Page 38 of 52
Re: Controlicz - Easy Domoticz to Alexa Integration
Posted: Friday 29 June 2018 12:44
by Madgeni
so in Domoticz, if you say to Alexa "turn off the fan" - does it turn it off, or not? I can take a look, it may require some effort
Posted: Friday 29 June 2018 18:22
by Lyrex
No it doesnt. There is no state change
I got the correct message in the log:
User: X initiated a switch command (175/Fan/Off)
But the level of the selector switch remains
Posted: Tuesday 03 July 2018 13:48
by wallgarden
I want to integrate my Amazon Echo Dot with Domoticz (pi) using Controlicz.
I struggle with the beginning, to make Domoticz secure with ssl (port 443).
I can't get it fixed. It would be a great help if someone shows the step by step handling.
So far I understand /etc/init.d/domoticz.sh should be changed.
Please help.
Kind Regards,
Jan Walhof
Posted: Tuesday 03 July 2018 13:54
by Madgeni
HI wallgarden - domoticz has ssl on by default, so you should be able to access your local domoticz -
https://yourlocalIPaddress:443 -
https://192.168.1.50:443
Then you should forward the port (443, or whatever you change it to), to your Domoticz IP address. Then you should be able to access it via the internet: i.e
https://wallgarden.ddns.net (I made that up!)
That's the address (wallgarden.ddns.net) you put into Controlicz in your profile
Posted: Tuesday 03 July 2018 14:54
by wallgarden
Thank You for the quick reply.
I tried first, what you mentioned, with my local ip-address.
https://192.168.178.220:443
It does'nt work. Do you have another idea?
Kind Regards,
Jan Walhof
Posted: Tuesday 03 July 2018 15:05
by Madgeni
wallgarden wrote: Tuesday 03 July 2018 14:54
Kind Regards,
Jan Walhof
What version of Domoticz are you running? Do you get an error? Is this running on a Pi, or your Synology?
Posted: Tuesday 03 July 2018 15:25
by wallgarden
Hereafter some additional information.
I've got the following message after click in chrome-browser on text "not secure": "No sufficient data to verify the certificate."
Certificate gave me the following data: "
-Raspberry.local
-Domoticz CA
-9-8-2013 - 31-3-2039 (dd-mm-yyyy)
Kind Regards,
Jan Walhof
Posted: Tuesday 03 July 2018 15:42
by Madgeni
so do you get a warning, but if you click on advanced, you can 'proceed'?
That's normal if you're using the self-signed cert that domoticz provide
Posted: Tuesday 03 July 2018 17:28
by wallgarden
Yes, i can continue, but after that the connection is not secure.
Jan Walhof
Posted: Tuesday 03 July 2018 18:39
by Madgeni
Posted: Tuesday 03 July 2018 19:25
by tombeckett
hello
i am new and it's not easy to begin
I try to use controliz.
Domoticz and external access : OK
Controlicz : connexion sucessul.
Nothing in device......
I see i must create a plan in domoticz....plan is necessary or it's possbible to work without?
Last time i try to create a plan.......my interrupt for binds ...disappear.....impossible to comeback (was activate in device domoticz)...
Thx u
Posted: Tuesday 03 July 2018 19:33
by Madgeni
Hi -
sorry you're not finding it easy. Yes, you need to put your devices in a Room Plan to use Controlicz
Posted: Tuesday 03 July 2018 21:20
by wallgarden
Problem solved. There was also an other IP that was using port 433.
I changed that en with your tips the I could solve the problems I had.
Everything is running now. Thank you.
Kind Regards,
Jan Walhof
Posted: Tuesday 03 July 2018 23:13
by deennoo
Really à good job.
Surely that a domoticz limitation but Ask about it by the way.
Anyway to use open and close instead of turn on and turn off for garage door, curtains, sunblinds ?
Actualy they are reconise as Switch/light
Posted: Sunday 08 July 2018 18:17
by frenchyyii
Edit j'ai du picoler... je devais passer par un IFTTT
Posted: Thursday 12 July 2018 18:41
by cryonic90
Is it just me or is the controlicz website/service down?
I'm not able to use Alexa anymore or go to the website.
All was working perfectly yesterday.
Posted: Thursday 12 July 2018 18:45
by phtinix
yep the website is down
Posted: Thursday 12 July 2018 20:52
by Madgeni
sorry! It's back
<adds monitoring to list>
Posted: Thursday 12 July 2018 22:47
by stanvv
So, I got stuck spending hours on troubleshooting (creating new accounts, stopping fail2ban, curl my own IP etc.) due to this message:
Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.176.67.167)
Appears that you can set the Authentication of Website Protection. Changed that from Basic-Auth to Login-Page, and everything works like a charm again. (still weird that checking the connection at
https://www.controlicz.com/profile gives me an error, saying "Check your username + password". It recognizes devices though, so currently it's working well.)
Thanks for the hard work Madgeni, have a few drinks on me!
Posted: Saturday 14 July 2018 14:21
by PHIL63
since yesterday (or more don't know) I can't add new device in Controlicz.
I add a new device in Domoticz (with or without a friendly name in description), the device works fine.
I add this device in a floor plan, no problem.
If a go in Alexa app (on PC or on Android) and try to find a new device the result is "No new device found".
I have try to deactivate the Controlicz skill
I try to forget all device in the list
No problem to connect to Controlicz, I access Domoticz using https port etc etc...
All that I do has the same result : No new device found.
It's like Alexa left the scan before it was over.
Please, note that before I have no problem to add a new device and that all works fine with my other devices (blinds, lights etc..) Alexa
I don't understand why I can't add a new device since few days
I appreciate any idea to solve this problem.
Edit :
Using Domoticz v4.9763 on Windows server, Amazon Echo
