Page 33 of 55
Re: [MyDomoAtHome] Support thread
Posted: Friday 07 October 2016 15:08
by TroisSix
Hello all,
I'm using mdah for a long time, it perfectly works
I have version 0.1.51, but
I can't succeed in installing lastest version 0.1.57 :
- I tried "sudo apt-get update" then "sudo apt-get upgrade" then "sudo apt-get dist-upgrade", but still
0.1.51
- I uninstalled mdah then reinstalled it, and apt-get still find 0.1.51.
what am I going wrong?
I have a pi2 with jessie, I have the good e-nef source in sources.list..
Have you any idea to help me? thank you
Posted: Friday 07 October 2016 16:01
by jumbotroll
TroisSix wrote:Hello all,
0.1.51
Here:
https://github.com/empierre/MyDomoAtHome/releases
http://www.e-nef.com/domoticz/mdah/
Posted: Wednesday 12 October 2016 14:40
by furio49
there is no deb (pi2) package in the repository !!
Posted: Wednesday 12 October 2016 17:40
by TroisSix
Yes furio49, that's why we cannot update to last version 0.1.57.
But when I check http://my_ip:port/devices I see this:
...{"id":"S1","name":"New version found","type":"DevGenericSensor","params":[{"key":"Value","value":"v0.1.57","unit":"","graphable":"false"}]},...
That's a nonsense
Posted: Sunday 16 October 2016 20:04
by Tharland
i followed the guide, and see my devices with ip:port booth gateway and domoticz but in the app it doesn´t show the devices or anything. i get "ISS system success"
EDIT: On android it works.. not on iphone/ipad
Posted: Wednesday 19 October 2016 18:57
by Thomasdc
Thomasdc wrote:Hi!
Its probably allready answered but i dint find it back in the forum or wiki (maybe handy to add it in the wiki)
my setup:
Domoticz and imperhome are working fine (without users/passwords)
now i wanted to add users and passwords in my domoticz system but now i cant get the app imperihome working anymore..
do i need to do something more then just fill in the 'admin' and 'passsword' field in the configuration wizard in the app?
(so without any sort of authentification (blank password and user) was it all working fine, now i added some users and i cant get imperihome working anymore.. )
is it not possible to use imperihome with different domoticz users?
Re: RE: Re: [MyDomoAtHome] Support thread
Posted: Monday 31 October 2016 21:40
by Justintime
TroisSix wrote:Yes furio49, that's why we cannot update to last version 0.1.57.
That's a nonsense
So updating is not possible?
Posted: Thursday 03 November 2016 15:48
by sach
0.1.51
Same issue here too.
Posted: Friday 04 November 2016 22:35
by jumbotroll
MyDomoAtHome for Synology.
DSM 6.0
node-mydomoathome-0.1.59.spk
http://www.jadahl.com/domoticz_beta_6/
DSM 5.2
node-mydomoathome-DSM5-0.1.56.spk
http://www.jadahl.com/domoticz_beta/
Thanks to epierre
Posted: Sunday 06 November 2016 19:08
by epierre
@furio49 as said kindly Jumbotroll it is :
Here:
It now works manually on windows, see github
Posted: Sunday 06 November 2016 19:09
by epierre
> I have version 0.1.51, but I can't succeed in installing lastest version 0.1.57 :
yes in fact it showed a new version I haven't published since I was working on a DSM5 parallel version, latest is 0.2.0
Posted: Sunday 06 November 2016 19:12
by epierre
gilzin wrote:when i try to activate my camera from imperihome i am getting "unable to read stream error"
the camera works fine from domoticz app
can some one knows why?
please use native camera support from imperihome, imperihome is not good on the flow from domoticz
Posted: Sunday 06 November 2016 19:13
by epierre
Bastien wrote:Hi all,
I would like to install MyDomoAtHome but Domoticz is running on Windows environment...Does someone have a corresponding installation guide for me...?
Thank you very much !!
yes see here:
Posted: Sunday 06 November 2016 19:15
by epierre
DRuw wrote:Hi guys, I have an issue with the graphs and data of the energy meters.
Ive got all things running (see previous posts in this topic) and since last week I have installed solar panels.
Domoticz show a negative number when I produce more energy than I consume and also in the webinterface I have 4 graphs: use high rate, use low rate and proction high an low.
In domoticz this work perfect and looks great but in the mobile interface of imperihome it all goes south...
It seems that only consumption is used and the production isnt?
Can this be changed???? (should be, Domotics is correct...)
yes if you guide me through which data to expose from API
Posted: Sunday 06 November 2016 19:17
by epierre
mvzut wrote:I also have issues with the new MyDomoAtHome. I completely re-installed my Raspberry Pi 2B with a fresh install of Domoticz etc. But then I found out that this the new Javascript implementation has two MAJOR drawbacks on my system:
- My Raspberry Pi uses around 10% cpu when Imperihome is running. This used to be around 3%.
- Loading graphs takes ages! From a few seconds with the "old" version to >10 seconds now
Are these aspects that are still being worked on? Or do I just have to live with them, or switch over to a faster system?
P.S. I don't have the problems that ripp2003 describes, operating switches etc. is almost instantaneous
Should not, for I've had better perf with the latter, have you installed a recent nodejs as on the doc ?
Posted: Sunday 06 November 2016 19:19
by epierre
rhb3rg wrote:Lukewalker wrote:Dear all,
But when I try to search the devices on iOS Ididn't find any device, instead if I try on android I see only a sensor called mydomeathome.
Do you have any suggestion?
Luca
Exactly same same problem here with fresh install of MDAH.
Everything seems to work in the URL but won't work in the ImperiHome (lite) app, with same thing, I can see only one sensor called MyDomoAtHome.
Any clue?
Still have the same issue ? try reload (top right menu) sometimes there is a little latency on first use
Posted: Wednesday 16 November 2016 23:54
by hanryz
Hi epierre,
I have a problem with MyDomoAtHome as the REST interface between the Domoticz and Imperihome.
That is, a gas consumption meter in "utilities" tab of Domoticz is not shown with the "graph" option enabled in Imperihome.
There are though some other temperature sensors which have this option "graph" enabled.
How can we tackle the issue?
Please note that sharing the whole database is not a good idea, maybe we can start differently with some other data/output which could help? Below, I will provide the JSON output of Domoticz for the gas meter which casuses the problem.
Thanks for any ideas in advance,
Hanry.
The JSON output:
P.S. here is the JSON output for the Gas Meter which is not enabled with the "graphs" option:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Counter" : "601.292",
"CounterToday" : "2.585 m3",
"CustomImage" : 0,
"Data" : "601.292",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 11,
"HardwareName" : "nefit_easy_http",
"HardwareType" : "Nefit Easy HTTP server over LAN interface",
"HardwareTypeVal" : 68,
"HaveTimeout" : false,
"ID" : "1",
"LastUpdate" : "2016-11-16 23:54:32",
"Name" : "GasConsumption_Cellar_NefitHR",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Gas",
"SwitchTypeVal" : 1,
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 2,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "76"
Posted: Thursday 17 November 2016 10:46
by epierre
ok looks like I did not say it was graphable, easy to correct.
"Please note that sharing the whole database is not a good idea": gizmocuz do it and recommanded me to do it too so it is one proposal, for graphs this is where I need it when values are strange... for graphing is based on live data, and I cannot fake
https://github.com/empierre/MyDomoAtHome/issues/132
Posted: Thursday 17 November 2016 10:57
by hanryz
Hi epierre, thanks for your quick reaction.
It seems that it can be easy to correct. When could I/we expect the issue 132 to be closed?
Thanks again, Hanry.
Posted: Thursday 17 November 2016 10:59
by epierre
tonight
I just need to do the packaging and a few tests
