Page 35 of 52
Re: Controlicz - Easy Domoticz to Alexa Integration
Posted: Monday 30 April 2018 12:18
by markjgabb
hey madgeni....
still an awesome project, just got it up and running again due to just getting a new phone...
did we ever get any traction with the selector switches?
Posted: Monday 30 April 2018 15:07
by lshield
Madgeni wrote: Monday 30 April 2018 12:11
Hi - can you try again? I was making some backend changes, which may have affected service for period of time
Looks like it all works again. Thanks!
Posted: Tuesday 01 May 2018 1:26
by vivatauro
Madgeni:
I have trouble in understanding how to set this up. Is there any tutorial to explain from scratch how to set my rapsberry running Domoticz?
I also followed some steps but I got lost in the process regarding the SSL certificate. One of the requisites is to have a domain, how can I create it?
Sorry for asking rookie questions, but I love experimenting and do things myselfs I did a lot already but I want to have as a goal the intrgration of my domoticz with Alexa as a goal. But I have some challenges on how to get to the part to make my domoticz server visible on the net as well as getting the details to enter in controlicz.
Thanks in advance for your support.
Posted: Tuesday 01 May 2018 7:44
by Madgeni
Hi, and welcome.
Https is on by default, so you just need to forward your https port to your router. Maybe change the port number to something else .
You don't *need* a domain, but makes life easier, especially if your external IP can change. Try noip.com it's free ( and v easy).
Once you have that, the instructions on controlicz.com should be enough, but any issues, drop them in here.
Posted: Sunday 06 May 2018 11:06
by IanDury
Hi Madgeni,
Works great, thanks!
However, I use my own domain with a reverse proxy routing internet traffic either to my Apache or domoticz web server. For Domoticz I use the "-webroot domoticz" option and the reverse proxy configuration is configured so that
https://mydomain/domoticz/ passes all traffic to Domoticz and vice versa.
Unfortunately controlizc.com currently doesn't seem to support this (host: mydomain/domoticz/).
Would be great if controlicz would support this.
Posted: Monday 07 May 2018 9:44
by Madgeni
Hi Ian - can you email me (via the Controlicz profile page) - there's a few people here using proxies, they've worked around it, but i should look to see what can be achieved.
Posted: Wednesday 16 May 2018 16:49
by jhbackus
Hi, I've successfully connected a fireplace with Domoticz, using the RFX-TRX433E, which acts as a remote (G6R-H4T16) for the fireplace.
I have made a switch in Domoticz (generic on/off) , which can send the on/off commands as well as fire up and fire down commands (for increasing or decreasing the flames).
And now I have installed Controlicz, through which I can let Alexa turn the fireplace on and off. So that's great! Thanks a lot to madgenies help!
But now there is this issue: I don't know how to let Alexa turn up or down the fire.
Commands that I tried:
turn up/down, set temp to.. degrees, set fireplace to 50%, lower fire place.... nothing seems to work. Has anyone any idea how to get the up and down functions working through Alexa?
Posted: Thursday 17 May 2018 9:41
by solidum90
Hi, password recovery does not work yet?
Always redirect to
https://www.controlicz.com/200 ?
Posted: Thursday 17 May 2018 11:06
by Madgeni
Hi - just reset my password using that method - seems to be working fine? What step does it fail for you?
Posted: Saturday 02 June 2018 18:11
by Madgeni
Hi - if anyone experiences any issues, you may have to re-authenticate with Alexa/Google - I've been doing some Controlicz housework
Posted: Sunday 03 June 2018 8:32
by remb0
aha that was the reason my wife was screaming to alexa last night
not it working again. thanks!
Posted: Sunday 03 June 2018 10:43
by bozidar
Hi Nick
Could you please specify what is needed todo. I am a littlebit afraid i do it wrong and have to setup alot from scrath.
It doesnt work here :
I have tested connection and it works.
I have discovered devices ,and no new devices found (of course)
Everything is working directly from domoticz.
Posted: Sunday 03 June 2018 10:45
by Madgeni
Disable/re-enable Controlicz in your Alexa app
Posted: Sunday 03 June 2018 11:39
by freijn
Re-registering worked for me as well.
Had visitors yesterday evening ( in the afternoon it all worked ).
They where politely smiling at me "Poor old man.. shouting at a device" Nothing worked.... pfffff
Glad its restored again.. Thanks Madgeni for all the hard work you doing here for us !!
Posted: Sunday 03 June 2018 15:08
by gomario
Same here, before doing the last thing I could think of (disable/re-enable) I checked this thread and there it was:
"Hi - if anyone experiences any issues, you may have to re-authenticate with Alexa/Google - I've been doing some Controlicz housework"
Thanks Madgeni for letting us know and for your hard work. When things suddenly stop working we all realise how much we owe you!
...now I'm subscribed with e-mail notifications
Posted: Sunday 03 June 2018 17:27
by Madgeni
freijn wrote: Sunday 03 June 2018 11:39
i am *so* sorry
I hate it when that happens
Posted: Monday 04 June 2018 8:44
by giorgik
Hi!
I ran into a small problem - Controlicz doesn't list any devices under the "devices" tab. The message says "No data available in table".
The connection from Controlicz to Domoticz works according to the website. I verified this by sifting through logs as well, relevant lines appear when I click the "Test button" on the website:
2018-06-04 06:38:50.461 Status: Incoming connection from: 35.176.67.167
2018-06-04 06:38:57.865 Status: Incoming connection from: 35.176.67.167
The device I'm trying to set up is a Tasmota running on ESP8266, using the old Dummy hardware trick.
Any insights?
Posted: Monday 04 June 2018 9:01
by Madgeni
Add the device to a Room Plan in Domoticz
Posted: Monday 04 June 2018 17:10
by modular
My controlicz suddenly can't connect anymore. As far as i can see there was no update or anything. I used the the following setup:
my ip public:667 (which redirect to domoticz internal ip:443)
Now i noticed i can connect internally on the 443 port, but the external redirect does not seem to work anymore. Again there has been no config change or update. This setup did work for 4 days ago.
someone has a clue on where to look
Posted: Monday 04 June 2018 17:11
by Madgeni
can you disable the skill in your Alexa app, and reenable it?
or have i misunderstood, and this is more of a port forwarding issue?
