Posted: Tuesday 15 September 2015 9:57
by galadril
ThinkPad wrote:Own topic is better, people can talk about it easier then. Otherwise people will confuse what post is about what frontpage
Done >>
http://www.domoticz.com/forum/viewtopic.php?f=8&t=8017
Posted: Sunday 20 September 2015 21:55
by G3rard
vil1driver wrote:hi,
i have add on my frontpage an iframe to see an other site on it
but swipe doesn't work on iframe,
anyone know how enable swipe on iframe ?
I made the frame a bit smaller than the page, so you can still swipe on the sides of the page.
Posted: Sunday 27 September 2015 22:57
by Sevift
// if alarm threshold is defined, make value red
if (typeof valarm != 'undefined' && vtype != 'SetPoint') {
alarmcss='';
if ( Number(vdata) >= valarm ) {
alarmcss=';color:red;';
['idx','value', 'cellule', 'description','1=lastseen 2=icon 3=both','pas de thermostat','
override css','Alarme ou valeur max de thermostat']
can not set any color - Visibility Barometer Temp Gust, yet?
add
I'm a fool
logical default do not use Alarme
Visibility - Alarm < 0.5?
-25 > Temp > 33?
Barometer ?
И т.д.
Posted: Monday 09 November 2015 7:52
by grelle
G3rard, is there any other documentation about getting the Sonos PHP wrapper to work on domoticz.
I have set up the sonos folder as follows
/domoticz/www/tablet/sonos/
changed config.php to "my-idx" of domoticz dummy switch and my ip of raspberry pi, with and without ports, tested also my ip of the sonos amp controller without ports...
In Domoticx I have added these lines "
http://my-local-ip:8080/tablet/sonos/in ... ction=Play"
Nothing happens - when I use the link in a broser "
http://yourserver/tablet/sonos/index.ph ... ction=Play" I only get the output of index.php as text...is there a PHP parsing problem you think ?
