Yet another frontpage
Jasper79
Re: Yet another frontpage
Post by Jasper79 »
Clicking the link says its not safe, going on and the download triggers Chrome and again it says not safe. Might want to repack and share somewhere else?
PatrickSt91
Post by PatrickSt91 »
Jasper79 wrote: Friday 14 August 2020 14:12 Clicking the link says its not safe, going on and the download triggers Chrome and again it says not safe. Might want to repack and share somewhere else?
Thanks for the headsup, i've reuploaded it to a different site.
https://github.com/PatrickSt1991/Domoti ... master.zip
Last edited by PatrickSt91 on Tuesday 18 August 2020 9:22, edited 1 time in total.
bimse
Domoticz version: Model 3
Post by bimse »
Does not work as intended, now it says "403 Forbidden"
Hope you find a solution
Translated with google
PatrickSt91
bimse wrote: Saturday 15 August 2020 12:36 Does not work as intended, now it says "403 Forbidden"
It's on github now, you should be able to download it without any problem now.
GilbertvH
Post by GilbertvH »
Are you planning to implement more garbage companies? Our city doesn't use afvalwijzer but 'deafvalapp'
Jasper79
Post by Jasper79 »
PatrickSt91 wrote: Tuesday 18 August 2020 9:22
Thanks, I'm following this now. Previous link was the direct link to the zip file.
https://github.com/PatrickSt1991/Domoticz-Template
PatrickSt91
GilbertvH wrote: Tuesday 18 August 2020 10:12 Are you planning to implement more garbage companies? Our city doesn't use afvalwijzer but 'deafvalapp'
I wasn't planning on it, but I've added it never the less.
You should be able to see it now on the github page.
Please not i've only added the functionality, you should do a bit of styling yourself in the css :)
Kind regards,
Patrick
GilbertvH
Post by GilbertvH »
PatrickSt91 wrote: Wednesday 19 August 2020 15:10
Kind regards,
Patrick
Great! I'll check tonight!
Update: Date works but image still not available
PatrickSt91
GilbertvH wrote: Thursday 20 August 2020 11:35 Update: Date works but image still not available
Can you post a screenshot or check the code why it's not working?
There should be a image folder, maybe you postalcode has something different.
Cheers,
Patrick
GilbertvH
Post by GilbertvH »
Link to image is referring to http://***/assets/images/Afvalwijzer/GFT_80.png. *** is of course my internal IP and web folder name.
When I open this in a new tab it shows a 404. When I manually change GFT_80.png to gft_80.png it works.
PatrickSt91
GilbertvH wrote: Tuesday 25 August 2020 11:59 Link to image is referring to http://***/assets/images/Afvalwijzer/GFT_80.png. *** is of course my internal IP and web folder name.
Wait it's using the folder Afvalwijzer?
I thought you needed to use deafvalapp?
Have you changed the variable setting?
index.php -> line 2 -> $AfvalType = 'deafvalapp';
GilbertvH
Post by GilbertvH »
PatrickSt91 wrote: Tuesday 25 August 2020 12:09
Changed that already. I also see this on line 78:
<th class="tg-0lax" rowspan="2"><img src="assets/images/Afvalwijzer/<?php echo $container_typ; ?>_80.png"></th>
That's still referring to this Afvalwijzer map
Opera Snapshot_2020-08-25_134454_192.168.178.24.png (17.61 KiB) Viewed 1898 times
PatrickSt91
GilbertvH wrote: Tuesday 25 August 2020 13:38 Changed that already. I also see this on line 78:
Ah I guess I uploaded a beta file then.
I've added a new index.php, please try that one...
My bad :)
index.7z
Correct index version
(2.42 KiB) Downloaded 69 times
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi There nice frontpage!
For my garbage I need to use the opzet_api, in combination with www.mijnblink.nl
Is it possible to integrate this one as wel?
Jan
PatrickSt91
JuanUil wrote: Wednesday 26 August 2020 9:21 Hi There nice frontpage!
Jan
I've send you a private message regarding your request.
GilbertvH
Post by GilbertvH »
Could be my n00bness but when I change the idx for the bottom switches (in your case the PS4, Roomba etc.) to my Domoticz switches nothing happens on toggle. The link refers to my index.php file. In index.php I have the following code for powering off all lamps:
<div class="item col-6 col-md-4 col-lg-2 mb-3 mb-lg-0">
<a href="" onclick='ToggleSwitch("1");'>
<div class="item-inner">
<i class="flaticon-idea-1" <?php echo $active_style[0]; ?>></i>
<div class="flaticon-text">Lampen uit</div>
ToggleSwitch("1") is idx 1 in my Domoticz which is a scene.
PatrickSt91
Hi Gilbert,
The best way to use a scene is to adde the following to domoticz_switches.js
function ToggleScene(idx){
	$.ajax({ url: 'http://192.168.0.125:8080/json.htm?type=command&param=switchscene&idx=' + idx + '&switchcmd=Toggle' });
for reference: https://www.domoticz.com/wiki/Domoticz_ ... _on_or_off
or you can send another parameter with the ToggleSwitch and put in scene or light
but if you choose to go with the above then you should also change onclick='ToggleSwitch("1");' to onclick='ToogleScene("1");'
Domoticz uses different json url's for changing a light switch and changing a scene.
Cheers,
Patrick
JuanUil
Post by JuanUil »
Hi Patrck,
today tried to implement your frontpage with the implementation of blink you made for me.
I did it remotely because I am still on vacation.
When I enter http://192.168.x.xx:8080/Frontpage/index.php
I get a failure 501 not implemented.
I have installed php 7.3 with no result.
Any idea?
Jan
JuanUil
Post by JuanUil »
anyone any idea?
Jasper79
Post by Jasper79 »
Is the directory Frontpage or frontpage?
