Blockly examples
welby
Re: Blockly examples
Your right in using the 10% for the gateway as that will play the siren sound. What your problem is that while the 300 second wait is happening the code then moves to the next line and cancels it after the 5 seconds. You need to combine the wait time and the off time together in the same line.
Patou
Re: Blockly examples Script not found
Hello I am new on this forum
I use Domoticz on a Synology NAS to control some ESP Easy units
Version: 4.9700
Build Hash: a3a4590-modified
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: None
With one switch I want to send 2 HTTP commands to the ESP easy unit
So I use blockly to make the 2 commands with One switch see screenshoot attached The file is named "A"
In the switch setting I have put : On action : script://A
When I turn on the switch I have a log error as follow :
2018-12-28 22:00:34.299 (Switches) Light/Switch (Open-Close)
2018-12-28 22:00:34.298 Status: User: Admin initiated a switch command (8/Open-Close/On)
2018-12-28 22:00:34.298 Error: SQLHelper: Error script not found '/usr/local/domoticz/var/scripts/A'
Can somebody tell me what I am doing wrong ?
Thanks in advance
Patou
Version: 4.9700
Thanks in advance
Patou
- 2018-12-28_22h43_28.png (14.35 KiB) Viewed 5196 times
- 2018-12-28_22h57_10.png (2.95 KiB) Viewed 5196 times
Patou
Hello again,
I found my mistake ....
The 2 blocks must be linked with the else if statement
Hope this can help somebody else ...
Patou
Patou
- 2018-12-28_23h39_38.png (13.98 KiB) Viewed 5192 times
frigide
Why is this not working?
- StanHD
Try with the other "if" block that does not have the blue gear icon. The one you have used needs an "else if" to work.frigide wrote:
Sent from my SM-T820 using Tapatalk
Python:- Broadlink RM2, Sonos
frigide
Thanks for answering. But if that is it, why is this not working?StanHD wrote: Saturday 05 January 2019 17:39Try with the other "if" block that does not have the blue gear icon. The one you have used needs an "else if" to work.frigide wrote:
tozzke
- Domoticz version: Stable
Which version of Domoticz are you running? In the older versions you can select what type of event you want it to be, All/Device/Security/Time/Uservariable. In the newer versions of Domoticz this dropdown menu doesn't exist anymore and I don't know whether the event can trigger on a variable
- MarcelMAH
- Domoticz version: v3.8025
I'm trying to create a Blocky for the following, but I keep getting errors (tried multiple ways, all result in errors with syntax in the Domoticz logs):
Enable a scene when it's 07:00 but only when sunrise is after 07:00 and then enable another scene when sunrise is now.
Any help would be appreciated.
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
tozzke
Something like this should work I'd say:
'Light' should be one of the devices from the scene to prevent retriggering, or you could use user variables
shamie
i have the Blocky below running to turn a light on when a PC is turned on but only in the evening, but i noticed in the log that the ON command every minute is resend due to this Blockly, what is the trick that it doesnt send it continously ? my best guess is some sort of check that when light is on it should not be resending a ON command?
JimmyH1969
Or add a "and Bureaulamp Wendy = Off" to the IF line.
shamie
Thank you for your quick reply.JimmyH1969 wrote: Thursday 24 January 2019 16:07 Or add a "and Bureaulamp Wendy = Off" to the IF line.
i added the line like below, i hope the sequence is correctly, i will find out this evening.
JimmyH1969
Looks good to me
shamie
and it works good too, tnx
JimmyH1969
No problem
- PetervandePol
I am afraid I need some help. I can't figure out how to switch two lamps on between sunset and sunrise with a motion sensor. It works without the time restiction, but I do not want the lights on and off during the day. Based on the examples in this forum I have made this:
But nothing happens
Where do I go wrong?
But nothing happens
geezerrr
A day is from 00:00 till 23:59.PetervandePol wrote:Hi,
But nothing happensWhere do I go wrong?
You need to adjust your blockley like sunset till 23:59 and a second line from 00:00 till sunrise
- waaren
There is no such timePetervandePol wrote: Wednesday 30 January 2019 14:34 Hi,
Try > sunset OR < sunrise
tozzke
what @geezerrr and @waaren said with the addition that the Set part should be split in two. So you'll have to add a Set block for YeeLight 1 and another Set block for YeeLight 2, you can't use the 'and' block in the outputPetervandePol wrote: Wednesday 30 January 2019 14:34 Hi,
Also the 'On for x minutes' doesn't always react as you might think it does. When the device is off when the 'if' is triggered, it'll turn on and after the set time it'll turn off like you'd expect. Is the device already on however (when the 'if' is triggered) it won't turn off but will turn to the state it was at the trigger, so "back" on in that case.
- PetervandePol
Thank you, @tozzke.tozzke wrote: Thursday 31 January 2019 21:46what @geezerrr and @waaren said with the addition that the Set part should be split in two. So you'll have to add a Set block for YeeLight 1 and another Set block for YeeLight 2, you can't use the 'and' block in the outputPetervandePol wrote: Wednesday 30 January 2019 14:34 Hi,
I changed to:
... and this works to switch "on" but like you predicted the lights do go on, but not off. How do I achieve that then?
