Dashticz - Show your dashboard and how-to's!
HansieNL
Post by HansieNL »
EdwinK wrote: Wednesday 11 December 2019 18:01 @Hansienl how did you get that uptime tile look so nice. I only got:
A dzvents script fills a Domoticz user variable with the uptime string and created a Dashticz variable block.
-- dzuptime.lua
-- Set Domoticz Uptime as User Variable string
	logging = {
		-- level = domoticz.LOG_DEBUG, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
		level = domoticz.LOG_INFO,
		marker = "(Uptime)"
		timer = {
			"every minute"
	execute = function(dz)
		local days		= dz.startTime.daysAgo
		local hours		= dz.startTime.hoursAgo%24
		local minutes	= dz.startTime.minutesAgo%60
		dz.variables("Uptime").set(days .. " dagen, " .. hours .. " uur en " .. minutes .. " minuten")
blocks['v3'] = { //Uptime
    title: 'Uptime',
	image: '../custom/img/uptime.png',
	switch: true,
	width: 12
Blah blah blah
EdwinK
Post by EdwinK »
HansieNL wrote: Thursday 12 December 2019 2:02
O, that UV was gone after restoring a backup. And it also helps to use the correct variable number ;)
martin82
Post by martin82 »
wauw i see verry nice dashboards.
i started with dashticz but i'm a noob i can install and run dashticz .
but how to setup a nice dashboard that is to difficult for me, can someome help me with setting up the dashboard.
i read al all the wikki but sorry for me is it to difficult.
i run domoticz i use sonoff flashd and zigbee2mqtt .
who can help me to setting up a nice dashboard for dashticz ??
greeet
martin
martin82
Post by martin82 »
i got a pm but i can not answer to you lokonli .
to feew message on this board wroten.
but i can speak dutch :)
i hope that you can help me :)
gbianchi
Post by gbianchi »
Thank for domoticz and dashticz!
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
[Noob mode on]
OK, I need some help here, please! I have the coding skills of a Kangaroo and I know I am doing something wrong (probably in Domoticz).
I have created the lua script and placed it in the dzVents folder (dzVEnts is enabled in settings). Restarted Domoticz but the variable is not filled with the value. Variable is of type "string" and is named "Uptime
Any help, tips, insights are truly appreciated!
[/Noob mode on]
Greetz,
Sjonnie
YouLess Energy meter
pvklink
Domoticz version: latest b
Post by pvklink »
I made a dashticz screen for my grandfather so he can manage his lights without walking to much (86 years old)
Because of his age i have to pay attention to font-size etc.
Last thing to tdo is aligment.
I managed to align block titles horizontal but
vertical alignment does not work , i tried several options...
.block_391 .title {font-size:26px;vertical-align: center}
.block_392 .title {font-size:26px;vertical-align: middle}
.block_393 .title {font-size:26px; padding-top: 6px; }
Somebody tried this ?
Jablotron connection, Ikea
clinkadink
Post by clinkadink »
pvklink wrote: Wednesday 01 January 2020 19:39 Hi,
As far as I can recall, vertical-align will only work on inline elements, i.e. not a div (which is what you are trying apply it to). Notwitstanding, vertical-align not used much anymore, now that Flex is available. If you don't want to use Flex (which does work with Dashticz), you can try making your div (i.e the element the title sits in) an inline element, using either of the first two options.
style="display:inline-block;vertical-align:middle"
style="display:table-cell;vertical-align:middle"
If you don't want to change it to either of the above, then vertical-align needs a fixed height to calculate the 'middle'.
style="height:20px;vertical-align:middle"
If that doesn't work, another (crude) method is to change the line-height, by any of these methods:
style="line-height:1.6;"
style="line-height:200%;"
style="line-height:30px;"
Personally, I would always recommend Flex:
style="display:flex;align-items:center;"
The great thing about Flex, is that it is responsive. It will adapt per browser screen/resolution/orientation.
clinkadink
Domoticz is a powerful bit of kit, but the UI is dated, despite some good themes, like Machinon. Dashticz really allows to you to maximise and showcase the true potential of Domoticz. I have only being using it for 2 weeks, but already love it. Many thanks.
pvklink
Post by pvklink »
thanks @clinkadink,
i will try the various options...
EdwinK
Post by EdwinK »
clinkadink wrote: Thursday 02 January 2020 22:11 Image
Looks nice and clean.
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Nice,
could you post custom js and css and so?
Sjonnie2017
I have been experimenting with Dashticz for a few days now and the configuration is getting to a point where it is usable to replace my physical remotes and use my PC/tablet or phone to drive lights and shutters. That was the main goal. I have been using Domoticz for a while now and wanted to organize my dashboards in a more flexible way than Domoticz provided; hence Dashticz :) I have no need for online information (well... maybe weather forecasts would be nice) and I don't want my calendar or IP cam on the dash. I like things "simple" :mrgreen:
I still have some issues to iron out and some items to add (when they arrive).
Items to add:
A - ZigBee smoke alerts
B - ZigBee temperature/humidity sensors
Issues to iron out:
1 - getting the color slider to show up (see thread here: https://www.domoticz.com/forum/viewtopi ... 67&t=30784)
2 - having the water sensors showing the last update and not showing up like a security device
3 - getting the settings/full screen buttons to align properly on first desktop screen
4 - really love to have the group of shutters show up and act like individual shutters - I have applied a workaround for now (see thread here: https://www.domoticz.com/forum/viewtopi ... 67&t=30718)
Any tips on the above issues are greatly appreciated :)
The screenshots
Desktop:
Tablet:
Phone:
My (anonimised) config.js
// Algemene configuratie
var config = {}
config['domoticz_ip'] = 'http://xxx.xxx.xxx.xxx:2080';
config['login_timeout'] = '60';
config['user_name'] = '0';
config['pass_word'] = '0';
config['app_title'] = '@Home';
config['room_plan'] = '0';
config['default_news_url'] = 'https://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['default_cors_url'] = '';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = '0';
config['standby_call_url_on_end'] = '0';
config['theme'] = 'default';
config['background_image'] = 'img/bg15.jpg';
config['standby_after'] = '0';
config['start_page'] = '1';
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '0';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = '0';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '0';
config['gm_zoomlevel'] = '0';
config['gm_latitude'] = '0';
config['gm_longitude'] = '0';
config['speak_lang'] = 'en-US';
config['wu_api'] = '';
config['wu_city'] = '';
config['wu_name'] = '0';
config['wu_country'] = 'NL';
config['owm_api'] = 'xxx';
config['owm_city'] = 'Wilnis';
config['owm_name'] = 'Wilnis';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '4';
config['idx_moonpicture'] = '0';
config['owm_days'] = true;
config['owm_min'] = true;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['longfonds_zipcode'] = '';
config['longfonds_housenumber'] = '';
config['switch_horizon'] = '0';
config['host_nzbget'] = '0';
config['spot_clientid'] = '0';
config['sonarr_url'] = '0';
config['sonarr_apikey'] = '0';
config['sonarr_maxitems'] = '0';
config['garbage_company'] = '';
config['garbage_icalurl'] = '0';
config['google_api_key'] = '0';
config['garbage_calendar_id'] = '0';
config['garbage_zipcode'] = '0';
config['garbage_street'] = '0';
config['garbage_housenumber'] = '0';
config['garbage_housenumberadd'] = '0';
config['garbage_maxitems'] = '0';
config['garbage_width'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['no_rgb'] = 0;
config['hide_off_button'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 1;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['hide_mediaplayer'] = 0;
// Screen definitions
var max_resolution_desktop    = 'default';
var max_resolution_tablet     = 'tablet';
var max_resolution_phone      = 'phone';
// Title Definitions
var title_lampen              = 'title_lampen';
var title_dimmers             = 'title_dimmers';
var title_lampen_2200         = 'title_lampen_2200';
var title_vochtsensors        = 'title_vochtsensors';
var title_ventilatoren        = 'title_ventilatoren'
var title_ventilator1         = 'title_ventilator1';
var title_ventilator2         = 'title_ventilator2';
var title_rookmelders         = 'title_rookmelders';
var title_gas_en_elektra      = 'title_gas_en_elektra';
var title_elektra             = 'title_elektra';
var title_gas                 = 'title_gas';
var title_luikensets          = 'title_luikensets';
var title_luiken              = 'title_luiken';
var title_datum_tijd          = 'title_datum_tijd'
var title_weer                = 'title_weer';
var title_klimaatsensors      = 'title_klimaatsensors';
var title_deurbel             = 'title_deurbel';
var title_raspberry           = 'title_raspberry';
var title_alle_schakelaars    = 'title_alle_schakelaars';
var title_domoticz            = 'title_domoticz';
var title_uptime              = 'title_uptime';
var title_hobby_verlichting   = 'title_hobby_verlichting';
var title_settings            = 'title_settings';
// IDX Definitions
// Verlichting
var ventilator_lamp            = 47;
var simon_levelt               = 59;
var wandbord                   = 60;
var cd_rek                     = 61;
var eettafel                   = 122;
var plafondspot_tv             = 64;
var secretaire                 = 117;
var buffetkast                 = 66;
var dressoir                   = 73;
var traplicht                  = 75;
var plafondspot_haard          = 76;
var hobby_yyy                  = 78;
var hobby_algemeen             = 79;
var slaapkamer_bed             = 82;
var slaapkamer_plafond         = 83;
var hobby_xxx                  = 85;
var theaterspot                = 133;
var mondriaan_tv               = 107;
var mondriaan_dressoir         = 135;
// Luiken
var luik_keuken                = 63;
var luik_dressoir              = 67;
var luik_haard                 = 68;
var luik_kop_tuin              = 69;
var luik_tuindeur              = 70;
var luik_tuinraam              = 71;
var luik_secretaire            = 72;
var luik_eettafel              = 77;
var luik_hobby_waterzijde      = 80;
var luik_hobby_kop             = 81;
// Luikensets (Scenes)
var luiken_waterzijde          = 's1';
var luiken_tuinzijde           = 's2';
var luiken_hobby               = 's3';
// Experiment met individuele scenes voor openen en sluiten
var luiken_hobby_open          = 's7';
var luiken_hobby_dicht         = 's8';
var luiken_water_open          = 's9';
var luiken_water_dicht         = 's10';
var luiken_tuin_open           = 's11';
var luiken_tuin_dicht          = 's12';
// Lampenset
var lampen_2200                = 's4';
var alle_lampen_uit            = 's13';
// Weer
var tuinvilla_buiten           = 89;
var schuur                     = 90;
var tuinvilla                  = 91;
var kelder_achter              = 92;
var regen                      = 111;
var grafiek_regen              = 'graph_111';
// Sensoren
var vochtsensor_ontvochtiger   = 100;
var vochtsensor_cv_ketel       = 101;
var vochtsensor_wasmachine     = 102;
var vochtsensor_waterontharder = 103;
var rookmelder_woonkamer       = 97;
var rookmelder_gang            = 115;
var rookmelder_slaapkamer      = 99;
// Gas en elektra
var elektra                    = 112;
var gas                        = 113;
var elektra_nu                 = '112_1';
var elektra_vandaag            = '112_2';
var elektra_totaal             = '112_3';
var grafiek_gas                = 'graph_113';
var grafiek_elektra            = 'graph_112';
// Deurbel
var deurbel                    = 104;
// Ventilator (1 en 2)
var ventilator1_stand_0         = 48;
var ventilator1_stand_1         = 49;
var ventilator1_stand_2         = 50;
var ventilator1_stand_3         = 51;
// Sensoren RPi
var rpi_cpu_load                = 125;
var rpi_temp                    = 126;
var rpi_mem_usage               = 127;
// Variabelen uit Domoticz
var uptime                      = 'v5';
// Dummy blocks
var dummy9                      = 'dummy9'
// Buttons
var buttons = {}
// Blocks
var blocks = {}
// Lampen
// Lampen uit om 22.00 uur
blocks[lampen_2200] = {}
blocks[lampen_2200]['title'] = 'Lampen uit om 22.00';
blocks[lampen_2200]['width'] = 3;
blocks[lampen_2200]['hide_data'] = true;
blocks[alle_lampen_uit] = {}
blocks[alle_lampen_uit]['title'] = 'Alles uit';
blocks[alle_lampen_uit]['width'] = 3;
// Title: Lampen
blocks[title_lampen] = {}
blocks[title_lampen]['type'] = 'blocktitle'
blocks[title_lampen]['title'] = 'Lampen'
blocks[title_lampen]['image'] = 'lights.png'
// Title: Alle_Schakelaars
blocks[title_alle_schakelaars] = {}
blocks[title_alle_schakelaars]['type'] = 'blocktitle'
blocks[title_alle_schakelaars]['title'] = 'Alle Schakelaars'
blocks[title_alle_schakelaars]['image'] = 'lights.png'
// Title: Hobby Verlichting
blocks[title_hobby_verlichting] = {}
blocks[title_hobby_verlichting]['type'] = 'blocktitle'
blocks[title_hobby_verlichting]['title'] = 'Verlichting Hobby'
blocks[title_hobby_verlichting]['image'] = 'lights.png'
// Lampen - Simon Lévelt
blocks[simon_levelt] = {}
blocks[simon_levelt]['title'] = 'Simon Lévelt';
blocks[simon_levelt]['width'] = 4;
blocks[simon_levelt]['hide_data'] = false;
// Lampen - Wandbord
blocks[wandbord] = {}
blocks[wandbord]['title'] = 'Wandbord';
blocks[wandbord]['width'] = 4;
blocks[wandbord]['hide_data'] = false;
// Lampen - CD Rek
blocks[cd_rek] = {}
blocks[cd_rek]['title'] = 'CD Rek';
blocks[cd_rek]['width'] = 4;
blocks[cd_rek]['hide_data'] = false;
// Lampen - Secretaire
blocks[secretaire] = {}
blocks[secretaire]['title'] = 'Secretaire';
blocks[secretaire]['width'] = 3;
blocks[secretaire]['hide_data'] = false;
// Lampen - Buffetkast
blocks[buffetkast] = {}
blocks[buffetkast]['title'] = 'Buffetkast';
blocks[buffetkast]['width'] = 3;
blocks[buffetkast]['hide_data'] = false;
// Lampen - Dressoir
blocks[dressoir] = {}
blocks[dressoir]['title'] = 'Dressoir';
blocks[dressoir]['width'] = 3;
blocks[dressoir]['hide_data'] = false;
// Lampen - Mondriaan TV
blocks[mondriaan_tv] = {}
blocks[mondriaan_tv]['title'] = 'Mondriaan TV';
blocks[mondriaan_tv]['width'] = 3;
blocks[mondriaan_tv]['hide_data'] = false;
// Lampen - Mondriaan Dressoir
blocks[mondriaan_dressoir] = {}
blocks[mondriaan_dressoir]['title'] = 'Mondriaan Dressoir';
blocks[mondriaan_dressoir]['width'] = 3;
blocks[mondriaan_dressoir]['hide_data'] = false;
// Lampen - Traplicht
blocks[traplicht] = {}
blocks[traplicht]['title'] = 'Traplicht';
blocks[traplicht]['width'] = 3;
blocks[traplicht]['hide_data'] = false;
// Title Dimmers
blocks[title_dimmers] = {}
blocks[title_dimmers]['type'] = 'blocktitle'
blocks[title_dimmers]['title'] = 'Dimmers'
blocks[title_dimmers]['image'] = 'dimmer2.png'
// Lampen - Theaterspot
blocks[theaterspot] = {}
blocks[theaterspot]['title'] = 'Theaterspot';
blocks[theaterspot]['width'] = 6;
blocks[theaterspot]['hide_data'] = false;
// Dimmers - Eettafel
blocks[eettafel] = {}
blocks[eettafel]['title'] = 'Eettafel';
blocks[eettafel]['width'] = 6;
//blocks[eettafel]['hide_data'] = false;
// Dimmers - Plafondspots TV Dimmer
blocks[plafondspot_tv] = {}
blocks[plafondspot_tv]['title'] = 'Plafondspots TV';
blocks[plafondspot_tv]['width'] = 6;
blocks[plafondspot_tv]['hide_data'] = false;
// Dimmers - Plafondspot Haard Dimmer
blocks[plafondspot_haard] = {}
blocks[plafondspot_haard]['title'] = 'Plafondspots Haard';
blocks[plafondspot_haard]['width'] = 6;
blocks[plafondspot_haard]['hide_data'] = false;
// Lampen - Hobby xxx Dimmer
blocks[hobby_xxx] = {}
blocks[hobby_xxx]['title'] = 'Hobby xxx';
blocks[hobby_xxx]['width'] = 4;
blocks[hobby_xxx]['hide_data'] = false;
blocks[hobby_yyy] = {}
blocks[hobby_yyy]['title'] = 'Hobby yyy';
blocks[hobby_yyy]['width'] = 4;
blocks[hobby_yyy]['hide_data'] = false;
// Lampen - Hobby voorraad Dimmer
blocks[hobby_algemeen] = {}
blocks[hobby_algemeen]['title'] = 'Hobby Voorraad';
blocks[hobby_algemeen]['width'] = 4;
blocks[hobby_algemeen]['hide_data'] = false;
// Sensors
// Title Vochtsensors
blocks[title_vochtsensors] = {}
blocks[title_vochtsensors]['type'] = 'blocktitle'
blocks[title_vochtsensors]['title'] = 'Vochtsensors'
blocks[title_vochtsensors]['image'] = 'water_set.png'
// Vochtsensors - Ontvochtiger
blocks[vochtsensor_ontvochtiger] = {};
blocks[vochtsensor_ontvochtiger]['title'] = 'Ontvochtiger';
blocks[vochtsensor_ontvochtiger]['width'] = 3;
blocks[vochtsensor_ontvochtiger]['image'] = 'water.png';
blocks[vochtsensor_ontvochtiger]['protected'] = true;
blocks[vochtsensor_ontvochtiger]['hide_data'] = false;
// Vochtsensors - CV ketel
blocks[vochtsensor_cv_ketel] = {};
blocks[vochtsensor_cv_ketel]['title'] = 'CV ketel';
blocks[vochtsensor_cv_ketel]['width'] = 3;
blocks[vochtsensor_cv_ketel]['image'] = 'water.png';
blocks[vochtsensor_cv_ketel]['protected'] = true;
blocks[vochtsensor_cv_ketel]['hide_data'] = false;
// Vochtsensors - Wasmachine
blocks[vochtsensor_wasmachine] = {};
blocks[vochtsensor_wasmachine]['title'] = 'Wasmachine';
blocks[vochtsensor_wasmachine]['width'] = 3;
blocks[vochtsensor_wasmachine]['image'] = 'water.png';
blocks[vochtsensor_wasmachine]['protected'] = true;
blocks[vochtsensor_wasmachine]['hide_data'] = false;
// Vochtsensors - Waterontharder
blocks[vochtsensor_waterontharder] = {};
blocks[vochtsensor_waterontharder]['title'] = 'Waterontharder';
blocks[vochtsensor_waterontharder]['width'] = 3;
blocks[vochtsensor_waterontharder]['image'] = 'water.png';
blocks[vochtsensor_waterontharder]['protected'] = true;
blocks[vochtsensor_waterontharder]['hide_data'] = false;
// Ventilator
// Title Ventilatoren
blocks[title_ventilatoren] = {}
blocks[title_ventilatoren]['type'] = 'blocktitle'
blocks[title_ventilatoren]['title'] = 'Ventilatoren'
blocks[title_ventilatoren]['image'] = 'fan_set.png'
blocks[title_ventilatoren]['width'] = 12;
// Title Ventilator1
blocks[title_ventilator1] = {}
blocks[title_ventilator1]['type'] = 'blocktitle'
blocks[title_ventilator1]['title'] = 'Ventilator 1'
blocks[title_ventilator1]['image'] = 'fan.png'
// Title Ventilator2
blocks[title_ventilator2] = {}
blocks[title_ventilator2]['type'] = 'blocktitle'
blocks[title_ventilator2]['title'] = 'Ventilator 2'
blocks[title_ventilator2]['image'] = 'fan.png'
// Hier moet nog (steeds!!) iets slims komen om de standen van de ventilator te kiezen en in 1 knop onder te brengen
blocks[ventilator1_stand_0] = {}
blocks[ventilator1_stand_0]['title'] = 'Fan 1 uit'
blocks[ventilator1_stand_0]['width'] = 3;
blocks[ventilator1_stand_0]['image'] = 'fan_off.png'
blocks[ventilator1_stand_1] = {}
blocks[ventilator1_stand_1]['title'] = 'Fan 1 stand 1'
blocks[ventilator1_stand_1]['width'] = 3;
blocks[ventilator1_stand_1]['imageOn'] = 'fan_on.png'
blocks[ventilator1_stand_1]['imageOff'] = 'fan_off.png'
blocks[ventilator1_stand_2] = {}
blocks[ventilator1_stand_2]['title'] = 'Fan 1 stand 2'
blocks[ventilator1_stand_2]['width'] = 3;
blocks[ventilator1_stand_2]['imageOn'] = 'fan_on.png'
blocks[ventilator1_stand_2]['imageOff'] = 'fan_off.png'
blocks[ventilator1_stand_3] = {}
blocks[ventilator1_stand_3]['title'] = 'Fan 1 stand 3'
blocks[ventilator1_stand_3]['width'] = 3;
blocks[ventilator1_stand_3]['imageOn'] = 'fan_on.png'
blocks[ventilator1_stand_3]['imageOff'] = 'fan_off.png'
// Rookmelders
// Title rookmelders
blocks[title_rookmelders] = {}
blocks[title_rookmelders]['type'] = 'blocktitle'
blocks[title_rookmelders]['title'] = 'Rookmelders'
blocks[title_rookmelders]['image'] = 'smoke_set.png'
//// Rookmelder Woonkamer
//blocks[rookmelder_woonkamer] = {};
//blocks[rookmelder_woonkamer]['title'] = 'Woonkamer';
//blocks[rookmelder_woonkamer]['width'] = 4;
//blocks[rookmelder_woonkamer]['image'] = 'smoke.png'
//blocks[rookmelder_woonkamer]['protected'] = true;
//blocks[rookmelder_woonkamer]['hide_data'] = true;
//// Rookmelder Gang
//blocks[rookmelder_gang] = {};
//blocks[rookmelder_gang]['title'] = 'Gang';
//blocks[rookmelder_gang]['width'] = 4;
//blocks[rookmelder_gang]['image'] = 'smoke.png'
//blocks[rookmelder_gang]['protected'] = true;
//blocks[rookmelder_gang]['hide_data'] = true;
//// Rookmelder Slaapkamer
//blocks[rookmelder_slaapkamer] = {};
//blocks[rookmelder_slaapkamer]['title'] = 'Slaapkamer';
//blocks[rookmelder_slaapkamer]['width'] = 4;
//blocks[rookmelder_slaapkamer]['image'] = 'smoke.png'
//blocks[rookmelder_slaapkamer]['protected'] = true;
//blocks[rookmelder_slaapkamer]['hide_data'] = true;
// "Slimme" meter
// Title Gas en Elektra
blocks[title_gas_en_elektra] = {}
blocks[title_gas_en_elektra]['type'] = 'blocktitle'
blocks[title_gas_en_elektra]['title'] = 'Gas en Elektra'
blocks[title_gas_en_elektra]['image'] = 'gas_electricity.png'
blocks[title_elektra] = {}
blocks[title_elektra]['type'] = 'blocktitle'
blocks[title_elektra]['title'] = 'Elektra'
blocks[title_gas] = {}
blocks[title_gas]['type'] = 'blocktitle'
blocks[title_gas]['title'] = 'Gas'
// componenten gas en elektra
blocks[elektra_nu] = {}
blocks[elektra_nu]['width'] = 4;
blocks[elektra_nu]['show_lastupdate'] = false;
blocks[elektra_nu]['protected'] = true;
blocks[elektra_vandaag] = {}
blocks[elektra_vandaag]['width'] = 4;
blocks[elektra_vandaag]['show_lastupdate'] = false;
blocks[elektra_vandaag]['protected'] = true;
blocks[elektra_totaal] = {}
blocks[elektra_totaal]['width'] = 4;
blocks[elektra_totaal]['show_lastupdate'] = false;
blocks[elektra_totaal]['protected'] = true;
blocks[gas] = {}
blocks[gas]['width'] = 6;
blocks[gas]['show_lastupdate'] = false;
blocks[gas]['protected'] = true;
blocks[grafiek_elektra] = {}
blocks[grafiek_elektra]['title'] = 'Elektriciteit';
blocks[grafiek_elektra]['width'] = 12;
blocks[grafiek_elektra]['height'] = '400px';
//blocks[grafiek_elektra]['height'] = '1050px !important';
//blocks[grafiek_elektra]['graph'] = 'bar';
//blocks[grafiek_elektra]['legend'] =
blocks[grafiek_elektra]['pointFillColors'] = ['#aaa9a9', '#7e7e7e'];
blocks[grafiek_elektra]['pointSize'] = 3;
blocks[grafiek_elektra]['lineColors'] = ['#aaa9a9', '#7e7e7e'];
blocks[grafiek_gas] = {}
blocks[grafiek_gas]['title'] = 'Gas';
blocks[grafiek_gas]['width'] = 12;
blocks[grafiek_gas]['height'] = '400px';
//blocks[p1_grafiek_gas]['graph'] = 'bar';
//blocks[p1_grafiek_gas]['pointFillColors'] = ['#aaa9a9', '#7e7e7e'];
//blocks[p1_grafiek_gas]['pointSize'] = 3;
//blocks[p1_grafiek_gas]['lineColors'] = ['#aaa9a9', '#7e7e7e'];
//Rolluiken
// Title Luikensets
blocks[title_luikensets] = {}
blocks[title_luikensets]['type'] = 'blocktitle'
blocks[title_luikensets]['title'] = 'Luikensets'
blocks[title_luikensets]['image'] = 'shutter_set.png'
// Luikenset - Waterzijde
//blocks[luiken_waterzijde] = {}
//blocks[luiken_waterzijde]['title'] = 'Waterzijde';
//blocks[luiken_waterzijde]['width'] = 6;
//blocks[luiken_waterzijde]['imageOff'] = 'blinds_open.png';
//blocks[luiken_waterzijde]['imageOn'] = 'blinds_closed.png';
//blocks[luiken_waterzijde]['hide_data'] = false;
//blocks[luiken_waterzijde]['protected'] = false;
// Luikenset Waterzijde Open
blocks[luiken_water_open] = {}
blocks[luiken_water_open]['title'] = 'Water Open';
blocks[luiken_water_open]['width'] = 3;
blocks[luiken_water_open]['image'] = 'blinds_set_open.png'
blocks[luiken_water_open]['hide_data'] = false;
// Luikenset Waterzijde Dicht
blocks[luiken_water_dicht] = {}
blocks[luiken_water_dicht]['title'] = 'Water Dicht';
blocks[luiken_water_dicht]['width'] = 3;
blocks[luiken_water_dicht]['image'] = 'blinds_set_closed.png'
blocks[luiken_water_dicht]['hide_data'] = false;
// Luikenset Hobby Open
blocks[luiken_tuin_open] = {}
blocks[luiken_tuin_open]['title'] = 'Tuin Open';
blocks[luiken_tuin_open]['width'] = 3;
blocks[luiken_tuin_open]['image'] = 'blinds_set_open.png'
blocks[luiken_tuin_open]['hide_data'] = false;
// Luikenset Hobby Dicht
blocks[luiken_tuin_dicht] = {}
blocks[luiken_tuin_dicht]['title'] = 'Tuin Dicht';
blocks[luiken_tuin_dicht]['width'] = 3;
blocks[luiken_tuin_dicht]['image'] = 'blinds_set_closed.png'
blocks[luiken_tuin_dicht]['hide_data'] = false;
blocks[luiken_hobby_open] = {}
blocks[luiken_hobby_open]['title'] = 'Hobby Open';
blocks[luiken_hobby_open]['width'] = 3;
blocks[luiken_hobby_open]['image'] = 'blinds_set_open.png'
blocks[luiken_hobby_open]['hide_data'] = false;
blocks[luiken_hobby_dicht] = {}
blocks[luiken_hobby_dicht]['title'] = 'Hobby Dicht';
blocks[luiken_hobby_dicht]['width'] = 3;
blocks[luiken_hobby_dicht]['image'] = 'blinds_set_closed.png'
blocks[luiken_hobby_dicht]['hide_data'] = false;
// Title Luiken
blocks[title_luiken] = {}
blocks[title_luiken]['type'] = 'blocktitle'
blocks[title_luiken]['title'] = 'Luiken'
blocks[title_luiken]['image'] = 'shutters.png'
// Luiken - Secretaire
blocks[luik_secretaire] = {}
blocks[luik_secretaire]['width'] = 4;
blocks[luik_secretaire]['title'] = 'Secretaire'
//blocks[luik_secretaire]['hide_data'] = false;
blocks[luik_secretaire]['protected'] = false;
// Luiken - Eettafel
blocks[luik_eettafel] = {}
blocks[luik_eettafel]['width'] = 4;
blocks[luik_eettafel]['title'] = 'Eettafel'
blocks[luik_eettafel]['protected'] = false;
// Luiken - Tuin Raam
blocks[luik_tuinraam] = {}
blocks[luik_tuinraam]['width'] = 4;
blocks[luik_tuinraam]['title'] = 'Tuinraam'
blocks[luik_tuinraam]['protected'] = false;
// Luiken - Tuin Deur
blocks[luik_tuindeur] = {}
blocks[luik_tuindeur]['width'] = 4;
blocks[luik_tuindeur]['title'] = 'Tuindeur'
blocks[luik_tuindeur]['protected'] = false;
// Luiken - Kop Tuin
blocks[luik_kop_tuin] = {}
blocks[luik_kop_tuin]['width'] = 4;
blocks[luik_kop_tuin]['title'] = 'Kop Tuin'
blocks[luik_kop_tuin]['protected'] = false;
// Luiken - Haard
blocks[luik_haard] = {}
blocks[luik_haard]['width'] = 4;
blocks[luik_haard]['title'] = 'Haard'
blocks[luik_haard]['protected'] = false;
// Luiken - Dressoir
blocks[luik_dressoir] = {}
blocks[luik_dressoir]['width'] = 4;
blocks[luik_dressoir]['title'] = 'Dressoir'
blocks[luik_dressoir]['protected'] = false;
// Luiken - Keuken
blocks[luik_keuken] = {}
blocks[luik_keuken]['width'] = 4;
blocks[luik_keuken]['title'] = 'Keuken'
blocks[luik_keuken]['protected'] = false;
// Luiken - Hobby Waterzijde
blocks[luik_hobby_waterzijde] = {}
blocks[luik_hobby_waterzijde]['width'] = 4;
blocks[luik_hobby_waterzijde]['title'] = 'Hobby W'
blocks[luik_hobby_waterzijde]['protected'] = false;
// Luiken - Hobby Kop
blocks[luik_hobby_kop] = {}
blocks[luik_hobby_kop]['width'] = 4;
blocks[luik_hobby_kop]['title'] = 'Hobby K'
blocks[luik_hobby_kop]['protected'] = false;
// Datum / Tijd / Weer (inclusief sensors)
// Title Datum & Tijd
blocks[title_datum_tijd] = {}
blocks[title_datum_tijd]['type'] = 'blocktitle'
blocks[title_datum_tijd]['title'] = 'Datum & Tijd'
// Title Weer
blocks[title_weer] = {}
blocks[title_weer]['type'] = 'blocktitle'
blocks[title_weer]['title'] = 'Weer'
// Title Klimaatsensors
blocks[title_klimaatsensors] = {}
blocks[title_klimaatsensors]['type'] = 'blocktitle'
blocks[title_klimaatsensors]['title'] = 'Klimaatsensors'
blocks[title_klimaatsensors]['image'] = 'climate.png'
blocks[regen] = {}
blocks[regen]['width'] = 12;
//blocks[regen]['show_lastupdate'] = false;
//blocks[regen]['protected'] = true;
blocks[tuinvilla_buiten] = {}
blocks[tuinvilla_buiten]['width'] = 6;
//blocks[tuinvilla_buiten]['show_lastupdate'] = false;
//blocks[tuinvilla_buiten]['protected'] = true;
blocks[tuinvilla] = {}
blocks[tuinvilla]['width'] = 6;
//blocks[tuinvilla]['show_lastupdate'] = false;
//blocks[tuinvilla]['protected'] = true;
blocks[schuur] = {}
blocks[schuur]['width'] = 6;
//blocks[schuur]['show_lastupdate'] = false;
//blocks[schuur]['protected'] = true;
blocks[kelder_achter] = {}
blocks[kelder_achter]['width'] = 6;
//blocks[kelder_achter]['show_lastupdate'] = true;
//blocks[kelder_achter]['protected'] = true;
// Deurbel
// Title Deurbel
blocks[title_deurbel] = {}
blocks[title_deurbel]['type'] = 'blocktitle'
blocks[title_deurbel]['title'] = 'Deurbel'
blocks[title_deurbel]['width'] = 6;
blocks[deurbel] = {}
blocks[deurbel]['width'] = 6;
// Systeeminformatie
blocks[title_domoticz] = {}
blocks[title_domoticz]['type'] = 'blocktitle'
blocks[title_domoticz]['image'] = 'domoticz.png'
blocks[title_domoticz]['title'] = 'Domoticz'
blocks[title_domoticz]['width'] = 12;
blocks[uptime] = {}
//blocks[uptime]['title'] = 'Uptime'
blocks[uptime]['image'] = 'uptime.png'
//blocks[uptime]['switch'] = true;
blocks[uptime]['width'] = 6;
blocks[title_settings] = {}
blocks[title_settings]['type'] = 'blocktitle'
blocks[title_settings]['image'] = ''
blocks[title_settings]['title'] = 'Settings'
blocks[title_settings]['width'] = 6;
blocks['settings'] = {}
blocks['settings']['width'] = 6;
blocks[title_raspberry] = {}
blocks[title_raspberry]['type'] = 'blocktitle'
blocks[title_raspberry]['image'] = 'rpi_128.png'
blocks[title_raspberry]['title'] = 'RPi & Domoticz'
blocks[title_raspberry]['width'] = 12;
blocks[rpi_cpu_load] = {}
blocks[rpi_cpu_load]['image'] = 'cpu2.png'
blocks[rpi_cpu_load]['width'] = 6;
blocks[rpi_temp] = {}
blocks[rpi_temp]['image'] = 'cpu_temp.png'
blocks[rpi_temp]['width'] = 6;
blocks[rpi_mem_usage] ={}
blocks[rpi_mem_usage]['image'] = 'ram2.png'
blocks[rpi_mem_usage]['width'] = 6;
// Dummyblocks
//blocks[dummy9] = {}
//blocks[dummy9]['type'] = 'blocktitle'
//blocks[dummy9]['title'] = ''
//blocks[dummy9]['width'] = 9;
// Columns
var columns = {}
// Laatst gebruikte column nummer is 17 (desktop)
// Aangepaste invulling voor de titelbalk
columns['bar'] = {}
columns['bar']['blocks'] = ['logo','miniclock','sunrise']
// Screen 1 voor desktop
columns[1] = {}
columns[1]['blocks'] = [title_lampen, simon_levelt, wandbord, cd_rek, title_dimmers, theaterspot, eettafel, plafondspot_tv, plafondspot_haard, title_luikensets, luiken_tuin_open, luiken_tuin_dicht, luiken_water_open, luiken_water_dicht, luiken_hobby_open, luiken_hobby_dicht, lampen_2200, alle_lampen_uit, title_luiken, luik_secretaire, luik_eettafel, luik_tuinraam, luik_tuindeur, luik_kop_tuin, luik_haard, luik_dressoir, luik_keuken, luik_hobby_waterzijde, luik_hobby_kop]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [title_gas_en_elektra, grafiek_elektra, elektra_nu, elektra_vandaag, elektra_totaal, grafiek_gas, gas]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [title_raspberry, rpi_cpu_load, rpi_temp, rpi_mem_usage, uptime, title_klimaatsensors, regen, tuinvilla_buiten, tuinvilla, schuur, kelder_achter, title_deurbel, deurbel, title_settings, 'settings']
columns[3]['width'] = 3;
// Screen 2 voor desktop
columns[4] = {}
columns[4]['blocks'] = [title_alle_schakelaars, simon_levelt, wandbord, cd_rek, secretaire, buffetkast, dressoir, mondriaan_tv, mondriaan_dressoir, traplicht, title_dimmers, theaterspot, eettafel, plafondspot_tv, plafondspot_haard, title_hobby_verlichting, hobby_xxx, hobby_yyy, hobby_algemeen, title_ventilatoren, ventilator_lamp, ventilator1_stand_0, ventilator1_stand_1, ventilator1_stand_2, ventilator1_stand_3]
columns[4]['width'] = 12;
// Screen 3 voor desktop
columns[14] = {}
columns[14]['blocks'] = [title_rookmelders, rookmelder_gang, title_vochtsensors, vochtsensor_ontvochtiger, vochtsensor_cv_ketel, vochtsensor_waterontharder, vochtsensor_wasmachine]
columns[14]['width'] = 12
// Screen 4 voor desktop
columns[17] = {}
columns[17]['blocks'] = [title_weer, 'currentweather_big_owm','weather_owm']
columns[17]['width'] = 12;
// Screen 1 voor tablet
columns[5] = {}
columns[5]['blocks'] = [title_lampen, simon_levelt, wandbord, cd_rek, title_dimmers, theaterspot, eettafel, plafondspot_tv, plafondspot_haard, title_luikensets, luiken_tuin_open, luiken_tuin_dicht, luiken_water_open, luiken_water_dicht, luiken_hobby_open, luiken_hobby_dicht, lampen_2200, alle_lampen_uit]
columns[5]['width'] = 6;
columns[6] = {}
columns[6]['blocks'] = [title_klimaatsensors, regen, tuinvilla_buiten, tuinvilla, schuur, kelder_achter, title_raspberry, rpi_cpu_load, rpi_temp, rpi_mem_usage, uptime]
columns[6]['width'] = 6;
// Screen 2 voor tablet bestaat uit losse luiken en alle schakelaars
columns[15] = {}
columns[15]['blocks'] = [title_luiken, luik_secretaire, luik_eettafel, luik_tuinraam, luik_tuindeur, luik_kop_tuin, luik_haard, luik_dressoir, luik_keuken, luik_hobby_waterzijde, luik_hobby_kop, title_ventilatoren, ventilator_lamp, ventilator1_stand_0, ventilator1_stand_1, ventilator1_stand_2, ventilator1_stand_3]
columns[15]['width'] = 6;
columns[16] = {}
columns[16]['blocks'] = [title_alle_schakelaars, simon_levelt, wandbord, cd_rek, secretaire, buffetkast, dressoir, mondriaan_tv, mondriaan_dressoir, traplicht, title_dimmers, theaterspot, eettafel, plafondspot_tv, plafondspot_haard]
columns[16]['width'] = 6;
// Screen 3 voor tablet bestaat uit columns[4]
// Screen 4 voor tablet
columns[7] = {}
columns[7]['blocks'] = [title_gas_en_elektra, grafiek_elektra, elektra_nu, elektra_vandaag, elektra_totaal, grafiek_gas, gas]
columns[7]['width'] = 12;
// Screen 5 voor tablet (sensoren en ventilatoren)
columns[11] = {}
columns[11]['blocks'] = [title_rookmelders, rookmelder_gang, title_vochtsensors, vochtsensor_ontvochtiger, vochtsensor_cv_ketel, vochtsensor_waterontharder, vochtsensor_wasmachine]
columns[11]['width']= 6;
columns[12] = {}
columns[12]['blocks'] = [title_hobby_verlichting, hobby_xxx, hobby_yyy, hobby_algemeen]
columns[12]['width'] = 6;
// Screen 1 voor phone
columns[8] = {}
columns[8]['blocks'] = [title_lampen, simon_levelt, wandbord, cd_rek, title_dimmers, theaterspot, eettafel, plafondspot_tv, plafondspot_haard, title_luikensets, luiken_tuin_open, luiken_tuin_dicht, luiken_water_open, luiken_water_dicht, luiken_hobby_open, luiken_hobby_dicht, lampen_2200, alle_lampen_uit]
columns[8]['width'] = 12;
// Screen 2 voor phone bestaat uit columns[4]
// Screen 3 voor phone bestaat uit de losse luiken
columns[13] = {}
columns[13]['blocks'] = [title_luiken, luik_secretaire, luik_eettafel, luik_tuinraam, luik_tuindeur, luik_kop_tuin, luik_haard, luik_dressoir, luik_keuken, luik_hobby_waterzijde, luik_hobby_kop]
columns[13]['width'] = 12;
// Screen 4 voor phone (sensoren) bestaat uit column[14]
// Screen 5 voor phone
columns[9] = {}
columns[9]['blocks'] = [title_elektra, grafiek_elektra, elektra_nu, elektra_vandaag, elektra_totaal]
columns[9]['width'] = 12;
// Screen 6 voor phone
columns[10] = {}
columns[10]['blocks'] = [title_gas, grafiek_gas, gas]
columns[10]['width'] = 12;
// Screens
var screens = {}
// Desktop
screens[max_resolution_desktop] = {}
screens[max_resolution_desktop]['maxwidth'] = 1920;
screens[max_resolution_desktop]['maxheight'] = 1200;
screens[max_resolution_desktop][1] = {}
screens[max_resolution_desktop][1]['background'] = 'img/bg15.jpg';
screens[max_resolution_desktop][1]['columns'] = [1,2,3]
screens[max_resolution_desktop][2] = {}
screens[max_resolution_desktop][2]['background'] = 'img/bg15.jpg';
screens[max_resolution_desktop][2]['columns'] = [4]
screens[max_resolution_desktop][3] = {}
screens[max_resolution_desktop][3]['background'] = 'img/bg15.jpg';
screens[max_resolution_desktop][3]['columns'] = [14]
screens[max_resolution_desktop][4] = {}
screens[max_resolution_desktop][4]['background'] = 'img/bg15.jpg';
screens[max_resolution_desktop][4]['columns'] = [17]
// Tablet
screens[max_resolution_tablet] = {}
screens[max_resolution_tablet]['maxwidth'] = 1280;
screens[max_resolution_tablet]['maxheight'] = 800;
screens[max_resolution_tablet][1] = {}
screens[max_resolution_tablet][1]['background'] = 'img/bg15.jpg';
screens[max_resolution_tablet][1]['columns'] = [5,6]
screens[max_resolution_tablet][2] = {}
screens[max_resolution_tablet][2]['background'] = 'img/bg15.jpg';
screens[max_resolution_tablet][2]['columns'] = [15,16]
screens[max_resolution_tablet][3] = {}
screens[max_resolution_tablet][3]['background'] = 'img/bg15.jpg';
screens[max_resolution_tablet][3]['columns'] = [4]
screens[max_resolution_tablet][4] = {}
screens[max_resolution_tablet][4]['background'] = 'img/bg15.jpg';
screens[max_resolution_tablet][4]['columns'] = [7]
screens[max_resolution_tablet][5] = {}
screens[max_resolution_tablet][5]['background'] = 'img/bg15.jpg';
screens[max_resolution_tablet][5]['columns'] = [11,12]
// Phone
screens[max_resolution_phone] = {}
screens[max_resolution_phone]['maxwidth'] = 720;
screens[max_resolution_phone]['maxheight'] = 1520;
screens[max_resolution_phone][1] = {}
screens[max_resolution_phone][1]['background'] = 'img/bg15.jpg';
screens[max_resolution_phone][1]['columns'] = [8]
screens[max_resolution_phone][2] = {}
screens[max_resolution_phone][2]['background'] = 'img/bg15.jpg';
screens[max_resolution_phone][2]['columns'] = [4]
screens[max_resolution_phone][3] = {}
screens[max_resolution_phone][3]['background'] = 'img/bg15.jpg';
screens[max_resolution_phone][3]['columns'] = [13]
screens[max_resolution_phone][4] = {}
screens[max_resolution_phone][4]['background'] = 'img/bg15.jpg';
screens[max_resolution_phone][4]['columns'] = [14]
screens[max_resolution_phone][5] = {}
screens[max_resolution_phone][5]['background'] = 'img/bg15.jpg';
screens[max_resolution_phone][5]['columns'] = [9]
screens[max_resolution_phone][6] = {}
screens[max_resolution_phone][6]['background'] = 'img/bg15.jpg';
screens[max_resolution_phone][6]['columns'] = [10]
And my moderately adjusted custom.css:
CUSTOM CSS FILE
.titlegroups {text-align: center !important;}
.transbg[class*="col-xs"] {
  border-radius: 20px;                            /* Rounded corners */
.swiper-pagination-bullet {
    width: 35px !important;
    height: 35px !important;
.swiper-pagination {
    text-align: right !important;
As said before: any tips on my issues are greatly appreciated :)
Greetz,
Sjonnie
garethiowc
Post by garethiowc »
Hi Tycho,
I'm assuming under the status section the device status dependant on a ping check?
https://www.domoticz.com/wiki/System_Al ... ker_(Ping)
I have followed the guide linked above and the checks work ok but are displayed using a lamp icon in dashticz. How did you get green and red icons?
tycho28 wrote: Monday 30 July 2018 13:50 This is my dashboard.
I've a small tablet (got it free) which I 'mounted' on a pallet on the wall. The dashboard on the tablet is a older version, the picture above is the correct one :)
Config.js
var config = {}
config['domoticz_ip'] = 'http://192.168.0.2:8081';
config['app_title'] = 'Breda';
config['domoticz_refresh'] = '60';
config['auto_positioning'] = 0;
config['calendarformat'] = 'dd D MMM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['wu_api'] = 'xxx';
config['wu_city'] = 'Breda';
config['wu_name'] = '';
config['hide_topbar'] = 1;
var publictransport = {}
publictransport.ovinfotrain= { station: 'station-breda', show_lastupdate:true, provider: '9292-train', icon: 'train', results: 5 };
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://calendar.google.com/calendar/xxx/basic.ics' }
/* BLOCKS CONFIGURATION */
var blocks = {}
blocks['bt_1'] = {}
blocks['bt_1']['type'] = 'blocktitle';
blocks['bt_1']['title'] = 'Verlichting';
blocks['bt_2'] = {}
blocks['bt_2']['type'] = 'blocktitle';
blocks['bt_2']['title'] = 'Temperatuur';
blocks['bt_3'] = {}
blocks['bt_3']['type'] = 'blocktitle';
blocks['bt_3']['title'] = 'Stroom';
blocks['bt_4'] = {}
blocks['bt_4']['type'] = 'blocktitle';
blocks['bt_4']['title'] = 'Status';
//Voordeur
blocks[8380] = {};
blocks[8380]['title'] = 'Voordeur';
blocks[8380]['show_lastupdate'] = false;
blocks[8380]['width'] = 6
//Balkondeur
blocks[8385] = {};
blocks[8385]['title'] = 'Balkondeur';
blocks[8385]['show_lastupdate'] = false;
blocks[8385]['width'] = 6
//Keukenraam
blocks[8382] = {};
blocks[8382]['title'] = 'Keukenraam';
blocks[8382]['show_lastupdate'] = false;
blocks[8382]['width'] = 6
//Slaapkamerraam 1
blocks[8391] = {};
blocks[8391]['title'] = 'Slaapkamer gallerij';
blocks[8391]['show_lastupdate'] = false;
blocks[8391]['width'] = 6
//Slaapkamerraam 2
blocks[8389] = {};
blocks[8389]['title'] = 'Slaapkamer balkon';
blocks[8389]['show_lastupdate'] = false;
blocks[8389]['width'] = 6
//Woonkamerraam
blocks[8387] = {};
blocks[8387]['title'] = 'Woonkamer';
blocks[8387]['show_lastupdate'] = false;
blocks[8387]['width'] = 6
//* TEMPERATUUR *//
blocks['1389_1'] = {};
blocks['1389_1']['title'] = 'Woonkamer';
blocks['1389_1']['switch'] = true;
blocks['1833_1'] = {};
blocks['1833_1']['title'] = 'Slaapkamer';
blocks['1833_1']['switch'] = true;
blocks['1834_1'] = {};
blocks['1834_1']['title'] = 'Badkamer';
blocks['1834_1']['switch'] = true;
blocks[7208] = {};
blocks[7208]['title'] = 'Hal';
blocks[7208]['switch'] = true;
blocks[8368] = {};
blocks[8368]['title'] = 'Keuken';
blocks[8368]['switch'] = true;
blocks['6649_1'] = {};
blocks['6649_1']['title'] = 'Buiten';
blocks['6649_1']['switch'] = true;
//* STROOM *//
//Vaatwasser
blocks['8394_1'] = {};
blocks['8394_1']['title'] = 'Vaatwasser';
blocks['8394_1']['icon'] = 'fa-bolt';
//Wasmachine
blocks['8398_1'] = {};
blocks['8398_1']['title'] = 'Wasmachine';
blocks['8398_1']['icon'] = 'fa-bolt';
//Koelkast
blocks['8396_1'] = {};
blocks['8396_1']['title'] = 'Koelkast';
blocks['8396_1']['icon'] = 'fa-bolt';
//Gas
blocks['8405_1'] = {};
blocks['8405_1']['title'] = 'Gas';
//* VERLICHTING *//
//Sfeerverlichting Kast
blocks[82] = {};
blocks[82]['title'] = 'Kastverlichting';
blocks[82]['show_lastupdate'] = false;
blocks[82]['width'] = 4
//Sfeerverlichting pallet
blocks[83] = {};
blocks[83]['title'] = 'Pallet';
blocks[83]['show_lastupdate'] = false;
blocks[83]['width'] = 4
//Woonkamer bol
blocks[6576] = {};
blocks[6576]['title'] = 'Bol';
blocks[6576]['show_lastupdate'] = false;
blocks[6576]['width'] = 4
//Studiekamer
blocks[8330] = {};
blocks[8330]['title'] = 'Computer';
blocks[8330]['show_lastupdate'] = false;
blocks[8330]['width'] = 4
//Eettafel
blocks[8322] = {};
blocks[8322]['title'] = 'Eettafel';
blocks[8322]['show_lastupdate'] = false;
blocks[8322]['width'] = 4
//Woonkamer lamp
blocks[7207] = {};
blocks[7207]['title'] = 'Staande lamp';
blocks[7207]['show_lastupdate'] = false;
blocks[7207]['width'] = 12
//Woonkamer spot
blocks[8409] = {};
blocks[8409]['title'] = 'WK spots';
blocks[8409]['show_lastupdate'] = false;
blocks[8409]['width'] = 4
//Slaapkamer 1
blocks[8325] = {};
blocks[8325]['title'] = 'Slaapkamer gallerij';
blocks[8325]['show_lastupdate'] = false;
blocks[8325]['width'] = 4
//* Scenes *//
//Slaapkamer 2
blocks[8327] = {};
blocks[8327]['title'] = 'Slaapkamer balkon';
blocks[8327]['show_lastupdate'] = false;
blocks[8327]['width'] = 4
//Scene TV kijken
blocks['s2'] = {};
blocks['s2']['title'] = 'TV Kijken';
blocks['s2']['show_lastupdate'] = false;
blocks['s2']['width'] = 4
blocks['s2']['hide_data'] = true
//Scene alles uit
blocks['s3'] = {};
blocks['s3']['title'] = 'Alles uit';
blocks['s3']['show_lastupdate'] = false;
blocks['s3']['width'] = 4
blocks['s3']['hide_data'] = true
//* STROOM *//
//Energieverbruik_1
blocks['8403_1'] = {};
blocks['8403_1']['title'] = 'Huidig verbruik';
//Energieverbruik_2
blocks['8403_2'] = {};
blocks['8403_2']['title'] = 'Totaal vandaag';
//* STATUS DEVICES *//
//PC
blocks[1828] = {};
blocks[1828]['title'] = 'PC';
blocks[1828]['show_lastupdate'] = false;
blocks[1828]['width'] = 4
blocks[1828]['hide_data'] = true
blocks[1828]['icon'] = 'fa-circle'
//TV Woonkamer
blocks[8416] = {};
blocks[8416]['title'] = 'TV WK';
blocks[8416]['show_lastupdate'] = false;
blocks[8416]['width'] = 4
blocks[8416]['hide_data'] = true
blocks[8416]['icon'] = 'fa-circle'
blocks[8416]['protected'] = true
//TV Slaapkamer
blocks[1824] = {};
blocks[1824]['title'] = 'TV SK';
blocks[1824]['show_lastupdate'] = false;
blocks[1824]['width'] = 4
blocks[1824]['hide_data'] = true
blocks[1824]['icon'] = 'fa-circle'
blocks[1824]['protected'] = true
//ATV Woonkamer
blocks[8841] = {};
blocks[8841]['title'] = 'ATV WK';
blocks[8841]['show_lastupdate'] = false;
blocks[8841]['width'] = 4
blocks[8841]['hide_data'] = true
blocks[8841]['icon'] = 'fa-circle'
blocks[8841]['protected'] = true
//ATV Slaapkamer
blocks[1827] = {};
blocks[1827]['title'] = 'ATV SK';
blocks[1827]['show_lastupdate'] = false;
blocks[1827]['width'] = 4
blocks[1827]['hide_data'] = true
blocks[1827]['icon'] = 'fa-circle'
blocks[1827]['protected'] = true
//Philips Soundsystem
blocks[6517] = {};
blocks[6517]['title'] = 'Philips HTB';
blocks[6517]['show_lastupdate'] = false;
blocks[6517]['width'] = 4
blocks[6517]['hide_data'] = true
blocks[6517]['icon'] = 'fa-circle'
blocks[6517]['protected'] = true
//Printer
blocks[8839] = {};
blocks[8839]['title'] = 'Printer';
blocks[8839]['show_lastupdate'] = false;
blocks[8839]['width'] = 4
blocks[8839]['hide_data'] = true
blocks[8839]['icon'] = 'fa-circle'
blocks[8839]['protected'] = true
//Vaatwasser
blocks[8421] = {};
blocks[8421]['title'] = 'Vaatwasser';
blocks[8421]['show_lastupdate'] = false;
blocks[8421]['width'] = 4
blocks[8421]['hide_data'] = true
blocks[8421]['icon'] = 'fa-circle'
blocks[8421]['protected'] = true
//Wasmachine
blocks[8420] = {};
blocks[8420]['title'] = 'Wasmachine';
blocks[8420]['show_lastupdate'] = false;
blocks[8420]['width'] = 4
blocks[8420]['hide_data'] = true
blocks[8420]['icon'] = 'fa-circle'
blocks[8420]['protected'] = true
//Koelkast
blocks[8393] = {};
blocks[8393]['title'] = 'Koelkast';
blocks[8393]['show_lastupdate'] = false;
blocks[8393]['width'] = 4
blocks[8393]['hide_data'] = true
blocks[8393]['icon'] = 'fa-circle'
blocks[8393]['protected'] = true
//Xiaomi Gateway
blocks[8869] = {};
blocks[8869]['title'] = 'Xiaomi';
blocks[8869]['show_lastupdate'] = false;
blocks[8869]['width'] = 4
blocks[8869]['hide_data'] = true
blocks[8869]['icon'] = 'fa-circle'
blocks[8869]['protected'] = true
//Android Tablet
blocks[8868] = {};
blocks[8868]['title'] = 'Tablet lader';
blocks[8868]['show_lastupdate'] = false;
blocks[8868]['width'] = 4
blocks[8868]['hide_data'] = true
blocks[8868]['icon'] = 'fa-circle'
blocks[8868]['protected'] = true
//Android Batterij
blocks[8867] = {};
blocks[8867]['title'] = 'Android Tablet';
blocks[8867]['show_lastupdate'] = false;
blocks[8867]['width'] = 6
blocks[8867]['protected'] = true
blocks[8867]['icon'] = 'fa-percent'
/* IEMAND THUIS */
//Tycho
blocks[1825] = {};
blocks[1825]['title'] = 'Tycho';
blocks[1825]['icon'] = 'fa-male';
blocks[1825]['width'] = 6;
blocks[1825]['hide_data'] = true
/* COLUMN CONFIGURATION */
var columns = {}
columns['bar'] = {};
columns['bar']['blocks'] = ['sunrise','miniclock','settings'];
columns[1] = {};
columns[1]['blocks'] = ['clock','sunrise',publictransport.ovinfotrain,8380,8385,8382,8391,8389,8387,1825,8867];
columns[1]['width'] = 3;
columns[2] = {};
columns[2]['blocks'] = ['bt_1',8409,8322,8330,83,82,6576,'s3','s2',calendars.private,'bt_4',1828,8839,8869,8416,6517,8841,1824,1827,8868,8393,8421,8420];
columns[3] = {};
columns[3]['blocks'] = ['bt_2','weather','1389_1','1833_1','1834_1',7208,8368,'6649_1','bt_3','8403_1','8403_2','8396_1','8398_1','8394_1','8405_1'];
columns[3]['width'] = 4;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather', 'currentweather_big']
Custom.css
CUSTOM CSS FILE
/* Titles */
div.mh.titlegroups h1, h2, h3, h4, h5, h6 {
font-family: -apple-system, BlinkMacSystemFont,
"Segoe UI", "Roboto", "Oxygen", "Ubuntu", "Cantarell",
"Fira Sans", "Droid Sans", "Helvetica Neue",
sans-serif;
font-weight: medium;
font-style: normal;
font-size: 17pt;
letter-spacing: 0.5pt;
margin: 0px;
margin-left: 15px;
padding-top:0px;
height: auto !important;	/* default height=75px */
/* Blocks*/
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-4,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
	padding-top:10px;
	padding-bottom:10px;
	border: 2px solid rgba(255,255,255,0);		/* border: 7px -> 3px - Smaller space between blocks */
	background: rgba(0,0,0,0.2);
	background-clip: padding-box;
	border-radius: 8px;
.fa,.wi {
   font-size:24px !important;
.fa.fa-train {
    font-size:18px !important;
.fa.fa-unlock.on.icon,
.fa.fa-lightbulb-o.on {
    color:#F1C300;
.fa.fa-lock.off.icon,
.fa.fa-lightbulb-o.off {
	color:#fff;
/*Toggle*/
.fa.fa-toggle-on.icon{
	color:#4bd961;
	opacity: 1 !important;
.fa.fa-toggle-off.icon{
	color:#fff;
	opacity: 0.5 !important;
/*Circle*/
.fa.fa-circle.on {
	color:#4bd961;
	font-size:15px !important;
.fa.fa-circle.off {
	color:#ff0000;
.lastupdate {
	display: none;
.fa.fa-male.on {
	color:#F1C300
/*Status*/
.block_1828.transbg.col-xs-4,
.block_8839.transbg.col-xs-4,
.block_8416.transbg.col-xs-4,
.block_6517.transbg.col-xs-4,
.block_8841.transbg.col-xs-4,
.block_1824.transbg.col-xs-4,
.block_1827.transbg.col-xs-4,
.block_8393.transbg.col-xs-4,
.block_8421.transbg.col-xs-4,
.block_8420.transbg.col-xs-4,
.block_8868.transbg.col-xs-4,
.block_8869.transbg.col-xs-4 {
	height: 34px;
	padding-top:7px;
	padding-bottom:1px;
/*Temperatuur*/
.block_1389_1.transbg.col-xs-4,
.block_1833_1.transbg.col-xs-4,
.block_1834_1.transbg.col-xs-4,
.block_7208.transbg.col-xs-4,
.block_8368.transbg.col-xs-4,
.block_6649_1.transbg.col-xs-4 {
	height: 50px;
	padding-top:7px;
	padding-bottom:1px;
/*Verlichting*/
.block_8409.transbg.col-xs-4,
.block_8322.transbg.col-xs-4,
.block_8330.transbg.col-xs-4,
.block_83.transbg.col-xs-4,
.block_82.transbg.col-xs-4,
.block_6576.transbg.col-xs-4,
.block_s2.transbg.col-xs-4,
.block_s3.transbg.col-xs-4 {
	height: 50px;
	padding-top:7px;
	padding-bottom:1px;
/*Stroom*/
.block_8403_1.transbg.col-xs-4,
.block_8403_2.transbg.col-xs-4,
.block_8396_1.transbg.col-xs-4,
.block_8398_1.transbg.col-xs-4,
.block_8394_1.transbg.col-xs-4,
.block_8405_1.transbg.col-xs-4 {
	height: 60px;
	padding-top:7px;
	padding-bottom:1px;
/*Sensoren deur/raam + scene*/
.block_8380.transbg.col-xs-6,
.block_8385.transbg.col-xs-6,
.block_8382.transbg.col-xs-6,
.block_8391.transbg.col-xs-6,
.block_8389.transbg.col-xs-6,
.block_8387.transbg.col-xs-6,
.block_s3.transbg.col-xs-6 {
	height: 70px;
	padding-top:7px;
	padding-bottom:1px;
/*Tycho + Android Tablet*/
.block_8867.transbg.col-xs-6,
.block_1825.transbg.col-xs-6 {
	height: 50px;
	padding-top:7px;
	padding-bottom:1px;
div.mh.titlegroups {
	height: 40px !important;		/* default height=75px */
	padding-top: 2px;			/* center text for new height */
div.mh h3 {
	padding-top: 1px;
/*Warning*/
.warning {
   background: rgba(199,44,44,0.3) !important;
.warningblue {
   background: rgba(45,119,204,0.3) !important;
.verbruik {
    color: #F1C300;
Custom.js
 //add custom javascript in here
function afterGetDevices(){
function getExtendedBlockTypes(blocktypes){
	//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
	return blocktypes;
//Temperatuur woonkamer
function getStatus_1389_1(idx,value,device){
   if(parseFloat(device['Data'])>30){
      $('div.block_1389_1').addClass('warning');
   else if (parseFloat(device['Data'])<5){
      $('div.block_1389_1').addClass('warningblue');
   else {
      $('div.block_1389_1').removeClass('warning');
      $('div.block_1389_1').removeClass('warningblue');
//Temperatuur Slaapkamer
function getStatus_1833_1(idx,value,device){
      $('div.block_1833_1').addClass('warning');
      $('div.block_1833_1').addClass('warningblue');
   else {
      $('div.block_1833_1').removeClass('warning');
      $('div.block_1833_1').removeClass('warningblue');
//Temperatuur Badkamer
function getStatus_1834_1(idx,value,device){
      $('div.block_1834_1').addClass('warning');
      $('div.block_1834_1').addClass('warningblue');
   else {
      $('div.block_1834_1').removeClass('warning');
      $('div.block_1834_1').removeClass('warningblue');
//Temperatuur Hal
function getStatus_7208(idx,value,device){
      $('div.block_7208').addClass('warning');
      $('div.block_7208').addClass('warningblue');
   else {
      $('div.block_7208').removeClass('warning');
      $('div.block_7208').removeClass('warningblue');
//Temperatuur Keuken
function getStatus_8368_1(idx,value,device){
      $('div.block_8368').addClass('warning');
      $('div.block_8368').addClass('warningblue');
   else {
      $('div.block_8368').removeClass('warning');
      $('div.block_8368').removeClass('warningblue');
//Temperatuur Buiten
function getStatus_6649_1(idx,value,device){
      $('div.block_6649_1').addClass('warning');
      $('div.block_6649_1').addClass('warningblue');
   else {
      $('div.block_6649_1').removeClass('warning');
      $('div.block_6649_1').removeClass('warningblue');
// SENSOREN
//Voordeur
function getStatus_8380(idx,value,device){
   if(device['Status']=='Open') {
	blocks[8380]['icon'] = 'fa fa-unlock'}
   else {
	blocks[8380]['icon'] = 'fa fa-lock'}
//Balkondeur
function getStatus_8385(idx,value,device){
	blocks[8385]['icon'] = 'fa fa-unlock'}
   else {
	blocks[8385]['icon'] = 'fa fa-lock'}
//Keukenraam
function getStatus_8382(idx,value,device){
	blocks[8382]['icon'] = 'fa fa-unlock'}
   else {
	blocks[8382]['icon'] = 'fa fa-lock'}
//Slaapkamer gallerij
function getStatus_8391(idx,value,device){
	blocks[8391]['icon'] = 'fa fa-unlock'}
   else {
	blocks[8391]['icon'] = 'fa fa-lock'}
//Slaapkamer balkon
function getStatus_8389(idx,value,device){
	blocks[8389]['icon'] = 'fa fa-unlock'}
   else {
	blocks[8389]['icon'] = 'fa fa-lock'}
//Woonkamer raam
function getStatus_8387(idx,value,device){
	blocks[8387]['icon'] = 'fa fa-unlock'}
   else {
	blocks[8387]['icon'] = 'fa fa-lock'}
//VERLICHTING
//Woonkamer spot
function getStatus_8409(idx,value,device){
   if(device['Status']=='On') {
	blocks[8409]['icon'] = 'fa fa-toggle-on'}
   else {
	blocks[8409]['icon'] = 'fa fa-toggle-off'}
//Eettafel
function getStatus_8322(idx,value,device){
	blocks[8322]['icon'] = 'fa fa-toggle-on'}
   else {
	blocks[8322]['icon'] = 'fa fa-toggle-off'}
//Studeerkamer
function getStatus_8330(idx,value,device){
	blocks[8330]['icon'] = 'fa fa-toggle-on'}
   else {
	blocks[8330]['icon'] = 'fa fa-toggle-off'}
//Pallet
function getStatus_83(idx,value,device){
	blocks[83]['icon'] = 'fa fa-toggle-on'}
   else {
	blocks[83]['icon'] = 'fa fa-toggle-off'}
//Kastverlichting
function getStatus_82(idx,value,device){
	blocks[82]['icon'] = 'fa fa-toggle-on'}
   else {
	blocks[82]['icon'] = 'fa fa-toggle-off'}
//Bol
function getStatus_6576(idx,value,device){
	blocks[6576]['icon'] = 'fa fa-toggle-on'}
   else {
	blocks[6576]['icon'] = 'fa fa-toggle-off'}
//Alles uit
function getStatus_s3(idx,value,device){
	blocks['s3']['icon'] = 'fa fa-toggle-on'}
   else {
	blocks['s3']['icon'] = 'fa fa-toggle-off'}
//TV kijken
function getStatus_s2(idx,value,device){
	blocks['s2']['icon'] = 'fa fa-toggle-on'}
   else {
	blocks['s2']['icon'] = 'fa fa-toggle-off'}
//VERBRUIK
//Koelkast
function getStatus_8396_1(idx,value,device){
   if(parseFloat(device['Usage'])>0){
      $('div.block_8396_1.col-xs-4').addClass('verbruik');
   else {
//Wasmachine
function getStatus_8398_1(idx,value,device){
      $('div.block_8398_1.col-xs-4').addClass('verbruik');
   else {
//Vaatwasser
function getStatus_8394_1(idx,value,device){
      $('div.block_8394_1.col-xs-4').addClass('verbruik');
   else {
HansieNL
Post by HansieNL »
With the block parameter icon: Defines alternative icon of the device instead of the default, choose from: https://fontawesome.com/icons?d=gallery&m=free
You can change icon colors of a Domoticz switch via CSS.
You can find full description in the manual: https://dashticz.readthedocs.io/
Blah blah blah
garethiowc
HansieNL wrote: Sunday 26 January 2020 17:59 With the block parameter icon: Defines alternative icon of the device instead of the default, choose from: https://fontawesome.com/icons?d=gallery&m=free
Cool Thanks.
blocks[35] = {};
blocks[35]['title'] = 'Router';
blocks[35]['show_lastupdate'] = false;
blocks[35]['width'] = 4
blocks[35]['hide_data'] = true
blocks[35]['icon'] = 'fa-circle'
I've managed to adjust the block I wanted but when using 'fa-circle' I'm left with a very small square icon. I'm assuming this means there's an error in my code
Lokonli
Post by Lokonli »
garethiowc wrote: Sunday 26 January 2020 21:30
Cool Thanks.
blocks[35] = {};
You have to put 'far' (for a regular icon) or 'fas' (for a solid icon) in front of fa-circle. For instance:
'far fa-circle'
garethiowc
Lokonli wrote: Sunday 26 January 2020 21:57
Cool Thanks.
blocks[35] = {};
'far fa-circle'
Awesome thanks :)
Next i will attempt changing the colour
Lokonli
Post by Lokonli »
garethiowc wrote: Monday 27 January 2020 12:53
Cool Thanks.
blocks[35] = {};
'far fa-circle'
Awesome thanks :)
Check:
https://dashticz.readthedocs.io/en/mast ... omcss.html
and:
https://dashticz.readthedocs.io/en/mast ... ynamically
garethiowc
Things have been going well -
I've managed to get the last seen update hidden on everything other than a few temperature sensors.
So as you can see in the image, last seen is hidden on the block 2 but none of the other temp sensors
/*Temperature Blocks*/
blocks[2] = {};
blocks[2]['last_update'] = false;
blocks[2]['width'] = 4
blocks[2]['hide_data'] = true
blocks[10] = {};
blocks[10]['last_update'] = false;
blocks[10]['width'] = 4
blocks[10]['hide_data'] = true
blocks[13] = {};
blocks[13]['last_update'] = false;
blocks[13]['width'] = 4
blocks[13]['hide_data'] = true
blocks[27] = {};
blocks[27]['last_update'] = false;
blocks[27]['width'] = 4
blocks[27]['hide_data'] = true
blocks[15] = {};
blocks[15]['last_update'] = false;
blocks[15]['width'] = 4
blocks[15]['hide_data'] = true
any ideas?
