Locked
SuperMouse
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by SuperMouse »
Hi Rob,
This worked for the setting of the height of the graph, thank you !
[/#graphoutput150 {
   height:100px;
}co0de]
But is it able to make the 'vandaag' default?
I also noticed that after a refresh of the screen this is also set to the first option.
[img]http://i.imgur.com/7nwt8ST.png[/img]
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
EdKo66 wrote:
SwordFish wrote:Sorry, its still a light bulb instead off a door.
Lightbulbs are the new door(s).
Ah a see Image
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
Black screen when my Dash goes standby: http://prntscr.com/eusp6r (I just edit css file. Change hex to black).. Also need to change opacity bit more.. :lol: (EDIT : This better: http://prntscr.com/eusrcb opacity are on 0.0 now.)
Now let see, how can added some important functions (Clock, my gas and power consumption, smartwall plugs consumption,, etc.)
Anyone can build a fast processor. The trick is to build a fast system.
rbisschops
Domoticz version: 2.2563
Post by rbisschops »
@robgeerts
Hi Rob,
Herewith the requested data files.
Regards,
Ralph
domoticzdevice_122.txt
(1.36 KiB) Downloaded 126 times
Meteroutput.txt
(47.29 KiB) Downloaded 138 times
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
maluko
Post by maluko »
here my door contact stay light_bulb, and if open or close the door it maintain at "ON".
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "Closed",
Description: "",
Favorite: 0,
HardwareID: 2,
HardwareName: "RFXCOM",
HardwareType: "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
HardwareTypeVal: 1,
HaveDimmer: true,
HaveGroupCmd: true,
HaveTimeout: false,
Image: "Light",
InternalState: "Closed",
IsSubDevice: false,
LastUpdate: "2017-04-09 13:21:32",
Level: 0,
LevelInt: 0,
MaxDimLevel: 15,
Name: "Janela Escritorio",
Notifications: "true",
PlanID: "3",
PlanIDs: [
3
Protected: true,
ShowNotifications: true,
SignalLevel: 7,
Status: "Closed",
StrParam1: "",
StrParam2: "",
SubType: "AC",
SwitchType: "Door Contact",
SwitchTypeVal: 11,
Timers: "false",
Type: "Lighting 2",
TypeImg: "door",
Unit: 10,
Used: 1,
UsedByCamera: false,
XOffset: "0",
YOffset: "0",
idx: "8"
SwordFish
Post by SwordFish »
I don't had the time to test the latest version yet. Had already changed the main.js. Will try it tomorrow.
Blueone
Post by Blueone »
The standby screen is working perfect :).
I wan't to use the dashboard on the original raspberry touchscreen which is only 800x480, is there a possibility to change the fontsize overall to a smaller percentage? I'm testing it in google chrome with the 800x480 (don't have the screen yet). If i do it with the css I have to change it for every item while I wan't the whole system to use a smaller percentage.
2017-04-10 20_25_54-Dashboard.png (237.15 KiB) Viewed 3749 times
Dynamic
Post by Dynamic »
Updates are released very fast. Could someone help me with a line of code that I can run on my Raspberry to clone the latest release from Github to my Raspberry?
Bob123bob
Post by Bob123bob »
Dynamic wrote:Updates are released very fast. Could someone help me with a line of code that I can run on my Raspberry to clone the latest release from Github to my Raspberry?
If your installed dashboard with git clone command (I run the command from /home/pi/domoticz/www/ folder
git clone https://gitlab.com/robgeerts/dashboard/tree/master
you can try a git pull command in the dashboard folder so for e.g.
pi@domoticz ~ $ cd domoticz/www/dashboard/
pi@domoticz ~/domoticz/www/dashboard $ git pull
Already up-to-date.
I'm not a GIT expert but it works for me
Dynamic
Post by Dynamic »
Already up-to-date.
It looks like something is wrong at the server end?
Cloning into 'master'...
fatal: https://gitlab.com/robgeerts/dashboard/tree/master/info/refs not found: did you run git update-server-info on the server?
Bob123bob
Post by Bob123bob »
Backup your CONFIG.js and run the command in domoticz/www/ folder
without "...tree/master/info/refs"
I made a test in my tmp folder
pi@domoticz /tmp $ git clone https://gitlab.com/robgeerts/dashboard
Cloning into 'dashboard'...
remote: Counting objects: 908, done.
remote: Compressing objects: 100% (438/438), done.
remote: Total 908 (delta 498), reused 797 (delta 433)
Receiving objects: 100% (908/908), 5.89 MiB | 476.00 KiB/s, done.
Resolving deltas: 100% (498/498), done.
Checking connectivity... done.
maluko
Post by maluko »
SwordFish wrote:I don't had the time to test the latest version yet. Had already changed the main.js. Will try it tomorrow.
door contact is working with the last update and clean the cache.
good were have on group botton, 2 little botton inside to "on" and "off", like blind, because same switch dont comunicate the state so in that case dont have to click two time only the command we want.
maluko
Post by maluko »
this is my dashboard until now, screen taken on deskop, i have maked change on door contact image, the last was a little confusion for me.
only the select switch not working like said before.
http://imgur.com/a/LRwDY
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Bob123bob wrote: For me it's still not working :
device 167 displays now, today and total
device 167_1 displays now, today and total
device 167_2 displays today and total
device 167_3 displays total
Still no way to display 167_1 (now) only :(
Did you have '167' and '167_1' at the same time displaying on your dashboard?
If yes, try only using 167_1 and removing the rest... What does is display?
I can imagine it give some problems when using 167 and 167_1 at the same time.
SuperMouse wrote: But is it able to make the 'vandaag' default?
Fixed
rbisschops wrote:Herewith the requested data files.
rbisschops wrote:When I add:
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,'blocktitle_3','8','9','122_1']
It shows an emtpy box
Fixed and now you see a waterdrop icon instead of fire ;) (triggers this icon because device name is 'Water'
Blueone wrote:Is there a possibility to change the fontsize overall to a smaller percentage? If i do it with the css I have to change it for every item while I wan't the whole system to use a smaller percentage.
You can add css for this in custom.css, like:
body {
	font-size:10px !important;
.h4, h4 {
    font-size: 14px !important;
EdwinK
Post by EdwinK »
It looks like everything is working now. Just one thing remaining, and that is something Rob can't fix ;), but either Domitcz or Eneco should.
mAiden88
Post by mAiden88 »
EdKo66 wrote:It looks like everything is working now. Just one thing remaining, and that is something Rob can't fix ;), but either Domitcz or Eneco should.
Weird thing.. Domoticz works very well here with Toon.. Reason is already clear: toonopafstand.eneco.nl/ is down. Domoticz use that url to read the Toon out.
Screens from script how Domoticz read Toon:
Sorry Mods,
[Dutch]
Is mij alleen nog niet helemaal duidelijk waarom, het bij mij bijvoorbeeld wel nog werkt, bij jou dan weer niet.. Erg raar..
[/Dutch]
EdwinK
Post by EdwinK »
I think Toon hates me.
mAiden88
Post by mAiden88 »
EdKo66 wrote:I think Toon hates me.
Give him a slap, not too hard, otherwise you have no more heating :lol:.
I promise i will looking about it in the weekend, how my connectie is with Toon.
robgeerts
Post by robgeerts »
Although I do see toonopafstand.eneco.nl is down, Toon still does work correctly here, the latest graph-output (Gas) I get is:
[code
"d" : "2017-04-11 11:00",
"v" : "0.010"
[/code]
EdwinK
Post by EdwinK »
See. I repeat what I said earlier.. it hates me...
Locked
