Page 4 of 5
Re: zigate tuya siren
Posted: Sunday 12 September 2021 10:37
by marktn
The log of domoticz as attachment.
Thanks for your support!
Posted: Sunday 12 September 2021 14:13
by keros
You can turn off the tuya debug : don't need to have those logs all the time.
I can not help you more. My knowledge stops there.
Please wait until Pipiche comes back or an another expert can answer you.
Posted: Sunday 12 September 2021 14:21
by marktn
keros wrote: Sunday 12 September 2021 14:13
Thanks so far! I will wait for Pipiche.
Posted: Monday 13 September 2021 10:33
by pipiche
marktn wrote: Sunday 12 September 2021 10:12
keros wrote: Sunday 12 September 2021 10:03
I think your plugin is still not up to date > git pull
You are right, did again a git pull, Plugin: 5.1.009
But the problem is still there.
Siren 1 en 3 not working, Siren 2 works.
A strange behaviour is, when selecting a alarm of siren 1 or 3, the switch stays on.
I had a look to your log file and the export, and I'm not able to identify the reason why it is not working.
between the 3 , 2 of them are the same model/same firmware version and the 3rd is same model/ with a different firmware. and in the 2 with the same firmware, 1 is working and the other not.
Have you try to repair one of the non-working since you have the latest firmware/plugin ? Todo that, you need to remove the associated Widgets in domoticz so then the reference to this device do not exist anymore in the Domoticz and Plugin device list.
Posted: Monday 13 September 2021 19:14
by marktn
Hi Pipiche,
I removed al 3 sirens, restart domoticz.
Add siren1, not working, and removed it again, restart domoticz.
Add siren 3, not working, and removed it again, restart domoticz.
Add siren 2, working.
Also did a test with batteries and/without USB cable.
Thanks,
Mark.
Posted: Friday 01 October 2021 19:09
by marktn
Any update on this issue?
Posted: Sunday 03 October 2021 9:29
by pipiche
Looks like there is something wrong or new somewhere. I have a second user experiencing the same issue.
I'll see if he is happy to send it to me, so I could debug what is wrong
Posted: Sunday 03 October 2021 10:00
by marktn
pipiche wrote: Sunday 03 October 2021 9:29
Thanks. I could also send it, but the last experience was not that good
I will for your respond! Thank so far.
Posted: Saturday 20 November 2021 10:06
by pfloryann
I received Tuya siren Neo Coolcam NAS-AB02...in domoticz and zigate he sees it as TS0601-sirene, but doesn't work...the deveice light blinking all the time and he's not get the command. If i'll attach raw json can it help to solve?
Posted: Monday 22 November 2021 20:22
by pipiche
Did you try to repair it once ?
If you can drop the raw json that would help
Posted: Wednesday 24 November 2021 22:42
by marktn
Looks like the same problem I have. Did the other user send you the siren?
Posted: Wednesday 24 November 2021 22:43
by pipiche
Nope:-(
Posted: Thursday 02 December 2021 21:34
by pfloryann
pipiche wrote: Monday 22 November 2021 20:22
I tried with repair but is same.
I will attach the json here, this siren is the last device from the list.
Thank you!
Posted: Thursday 02 December 2021 21:40
by pfloryann
I re-attached the correct raw file
Posted: Saturday 04 December 2021 21:35
by pfloryann
no solution?
Posted: Saturday 04 December 2021 21:52
by pipiche
I have received one. I’ll have some time next week
Posted: Sunday 05 December 2021 19:45
by pipiche
Thanks to @marktn whom was kind to ship one siren to me.
Indeed I'm having the same issue. The Siren get paired with Zigate and plugin, but continuously flashing and not able to be manged by Domoticz/Plugin.
I'll work on that as of tomorrow.
So stay tune
Posted: Monday 06 December 2021 15:35
by pipiche
can you please get the latest beta branch and redo the pairing after removing all widget created
Posted: Monday 06 December 2021 16:01
by pfloryann
Hi Pipiche i tested, now pairing works, temperature and humidity works, melodies/songs works but volume level is low and haven't melody/sound for alert, like short pairing sound or something like this. Switch alert for humidity and temperature doesn't work.
Thank you!
Posted: Monday 06 December 2021 16:06
by pfloryann
Another thing ...all 4 songs stop after 5 seconds and name of song is not correct all the time
