Page 34 of 94
Posted: Tuesday 23 February 2016 11:46
by gielie
jumbotroll wrote:@jumbo70
Now I have spent many hours trying to figure this out.
Aotec Gen 5 stick uses cdc-acm driver.
It looks like your NAS have an older kernel with an older cdc-acm driver and that's the problem.
I'll try to find a solution, but no promises.
This is the reason i switched form eaontec to a Vision Z stick, this works perfect, the eaon stick didnt on my DS415play
Posted: Tuesday 23 February 2016 12:23
by cherowley
Hi!
I think I must have had the beta builds ticked at some point as now it's not updating versions.
Is there a way to get it doing package updates again without uninstalling and re-installing?
Posted: Tuesday 23 February 2016 13:07
by jumbotroll
cherowley wrote:Hi!
Add
http://www.jadahl.com/domoticz_beta/ to your Synology NAS Package Center sources.
Posted: Tuesday 23 February 2016 23:41
by cherowley
jumbotroll wrote:cherowley wrote:Hi!
Add
Just to confirm, that will enable NON beta updates through again?
Posted: Thursday 25 February 2016 0:55
by Boots33
cherowley wrote:jumbotroll wrote:cherowley wrote:Hi!
Add
If you look back here
viewtopic.php?f=17&t=2620&p=70488&hilit=beta#p70488 you can see the address for the beta and stable releases posted by jumbotroll
Posted: Thursday 25 February 2016 9:30
by cherowley
Thanks. Think I will have to uninstall/reinstall to get back on the non-beta releases thanks anyways
Posted: Friday 26 February 2016 12:57
by mortyre
Please Help me!
I'm new to this forum, I've got through all the posts but haven't found any explanation about my problem with my USB serial port when I use RFXtrx433E on /dev/ttyUSB0 to pilot somfy rts with my synology (I have no bug with domoticz on windows or with RFXmngr)
my configuration :
dsm 6.0-7274
synology ds1815+
DomoticZ v2.4547 (avoton)
RfxcomE (bios 251)
usb Zwave.me on /dev/ttyACM0 --> ok with Fibaro plugs
Log from DomoticZ
2016-02-26 12:39:29.668 RFXCOM: Using serial port: /dev/ttyUSB0
2016-02-26 12:39:29.668 Error: Serial Port closed!... Error: End of file
I have been read that it should be a problem with right permission on the port ?
I'd be grateful if anyone could suggest something to try to fix this. Many Thanks
Posted: Saturday 27 February 2016 16:20
by gevegest
When i install the latest Domoticz beta from the Jumbotroll repository on my DS214+, the HTTPS server does not start and says that the 8443 port might already be used. As you can see the HTTP server starts fine.
- Screen Shot 2016-02-27 at 16.07.32.png (53.96 KiB) Viewed 3238 times
I have checked the used ports with netstat and the 8443 port is not listed anywhere.
I have tried reinstalling the package after a restart of the server, but the error persists.
Can anybody help me?
Posted: Saturday 27 February 2016 17:04
by gevegest
Did some more digging on the forum, it seems this is a problem in beta 2.4768 and seems to be fixed in 2.4790, so i will wait for this release from Jumbotroll.
Thanks in advance Jumbotroll!
Posted: Sunday 28 February 2016 17:10
by gevegest
Hi Jumbotroll,
Many thanks for your quick help, all is working fine now.
You should have a donation in your account
Keep up your great work!
Best regards,
gevegest
Posted: Monday 29 February 2016 11:05
by staradmin
Thank you for this great package. I have one question here about /var/domoticz.log
Every time I reboot my NAS, all previous logs are lost. How can I make it not deleted? I tried graphical interface log menu with no success
Thank you for your help
Posted: Monday 29 February 2016 20:43
by mortyre
hello
Very good news for me with the last version of domoticz 2.4814 :
- first the last version from my RFXcom of firmware 251 is correctly identified (before is was written 250)
- and now my problem with the permissions on USB ports is Ok -> I can pilot my Somfy RTS
thank you very much Jumbotroll for new version
Posted: Tuesday 01 March 2016 18:36
by mortyre
I'm looking for a way to change SSL port (443) on my Domoticz hosted on my Synology, because my synology use already this port...
Does anyone know how to do that ?
Posted: Tuesday 01 March 2016 21:43
by jumbotroll
Domoticz on synology use SSL port:8443
Posted: Wednesday 02 March 2016 16:03
by jumbotroll
Domoticz V3.4834 Stable.
http://www.jadahl.com/domoticz_stable/
I will keep V2.3530 a while.
Posted: Wednesday 02 March 2016 17:17
by deennoo
Great ! De got v3 on syno !!!
Posted: Wednesday 02 March 2016 21:02
by jumbo70
Hi Jumbotroll,
Did you manage to find solution for below issue with the aeotec gen5 stick?
If not, I'm considering to buy other zwave usb stick like:
zwave.me or Vision usb-stick.
Do you think one of these will work with my DS112+ ?
Thanks for your support!
Jumbo70
Posted: Wednesday 02 March 2016 21:17
by jumbotroll
jumbo70 wrote:Hi Jumbotroll,
Jumbo70
You can do a test and telnet or ssh the NAS and type: killall synousbmodemd
Then plug in your device and see if it appears in Hardware meny on domoticz.
Posted: Thursday 03 March 2016 19:36
by jumbo70
The 'killall synousbmodemd' command did not help. Actually 'No process was killed'.
Any idea if the Vision or Zwave.me usb stick will give similar problem, or is this problem specific for the Aeotec gen5 stick?
kind regards,
Jumbo70
Posted: Thursday 03 March 2016 20:15
by jumbotroll
jumbo70 wrote:Hi,
kind regards,
Jumbo70
What DSM version du you have on your NAS? 4.2,4.3 or 5.2?
