Supported Doorbells by Domoticz?
Domosapiens
Domoticz version: V3.5981
Re: Supported Doorbells by Domoticz?
Post by Domosapiens »
You could take a look here
viewtopic.php?f=50&t=9362#p97362
Same type of "only On" challenge,
but Blockly is triggered by a new On pulse.
Melissen
Post by Melissen »
Thx... but I don't understand anything off it. BlocklY is not my kind of doing things.
Is there someone who can make a LUA-script for this problem?
I have mulitple ON-pulses (everytime I push the button). So I need a dummy which goes on on the button ON-pulse, and switches back to OFF after 5 seconds (or something like that)
So I can use the dummy-switch (which does have ON and OFF state) for switching other devices.
(command like devicechanged will not work)
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
RayAmsterdam
Re: RE: Re: Supported Doorbells by Domoticz?
Post by RayAmsterdam »
Melissen wrote:Thx... but I don't understand anything off it. BlocklY is not my kind of doing things.
You could put a JSON command in the virtual switch's on action, to turn itself off after some delay.
Melissen
Post by Melissen »
I fixed it.... made a very simple script. Only use DeviceChanged function but not with an On/Off state selection and the end of this command.
for example:
If devicechanged['doorbell'] then
Instead of:
If devicechanged['doorbell']="On" then
Thomasdc
Post by Thomasdc »
thecosmicgate wrote:
I followed this guide, but the thing i want or need is just to separate the chime button from the chime .
So these 2 are two different devices . so i can use a blockly and timer when the chime doesn´t make any sound etc.
I tried everything without succes , is there anybody who can help me ?
( or is the only solution to buy a second action / selectplus doorbel ? )
did you( someone ) figure out how to do this?
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
After a lot of failure this was working for one or 2 days , then it stops .
So nowadays I changed to a complete different solution using z-wave
It's nice to be important, but it's more important to be nice
Scooter ;)
freijn
Domoticz version: Stable
Post by freijn »
Still interested too !!!!
I use the button to switch on and off my lights, but indeed would like the chime separately to notify an event in my livingroom.....
My Code :
if (devicechanged['SecDeurbel'] == 'On') then
   if (otherdevices['LampFrank2'] == 'Off') then
       commandArray['LampFrank2']='On'
       commandArray['LampFrank']='On'
       commandArray['LampFrank2']='Off'
       commandArray['LampFrank']='Off'
   commandArray['SecDeurbel']='Off'
assenzuid
Post by assenzuid »
Somebody tried the Linbell (Self Powered Wireless Doorbell) doorbell already with Domoticz?
gtjgtj
Domoticz version: 3.1 OMV
Post by gtjgtj »
Has anyone added this specific cheap doorbell to their setup?
It would be great if it's compatible, otherwise I'll have to invest in a new one.
mvveelen
Post by mvveelen »
Anyone got the (additional) bell push Byron BY37 working?
It operates aso on 433.92MHz, I tried the undec and Byron SX protocol, but it isn't seen by my Domoticz. Using the latest firmware (1025) for the RFXcom.
The reason I tried it was because it's IP44. I already used a few bell push devices, but one after the other dies (oxidised mostly).....
Edit:
I've sent the data the RFXmgr received to RFXcom. The sad thing was....the battery supplied with the bell push, was empty. With a new battery, I was able to receive messages. Hopefully they can add the bell push to a new firmware for the RFXcom.
Edit II:
The Byron BY37 now works in combination with the RFXcom with the latest beta firmware I received from them. Many thanks to Bert :D .
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
PetervandePol
Post by PetervandePol »
I just bought a Honeywell/Novar DC845 doorbell. The package says it is 434MHz, so I figured adding through my RFXCOM would be simple. No such thing. Does anyone have luck/experience with this device?
Link: https://goo.gl/chr2oK
