Page 35 of 94
Posted: Thursday 03 March 2016 20:32
by jumbo70
@jumbotroll
DSM5.2 5644
jumbotroll wrote:jumbo70 wrote:Hi,
The 'killall synousbmodemd' command did not help. Actually 'No process was killed'.
Any idea if the Vision or Zwave.me usb stick will give similar problem, or is this problem specific for the Aeotec gen5 stick?
kind regards,
Jumbo70
What DSM version du you have on your NAS? 4.2,4.3 or 5.2?
Posted: Thursday 03 March 2016 20:40
by jumbotroll
jumbo70 wrote:@jumbotroll
DSM5.2 5644
kind regards,
Jumbo70
Ok.
Can you test this version?
domoticz_88f6281-5.2_3.0.4846-7.spk with cdc-acm drivers.
Manually download and install from package center.
http://www.jadahl.com/domoticz_beta/pac ... 4846-7.spk
Posted: Thursday 03 March 2016 23:11
by G3rard
Thanks jumbotroll!
Just installed 3.4834 and it's seems to be working fine.
Posted: Thursday 03 March 2016 23:24
by deennoo
I start to move from a PI to a Syno.
Before putting all on my real syno, i made a "test" on an xpenology.
A question : what about hard drive stop ? On normal use when don't using the Nas, hard drive stop spinning.
As domoticz always write logs on DB, hard drive can't stop, is there any problème with this ?
Posted: Friday 04 March 2016 12:40
by j0bro
I just upgraded my Synology DS215j (armada375) to DSM 6.0-7307 (RC), backed up my Domoticz db, uninstalled Domoticz, added the
http://www.jadahl.com/domoticzbeta/ package source and installed the Domoticz beta package (version 3.0.4836-7). However, it won't run and complains about libstdc++.so.6 (see below). Anything else I should do? Thanks!
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_thread.so.1.59.0)
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_date_time.so.1.59.0)
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_system.so.1.59.0)
Posted: Friday 04 March 2016 15:55
by Gravityz
wanted to install the stable version but instead picked 4836.
what exiting bugs did you squash in that version compared to the 4834 version
Posted: Friday 04 March 2016 18:14
by gizmocuz
Posted: Friday 04 March 2016 19:32
by Gravityz
after installing 4836 i noticed the following(more people seem to have this problem)
Qubino ZMNHAD1 module
Temp:WORKING
kWh meter:NOT WORKING, NOT COUNTING
powermeter:WORKING
i have 2 kWh meters for qubino and both are not working.
fibaro FGD212
powermeter:WORKING
kWh meter:WORKING
Fibaro FGWPE plug
powermeter:WORKING
kWh meter:WORKING
Posted: Friday 04 March 2016 21:28
by jumbo70
@jumbotroll,
Thanks for the support. Unfortunately I can't get it to work.
The aeotec stick is blinking, but does not show up in the external devices list nor do I see it as serial port within domoticz when selecting openzwave usb.
I added output of dmesg |grep usb. Maybe that might help.
PS, some other memory usb sticks pop-up immediately as external devices.
Thanks,
jumbo70
jumbotroll wrote:jumbo70 wrote:@jumbotroll
DSM5.2 5644
Ok.
Posted: Saturday 05 March 2016 5:27
by Pierryck
Thanks for this package, I réally enjoy to run Domoticz on my synology.
Posted: Saturday 05 March 2016 11:30
by Vaaben
+1 to J0bro's problem - have the exactly same Syno - and the exactly same problem
j0bro wrote:I just upgraded my Synology DS215j (armada375) to DSM 6.0-7307 (RC), backed up my Domoticz db, uninstalled Domoticz, added the
Posted: Saturday 05 March 2016 12:42
by jumbotroll
I have never compiled domoticz for armada375.
This is the list for DSM6.0
http://www.jadahl.com/domoticz_beta_6/i ... llist=true
Re: RE: Re: domoticz in synology as package! Available now.
Posted: Saturday 05 March 2016 13:18
by j0bro
jumbotroll wrote:j0bro wrote:I just upgraded my Synology DS215j (armada375) to DSM 6.0-7307 (RC), backed up my Domoticz db, uninstalled Domoticz, added the
Well I have been running Domoticz for this architecture for well over a year, via the Synocommunity package but what I understand is that it isn't maintained anymore. My assumption was that my NAS was supported in this newer package version, but it seems I am out of luck.
I see you compile for armada370 already, any chance of including armada375 as well? The newer Synologies use this chipset a lot, you would make a lot of us happy [SMILING FACE WITH SMILING EYES]
Verstuurd vanaf mijn Nexus 6P met Tapatalk
Posted: Saturday 05 March 2016 13:38
by jumbotroll
Ok, I have added toolchain and compiled for armada375 DSM 6.0 you can test.
http://www.jadahl.com/domoticz_beta_6/?arch=armada375
Re: RE: Re: RE: Re: domoticz in synology as package! Available now.
Posted: Saturday 05 March 2016 18:27
by j0bro
Hey that's terrific! Will test and report back as soon as I get home tonight. Thanks in advance my friend!
EDIT: Everything working just fine again, thanks for your blazing fast support!
Posted: Sunday 06 March 2016 11:02
by dtech
Ok the synology I cannot update to the latest stable version, shall I do same magic, or wait till Jumbotroll will realize new version ?
Many thank
Posted: Sunday 06 March 2016 11:20
by Egregius
Yes, working on a DS1513+ with DSM 6 beta with a S2 stick and rfxcom.
Moved from RPi2 to Syno because I had a new site to host there and there's builtin support for let's encrypt certificates now.
First moved my floorplan from RPi to Syno but that gived from time to time a timeout while connecting to Domoticz.
Now that everything is on the Syno it feels even faster than before
Posted: Sunday 06 March 2016 11:21
by Egregius
dtech wrote:Hi,
Many thank
Because Syno can be dangerous to update files I disabled the update check inside Domoticz and will wait for a package update from Jumbotroll.
Guess that's the safest way to keep it stable.
Posted: Sunday 06 March 2016 11:35
by dtech
This was my idea that with Synology this will not be so easy, thx for info will wait for final realize.
Posted: Sunday 06 March 2016 11:43
by jumbotroll
dtech wrote:Hi,
Many thank
What latest release/stable version do you not find?
And what issue do you have?
What NAS do you have?
What DSM version do you have?
