RoadXY
Domoticz version: 2.2331
Re: Domoticz app 2.0
Post by RoadXY »
EdwinDaems wrote:Also awaiting a fix for the blinds.
Bummer it was not in the recently released update.
Never the less don't lose hope.. I never do ;)
Wondering what it is that's not working?
Like I said in a previous message: I have Somfy blinds and they work perfectly...
Chucky69
Post by Chucky69 »
When I click on up/down I always get stopped
I can confirm this. Last weekend I connected my Brel blinds motor to Domoticz which works fine from the Domoticz webpage.
In the android app I get on all 3 buttons "Stop", just like jannl mentioned.
RoadXY
Post by RoadXY »
Could we get read only access to one you guys server?
Hit me up on PM please, if so.
Chucky69
Post by Chucky69 »
Today it will not be possible. Tomorrow I'm working from home, so then we have possibilities.
jannl
Domoticz version: 2025.5.x
Post by jannl »
I can do that tonight if you like, just let me know.
Agrippa
Post by Agrippa »
Pausing or stopping the reverse blinds (zonnescherm) half way isnot possible (read my posting to get it clear).
I dont know how this works on Somfy, but I have to push the 'on' button for a second time to let the sunscreen stop halfway (with KAKU).
It works on the Domoticz page but not on the app.
RoadXY
Post by RoadXY »
StanHD wrote:Hi,
Please see below Widgets that have changed since Playstore Update today:-
Version 0.1.234 (paid version)
Galaxy S6 Edge
Android 5.1.1
The top Widget functions as expected and turns a group On & Off.
The wide Widget is a Selector which appears to "inherit" the "Off" button from the top switch. If used it performs that function - "All Lighting Auto Off"
The other 2 Widgets both appear to "inherit" the same "off" button from the top switch, thus setting "All Lighting Auto Off".
The off buttons do not appear immediately when the Widget is created but a short time after.
This is a great app and thanks to you guys for all your hard work. Awesome :D
Could you please try and recreate them to see if this solves it?
Agrippa
Post by Agrippa »
Do you mean I have to make separate Widgets to have my reverse blind work?
RoadXY
Post by RoadXY »
Agrippa wrote:Do you mean I have to make separate Widgets to have my reverse blind work?
Huh?
Agrippa
Post by Agrippa »
Huh?
Eummm
Seems you're not answering my question...
RoadXY
Post by RoadXY »
Agrippa wrote:Eummm
No, I have enough info.
Thanks.
StanHD
Post by StanHD »
RoadXY wrote:
StanHD wrote:Hi,
Galaxy S6 Edge
Android 5.1.1
:oops: Yes that fixed it, sorry, I should have tried that first. Thank you.
Python:- Broadlink RM2, Sonos
RoadXY
Post by RoadXY »
StanHD wrote:
RoadXY wrote: Could you please try and recreate them to see if this solves it?
No problem!
Glad it's solved.
Enjoy your Android Domoticz client :mrgreen:
asjmcguire
Domoticz version: 3.5877
Re: RE: Re: Domoticz app 2.0
Post by asjmcguire »
RoadXY wrote:
asjmcguire wrote:I'm just wondering. The Play Store page says the update features GCM notifications, I see a bit in the settings for GCM but when I press the option to push my registrationid to domoticz I just immediately get a message that "could not save your registration id in Domoticz". What am I missing? I'm now running version v2.4625 of Domoticz and version 0.1.234 of the app.
Are you running the beta version of Domoticz server?
Only then notifications is working.
We'll add an check for the server version if it's supported by the server.
I'm not sure, I did a git pull so I updated to whatever the latest version is, I can't see anywhere to specify if I wanted the beta or stable version of the server. There are no options for GCM on the server though if that helps.
Sent from my Nexus 4 using Tapatalk
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
RoadXY
Post by RoadXY »
asjmcguire wrote: I'm not sure, I did a git pull so I updated to whatever the latest version is, I can't see anywhere to specify if I wanted the beta or stable version of the server. There are no options for GCM on the server though if that helps.
If your in the beta channel of the server it should work. There are no settings yet on the server. You could check the database of the server if your telephone registered?
mstrandbo
Post by mstrandbo »
In the Dashboard I have my favorites, where I have a group called "Utebelysning". When I press its buttons, I get the notification underneath saying "Turning switch on: Outside weather".
Well, outside weather is not a switch - it's a thermometer.... :) Utebelysning should turn on my outdoor lights, but it doesnt.
However, if I go into Scenes and turn on Utebelysning from there, it works.
Jango
Post by Jango »
Hello, server update does not work in beta Android cliënt.
nautico
Post by nautico »
I cannot set à second server
Multi server on
When i Want to add a new server, app crash.....
ceedebee
Post by ceedebee »
RoadXY wrote:
ceedebee wrote:Updated the app today and it doesn't crash anymore on start-up.
Now I can see the security panel but it onlo shows the status and an on button. No possibility to change the status of the alarm, is this by design?
Could you post some screenshots please?
I'm sorry I realy don't know how to make a screenshot on Android. But on the phone there is at the right of the text a switch, just like a switch for lamps etc. On the tablet there is a rectangular switch (like the one used for my scenes)
EdwinDaems
Post by EdwinDaems »
RoadXY wrote:Could we get read only access to one you guys server?
Just let me know when you have time to look into things and I'll arrange access.
Cannot PM you to handover IP and credentials.
