Page 36 of 94
Re: RE: Re: domoticz in synology as package! Available now.
Posted: Sunday 06 March 2016 12:00
by dtech
jumbotroll wrote: What final release/stable version do you not find?
And what issue do you have?
What NAS do you have?
What DSM version do you have?
I try to update to the latest 4868 from version:
Version: 3.4836
Build Hash: 214e060-modified
Compile Date: 2016-03-03 09:16:19
When upgrade finish I have error message:
2016-03-06 11:53:31.911 Error: Error executing script command (/usr/local/domoticz/var/scripts/update_domoticz /usr/local/domoticz/var/). returned: 32512
I'm on the xpenology latest version.
Posted: Sunday 06 March 2016 12:19
by jumbotroll
You have to update domoticz from the package center on Synology NAS or package center. in XPenology
You can NOT update automatic from the domoticz interface, so please disable automatic check.
Do a Manual Install or Add http://www.jadahl.com/domoticz_beta/ to your Synology NAS Package Center sources !
V3.4868 is not yet uploaded. and this is beta!
Posted: Sunday 06 March 2016 12:24
by dtech
Thank you very much for info, I will wait till latest package will be ready.
Posted: Sunday 06 March 2016 12:25
by jumbotroll
dtech wrote:Thank you very much for info, I will wait till latest package will be ready.
BTW XPenology use Bromolow packages.
Posted: Monday 07 March 2016 16:34
by cherowley
Version: 3.4868
Build Hash: 61da2d3-modified
Compile Date: 2016-03-06 08:36:49
The On delay / Off delay system in switches is broken.
Value in Off delay makes the switch On Delay as well as off delay.
The On delay is now ignored...
This issue is only in this beta...
UPDATE: The problem only manifests when switching on from the UI, is a switch is set using a lua script then the delays all work fine.
Posted: Monday 07 March 2016 16:40
by gizmocuz
Please do not cross post on here and on github, working on it as you can see on the github issue page, hope to solve it soon
Posted: Monday 07 March 2016 16:48
by cherowley
Many apologies gizmocuz :)
Posted: Monday 07 March 2016 17:22
by gizmocuz
No worries... lets continue the discussion on github... i already made some tests
Posted: Monday 07 March 2016 18:16
by Gravityz
Hi Jumbotroll,
can you compile 4909 or later for me? (synology 112+)
i do not know how to do this myself(that's why i use your build)
i need to test out a Hue bug(percentage not displayed) which might be fixed in that build.
thanks
Posted: Monday 07 March 2016 19:33
by jumbotroll
Gravityz wrote:Hi Jumbotroll,
thanks
Here you go : http://www.jadahl.com/domoticz_beta/?arch=88f6281
Posted: Monday 07 March 2016 21:17
by Gravityz
wow that was quick.
tested it and it seems the bug is gone
thanks
Posted: Tuesday 08 March 2016 17:03
by mortyre
jumbotroll wrote:Domoticz on synology use SSL port:8443
thank you very much :D
Posted: Thursday 10 March 2016 11:28
by mpalyga
Hi Jumbotroll
looking forward to old DSM version and Synology packages available. ANY plan on roadmap to have Domoticz 3.4834 (stable) available on DSM 4.x ?
/regards m.
Posted: Thursday 10 March 2016 12:57
by jumbotroll
mpalyga wrote:Hi Jumbotroll
/regards m.
There are often problems to cross compile the older DSM versions due to old toolchains . It will probably not be as much updates to DSM 4.x versions, but what NAS and DSM version are you using?
Posted: Thursday 10 March 2016 14:42
by mpalyga
indeed it is. I use Synology 411j with DSM 4.3-3827u7 running on ARM 88f6281 (only reason for use DSM 4.3 is that it is much faster than version 5.x)
I use latest available version of domoticz and installed from package available here your website for ARM 88f6281. it works extremly well....
if you have a little to to build for DSM 4.3 and for ARM 88f6281, i can deeply test on my NAS :)
thx for help. and really fast response ..
Posted: Thursday 10 March 2016 17:38
by jumbotroll
mpalyga wrote:indeed it is. I use Synology 411j with DSM 4.3-3827u7 running on ARM 88f6281 (only reason for use DSM 4.3 is that it is much faster than version 5.x)
Here you go :)
domoticz_88f6281-4.2_3.0.4933-7.spk
domoticz_88f6282-4.2_3.0.4933-7.spk
domoticz_88f6281-4.3_3.0.4933-7.spk
domoticz_88f6282-4.3_3.0.4933-7.spk
http://www.jadahl.com/domoticz_old/inde ... llist=true
Posted: Thursday 10 March 2016 17:52
by mpalyga
Wow and BIG THANK YOU. looking to your support i can see that it was well spent money for android client. Let me test and back to you with results, but im pretty sure that no bugs included. thx a lot one again
Posted: Saturday 12 March 2016 11:13
by mschut
@jumbotroll (cant send you a PM anymore).
I just performed an upgrade to the latest DSM 6.0 beta (NC). Unfortunately I noticethat the HGI80 is not recogniosed anymore. Glad to test any future adaptations ;)
Posted: Saturday 12 March 2016 12:49
by jumbotroll
mschut wrote:@jumbotroll (cant send you a PM anymore).
Has unfortunately not had time to modify all ti_usb_3410_5052.h and ti_usb_3410_5052.c drivers in DSM 6.0 toolchains.
Has made one exception for arch-qoriq.
You may want to test the latest version :)
http://www.jadahl.com/domoticz_beta_6/?arch=qoriq
Posted: Saturday 12 March 2016 13:10
by mschut
Perfect! Upgrade, restart and up and running again!
Verstuurd vanaf mijn SM-G920F met Tapatalk
